Go to Post To think that one can "learn" engineering in 6 weeks while under the strain of building a robot too is proposterous. FIRST isn't about teaching. It's about inspiring. - Collin Fultz [more]
  #45   Spotlight this post!
Unread 17-01-2007, 01:12
Andrew Schuetze's Avatar
Andrew Schuetze Andrew Schuetze is offline
499 Founder / Alamo FTC & FLL AP
Andrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond repute
Re: quadrature
Originally Posted by Phalanx View Post
Actually the sensor does provide you with rotation direction information, but it is not easy, nor worth while to obtain IMO. You would need to measure the length of the pulse width of the signal. In the sensors datasheet it does say what the lengths of the pulse widths are. They are different for forward moving(CW) and reverse moving(CCW).
One of our programming mentors read this and I just can't get my head around how this works if the sprocket teeth are symetrical Maybe a picture would help. Does the spec sheet have one?
APS
APS
Founder FRC 499
Parent alumni FRC 2745 & 4219
Co-Coach FTC 4549 & 6407
Alamo FTC Affiliate Partner
Alamo FLL Affiliate Partner
Gear Tooth Sensor nukem Programming 9 04-02-2006 20:21
Gear Tooth Sensor Talha Electrical 1 23-01-2006 21:29
Gear Tooth Sensor AMIRAM Electrical 2 22-01-2006 04:09
Gear Tooth Sensor Question (InsrtNameHere) Electrical 2 20-01-2006 02:19
Gear tooth sensor issues Nine9cracker Electrical 2 17-01-2006 02:37
