Go to Post I owe these forums a lot more than $15 for all of the help and friends they have given me. - Karibou [more]
Unread 16-01-2007, 09:54
Daru Daru is offline
Daru has a spectacular aura aboutDaru has a spectacular aura about
Alternative to CIM with 12:1 GearBox
Hi guys,
We're going to need 6 drive motors this year. We determined the CIM with Banebots gearbox would be ideal, but we need two more similar to that. Can you recommend anything that would be about the equivelant? They don't need to be exactly the same, however the closer they are the better.
... actually, maybe I need to rethink it to work with only 4 CIMs.
Thanks,
Dave
706
Unread 16-01-2007, 09:59
Cowmankoza's Avatar
Cowmankoza Cowmankoza is offline
KoZa
AKA: Matthew Koza
FRC #1251 (The Tech Tigers)
Team Role: Operator
Cowmankoza has a spectacular aura aboutCowmankoza has a spectacular aura about
Send a message via AIM to Cowmankoza
Re: Alternative to CIM with 12:1 GearBox
You could always get the Andy Mark planetary that converts the fischer price to the same rotations as the cim. (But in the end you would probably benefit more from rethinking it to work with 4 cims as opposed to the addition of 2 extra motors)
Team 1251 The Techtigers
2008 UCF Regional Champs thanks to 233 and 86
2008 UCF Regional GM Industrial Design Award
2007 Palmetto Regional finalists thanks to 1626 and 1758
2007 Palmetto Regional Motorola Quality Award
2007 UCF Regional Champs thanks to 1270 and 86
2007 UCF Regional GM Industrial Design Award
2006 Palmetto Regional Champs thanks to 11 and 247
2006 UCF Regional Semifinalist thanks to 86 and 710
2005 Palmetto Regional finalist thanks to 25 and 301
2005 Palmetto Regional Xerox Creativity Award
2005 UCF Regional finalists thanks to 845 and 1270
2005 UCF Regional Judges Award
2004 UCF Regional Rookie All-star Award (The real winner)
Unread 16-01-2007, 13:25
AdamHeard's Avatar
Lead Mentor
With some gearing you can use the one large cim and one small.
Or you can use the FP planetary from andymark
Unread 16-01-2007, 13:27
Tytus Gerrish's Avatar
Tytus Gerrish Tytus Gerrish is offline
IGAB, ADHD, and Dislexic
AKA: Ty
FRC #0179 (SwampThing)
Team Role: Tactician
Tytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond repute
if your looking for the effedt of 4 Cim mortors without thinking about it too much the planetary grom andymark is the way to go. it has the same hole pattern and dimentions as a Cim. and similar speed output.
Unread 16-01-2007, 15:42
Actually we're doing this:
Chassis Drawing
I don't think using 4 CIMs would be easy (keeping power into consideration)
It would allow us only 2 CIMs per 'direction'
We'll probably go with the AndyMark gearboxes.
Thank you!
Dave
Unread 16-01-2007, 17:13
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
If you are intent on a 3 motor per side drive, you may consider the type of arrangement shown in this picture. All it would require is a .8 module gear that is approximately 1/4 the number of teeth of the 50T gear that is on the CIM (12 or so teeth should do nicely). Press it on the FP motor and then figure a mounting method to allow the motor to mate with the 50T.
If FIRST would have given Banebots more time, I think they would have built the mounting system right into the mold for the plastic housing. In fact, given just a little more time, I may have gotten my request to have the pitch of the gears for the adapter changed to 32 DP to match the gear that the FP comes with (32 DP = .79375 module which is very close to but not exactly .8 module).
If we had done this (and changed the housing tool to accept FP motors and had we know how many teeth were on the FP motor), we could have made gearbox that could take up to 4 motors (2 CIMs and 2 FPs) without requiring any motor changes. Now THAT would have been cool.
Ah well... ...perhaps some other year.
Joe J.
http://www.chiefdelphi.com/forums/at...1&d=1168351452
Team #88, TJ2
Unread 16-01-2007, 17:50
Ianworld's Avatar
Ianworld Ianworld is offline
AKA Ian Ferguson
AKA: Ian Ferguson
FRC #0694 (StuyPulse)
Ianworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud of
Send a message via AIM to Ianworld
I may have read your post wrong but it actually sounds like you're trying to drive each wheel independently with its own motor. One thing you could look into is connecting your wheels with roller chain. That way you dont' need to power each wheel indpendently.
Team Website
Unread 16-01-2007, 20:13
We intend to use 6 omniwheels, 4 of them oriented in the forward-backward direction, and two of them in the left-right direction to allow side to side translational movement.
To use only 4 motors, we would need to link the forward-backward wheels with chain, like you suggested. I fear that using one motor on each side of the robot would severly limit what pushing power we would have.
Two two CIM-like motors would be for the side-to-side translational movement (and maybe turning), which we don't intend to use to push with, so lacking power there would be acceptable. We would like it to be close to the same speed, however it's not too important as long as it moves us fairly quickly.
Unread 16-01-2007, 23:54
NK2007 NK2007 is offline
662's Manipulator VP
NK2007 is an unknown quantity at this point
Is this what you are trying to do?
This is the bike cim with the banebots gearbox, something I cadded up for an arm design we had.
http://www.chiefdelphi.com/media/photos/26252
~neill
Unread 17-01-2007, 14:24
That would be overkill for the drive, but something like that for our lift might be perfect ;D
Unread 17-01-2007, 14:35
Brandon Holley's Avatar
Thats a pretty complex drive system, but i must say its creative.
You may want to think about your pushing ability in general with 6 omni wheels there. No matter what direction you get pushed from, an omni wheel is able to slide freely.
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 17-01-2007, 14:42
Billfred's Avatar
Billfred Billfred is offline
And yet it's been competitive in the past; 343 did a similar design in 2002, and won the KSC regional that year. There's some videos on Google Video of their matches, and one picture on CD-Media: http://www.chiefdelphi.com/media/photos/13692
(Of course, they had metal-roller omniwheels--you can't do that anymore.)
Unread 17-01-2007, 14:45
Ben Piecuch Ben Piecuch is offline
Bengineer
Ben Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond repute
This 6-wheeled omni drive setup is exactly what Team 343 did in 2002. Here is a picture of their robot. I can see that they used the Fisher-Price motors and gearboxes to drive their "sideways" omnis. I don't know what motors they used for their "forward" omnis. This robot won at least one Regional Competition, and was extremely effective at moving TWO 180lb goals around the field. So, I think that would probably put to rest the question of "how much traction" can you get from this setup.
This robot has a very special place in the students and mentors of team 343. I'm sure any of them could tell you more about it.
BEN
opening up the BaneBot gearbox to install the CIM motor jskene Motors 9 22-01-2007 11:12
Strange noises from the BaneBots gearbox/CIM combination. PhilBot Motors 5 15-01-2007 11:15
pic: Bike Cim + 56 mm gearbox NK2007 Extra Discussion 7 15-01-2007 01:10
Gearbox that can be used inline with a CIM bombadier337 Motors 3 11-03-2005 22:05
