Go to Post There will always be a point in your FIRST experience when you realize you can get away with something that is against the rules. It is at that point when you have a choice to make about your own personal ethics, and what sort of example you will set for your students. - ToddF [more]
Unread 16-01-2007, 19:05
macwhoo macwhoo is offline
None #2061
macwhoo is an unknown quantity at this point
Spikes
Ok, we need some help. The diagram for the electrical calls for 6 spikes, but the kit we recieved only contains 4. Is anyone else having this problem? If it is supposed to be layed out like this, how do we make it work with only the 4?
Unread 16-01-2007, 19:07
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Re: Spikes
You may purchase more Spikes from IFI. You may also use Victors instead of Spikes for controlling motors (but not the compressor); they can be programmed to do basically the same thing.
Unread 16-01-2007, 19:08
None #2061
Re: Spikes
But is it supposed to come with only 4? And will it actually work for us if we don't buy more? And what are Victors?
Unread 16-01-2007, 19:26
AV_guy007's Avatar
AV_guy007 AV_guy007 is offline
AKA: Sam
FRC #0177 (bobcats)
AV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud of
Re: Spikes
spikes and victors are used for controlling motors pneumatics
spikes can only go full forwards full backwards or off
whereas victors are variable speed and operate on a scale of 0 to 254, 127 being neutral, 254 full speed forward, 0 full speed backwards.
there are only supposed to be 4 spikes and 4 victors in the kit and only the amount needed to operate your motors is needed i.e if you have 2 motors you want to have variable speed control over and 1 motor you want on or off control over you would need 2 victors and 1 spike
Team 177
bobcat robotics
BLUE ALLIANCE CREW MEMBER
Next event attending: Kickoff 08- Manchester NH With TBA
Unread 16-01-2007, 19:28
Gamer930's Avatar
Gamer930 Gamer930 is offline
Team 930 and 171 Alumni
AKA: Justin
Gamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to behold
Re: Spikes
you don't have to use everything they give you or show (in terms of motors, spikes, and victors). . . If you do use something you have to wire it that way in the correct pattern (with the correct terminal strip and breakers). . .
For Example. . . If you don't use Pneumatics you probably won't be using Spikes at all. . .
Also same applies for Victors 884s. If you use 3 motors you will use 3 victors and not try and use X that they show in the diagram
2010 to Present, Scorekeeper/Field Power Volunteer for FRC/FTC/FLL
2005 - 2010, Team 171 College Mentor
2002 - 2005, Team 930 Student
Unread 16-01-2007, 19:31
Re: Spikes
The kit of parts only comes with four Spikes.
If you have six motors, you need six Spikes/Victors to drive them (choose Spike vs. Victor depending on the motor, and what you want to do with them). Check section 8 of the rules for a full description of what you can and can't do.
Victors are speed controllers that take a PWM (Pulse Width Modulation) signal from the RC and a 12 V input from a circuit breaker, and use it to generate what is essentially a variable-voltage output for a motor. This lets you adjust motor speed (almost) anywhere between -12 V, 0 V and +12 V (full forward, idle and full reverse, respectively), represented in the RC code with 0, 127 and 254, respectively.
Spikes are electronic relays (they switch both +ve and -ve terminals). They can only give full forward, idle and full reverse voltages to the motor attached.
Programming Spikes X-Istence Programming 3 17-02-2006 14:53
Spikes Denman Control System 17 16-11-2004 07:51
Spikes? st28 Programming 2 24-02-2004 11:36
spikes and victors VinceT Electrical 2 14-01-2004 01:36
Spikes with Motors GregTheGreat Electrical 22 11-11-2003 10:25
