Go to Post Yes indeed... ten years ago tomorrow, those famous words "water game" were first mentioned on Chief Delphi! Oh, how things have and have not changed... - bduddy [more]
Unread 12-01-2007, 10:10
SleeveofWizard SleeveofWizard is offline
FRC #0066
SleeveofWizard is on a distinguished road
USB Chicklet
Is it possible to use more than one controller when using the USB Chicklet? If so do you need two USB Chicklets or can you use a splitter to separate the one USB port?
Unread 12-01-2007, 10:14
Fred Sayre's Avatar
Fred Sayre Fred Sayre is offline
AKA: Fred Sayre
FRC #0488 (xbot)
Fred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant future
Send a message via AIM to Fred Sayre
Re: USB Chicklet
http://www.chiefdelphi.com/forums/sh...hlight=usb+hub
and specifically:
Re: USB Joystick adapter is here!
Originally Posted by Michael Hill View Post
Is it possible to run multiple joysticks through a USB hub using only one unit?
The Chicklet only supports HID. It does not support HUB. We have a solution that does support HUB and other device classes however that solution was not cost effective. We wanted to keep the device affordable for FIRST Teams. Also the 15-pin joystick port does not provide enough interface to support more than one device. We have a device that outputs RS232 data instead of analog/digital. It is less expensive than the chicklet. If we had a serial port on the O/I this would have been the way to go.
Mike Copioli
CTRE
team 217
Unread 16-01-2007, 20:40
lilsmitty33 lilsmitty33 is offline
FRC #0537
lilsmitty33 is an unknown quantity at this point
Cool Re: USB Chicklet
does anyone know how to attach power to the usb-chicklet? i can't seem to find any clear instructions on powering the chicklet and i dont want to risk it with wiring it up wrong (backwards).
Unread 16-01-2007, 21:39
Mike Copioli's Avatar
Mike Copioli Mike Copioli is offline
You make it pretty We make it dance
no team (Retired(3539, 217))
Mike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond repute
Re: USB Chicklet
The Chicklet has protection against reversing its polarity so don't worry about that. The connector that is supplied with the chicklet comes apart buy unscrewing the metal plug from the plastic housing. The Chicklet needs a center positive to function. So solder the positive lead of a backup battery to the center terminal of the plug. The negative(black lead) goes to the outer terminal. Or while practicing you can use a 9 VDC (center positive)unregulated power supply.
Mike Copioli
CTRE Hardware Engineer
http://www.ctr-electronics.com
Team 3539 The Byting Bull Dogs
2013 Michigan State Champions
Team 217 The Thunder Chickens
2006 World Champions
2008 World Champions
2009 Michigan State Champions
Unread 27-01-2007, 10:08
predator_hunter predator_hunter is offline
FRC #0537
predator_hunter is an unknown quantity at this point
Re: USB Chicklet
hey does anyone know how to code the chicklet?
Unread 27-01-2007, 10:16
FRC #0537
Smile Re: USB Chicklet
does anyone know anything about the header pins on the chicklet. What do we use them for?
Unread 27-01-2007, 15:39
Re: USB Chicklet
The Chicklet does not require programming. It can be configured and calibrated which is what pins 1 and 2 on the header pins are for. Please read the user manual for more information:
http://www.ifirobotics.com/docs/usbc...ual-rev1-1.pdf
Mike Copioli
Unread 27-01-2007, 15:44
Andrew Blair's Avatar
FRC #0306 (CRT)
Re: USB Chicklet
and specifically:
Mike Copioli
CTRE
team 217
About the serial port on the OI-
The OI has a radio modem port that is not used during competition. Is it a functioning serial port, or simply a hardwired deal that cannot be interfaced to run data into the competition port's data out?
Unread 27-01-2007, 20:03
Re: USB Chicklet
Actually the radio modem is used in competition. It is how the O/I communicates with the R/C. I think you mean the dashboard port, which provides output only.
Mike Copioli
Unread 27-01-2007, 20:44
finni's Avatar
finni finni is offline
The Big Guy
AKA: jason
FRC #0521 (L33tCrew)
finni is an unknown quantity at this point
Send a message via AIM to finni Send a message via MSN to finni Send a message via Yahoo to finni
Re: USB Chicklet
has anyone tried mounting the chicklet in a project enclosure it so what size enclosure did you use and what did you you cut for access to the ports
Unread 28-01-2007, 22:35
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
Re: USB Chicklet
One warning about the Chicklet:
Using the original X-Box controller. We had two. One made in China, and one made in Malaysia. The chicklet said that the one made in China was not supported, while the one made in Malaysia was. Just chance I brought two with me.
Anyway, It works.
Jacob
Unread 28-01-2007, 22:45
Re: USB Chicklet
Anyway, It works.
Jacob
Yes, not all of the original X-box controllers are supported. There are so many differant variations of the x-box controller, it was not possible to support them all. For some reason thier PIDs are different. The same is true of the Logitech dual action gamepad. If you purchase an old one from E-bay there is no guarantee it will work. My suggestion is to by a new one(Logitech). They are only $20 and in our opinion a much better controller than the X-box or 360.
Mike Copioli
How the heck do you use an XBOX360 controller with the chicklet?? waialua359 Control System 58 17-02-2008 12:43
chicklet USB/xbox 360 controller spsteam1512 Control System 1 10-01-2007 23:14
USB I/O CJO Control System 2 15-10-2005 20:17
usb to db15 663.keith Technical Discussion 21 20-01-2005 15:16
USB to Serial Jack Programming 24 23-12-2002 14:21
