Go to Post Bottom line: if it confuses my mom, it is bad for FIRST. - Joe Johnson [more]
View Poll Results: Which drive system?
Tank 92 68.15%
Tread 6 4.44%
Crab / Swerve 14 10.37%
Other 23 17.04%
Voters: 135. You may not vote on this poll
Unread 17-01-2007, 02:24
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Re: What drive system is your team using?
Originally Posted by Justin M. View Post
Standard 4WD tank style driving w/ AndyMark KOP wheels. Keeping it simple this year.
4 BaneBots transmissions will be used - one for each wheel, with a 1.6:1 geardown from shaft to wheels (with chain), giving us a total geardown of 13.6:1. Our bot will be primarily offense so we will need speed and manuverability.
As a head's up, a 1.6:1 reduction from the Banebots 12:1 reduction results in an overall ratio of 19.2:1. I'm not sure if you made a typo or if you calculated your final ratio incorrectly, but you should be prepared for the robot to move a bit slower than you may have anticipated.
--Madison--
...down at the Ozdust!
Unread 17-01-2007, 02:32
Justin M. Justin M. is offline
Mechanical/Driver
FRC #0321 (RoboLancers)
Justin M. is on a distinguished road
Send a message via AIM to Justin M.
19.2:1 is what I meant, I typed it wrong....lack of sleep is killing me.
Team 321: CHS RoboLancers - Drexel University, CHS Alumni Assn., SDP, Philadelphia Motorsports, Lima Corperation
Unread 17-01-2007, 08:09
ewankoff's Avatar
ewankoff ewankoff is offline
hurdling=touch but don't spill
AKA: -=The WANK=-
FRC #1676 (PI-oneers)
ewankoff is a name known to allewankoff is a name known to allewankoff is a name known to allewankoff is a name known to allewankoff is a name known to allewankoff is a name known to all
We're using 4 banebots transmisions turning six KOP andy mark wheels. we decided to gear up the transmissions up to about 8 ft per second.
2005- NJ rookie all-stars
2006- NJ judges award winners
NJ&Palmetto safety credit award winners
Palmetto finalists
2007-NJ Website award winners
NJ Motorola quality award and J&J sportsmanship award winner
Buckeye Motorola quality award winner
NJ #3 seed and semifinalist
2008NJ Chairman's Award
JOHNY FIVE is ALIVE!!
Unread 17-01-2007, 08:48
xMarkThePiratex xMarkThePiratex is offline
"Carpe Nocterm" Sieze The Night
AKA: Mark
FRC #1522 (DOTM (Defenders Of The Multiverse))
Team Role: Webmaster
xMarkThePiratex is an unknown quantity at this point
Send a message via AIM to xMarkThePiratex
Mecanum Wheels. 4 wheels each independently driven, so far we've been able to get it to strafe directly to the right and left. as well as normal foward reverse and turning. and these wheels get suprisingly good grip.
xMarkThePiratex
Team 1522 (DOTM) 2nd Year Member
Unread 17-01-2007, 09:43
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
We're going with six wheel drive with a custom frame. We're using colson wheels and Andymark 2 speed transmissions. We should be pretty beefy and fast at the same time.
Mentor 2415
Unread 17-01-2007, 10:02
cgredalertcc cgredalertcc is offline
AKA: Charlie Baxter
FRC #1747 (Harrison Boiler Robotics)
cgredalertcc is a name known to allcgredalertcc is a name known to allcgredalertcc is a name known to allcgredalertcc is a name known to allcgredalertcc is a name known to allcgredalertcc is a name known to all
Send a message via AIM to cgredalertcc
2 8" X 2" IFI tractions (with our own special touch)
2 andymark molded plastic omis
4 12:1 BB transmissions
4 cims
Our final ratio is going to be a 24 to 1 so we have that ever important defensive edge. We will probably have one "drive assembly" at each corner where there will be a small sproket and chain system.
best of luck
Unread 17-01-2007, 10:30
MishraArtificer's Avatar
MishraArtificer MishraArtificer is offline
Winner, Chief Delphi Insanity Award
AKA: Jeremy Marr
FRC #0240 (T.E.M.P.E.S.T.)
MishraArtificer is a glorious beacon of lightMishraArtificer is a glorious beacon of lightMishraArtificer is a glorious beacon of lightMishraArtificer is a glorious beacon of lightMishraArtificer is a glorious beacon of lightMishraArtificer is a glorious beacon of light
2 Banebots, chained 4WD, some odd wheels that I saw at IRI and the Ford First event at Macomb ccc.
Madness?
THIS IS F.I.R.S.T!
Unread 17-01-2007, 10:49
Jeremiah Johnson's Avatar
Jeremiah Johnson Jeremiah Johnson is offline
Go VOLS!!
AKA: Budda648
no team (QC Elite)
Jeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond repute
Send a message via AIM to Jeremiah Johnson Send a message via MSN to Jeremiah Johnson
We're goin' crabstyle this year... from what I've seen in the Inventor mockup. IFI Traction wheels. 8020 Frame... maybe I'll have some teasers up after next Tuesday's meeting.
Do The Tyler!
XBOX Live Gamertag = theVelvetLie
Unread 17-01-2007, 11:23
Brian Mocci's Avatar
Brian Mocci Brian Mocci is offline
Still hanging around..
FRC #0195 (Cyber Knights)
Brian Mocci is a splendid one to beholdBrian Mocci is a splendid one to beholdBrian Mocci is a splendid one to beholdBrian Mocci is a splendid one to beholdBrian Mocci is a splendid one to beholdBrian Mocci is a splendid one to beholdBrian Mocci is a splendid one to behold
Send a message via AIM to Brian Mocci
195 is using 6WD with andymark performance wheels (6"x1"), a custom frame and our own designed 2speed transmissions from last year.
UTC Regional Champions
2006
UTC Innovation And Control Award
Nationals Innovation and Control Award
Nationals Einstein Runner-Up
Unread 17-01-2007, 11:27
Brandon Holley's Avatar
were thinkin about using wheels
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 17-01-2007, 12:05
MattB703 MattB703 is offline
AKA: Matt
None #0703 (Team Pheonix)
MattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud of
The CyberKnights without their BrecoFlex tank treads? What is the world coming to?
Unread 19-01-2007, 00:59
GMKlenklen's Avatar
GMKlenklen GMKlenklen is offline
The "Masonater"
AKA: George Mason Klenklen
FRC #2167 (MASMabots)
GMKlenklen is a name known to allGMKlenklen is a name known to allGMKlenklen is a name known to allGMKlenklen is a name known to allGMKlenklen is a name known to allGMKlenklen is a name known to all
Send a message via AIM to GMKlenklen Send a message via MSN to GMKlenklen Send a message via Yahoo to GMKlenklen
Team 2167 is exited to create a "homebrew" drive system... nothing ever atempted before. Yah... we are leaders in inovation fo-shure! Now... just if it works...
Thank you,
formerGrand Master Klenklen
-of the MASMabots-
Unread 27-01-2007, 22:10
Jared Russell's Avatar
Taking a year (mostly) off
Depending on how precise you were with the wording of your post, this could very well be illegal.
Unread 27-01-2007, 22:25
imax48236's Avatar
imax48236 imax48236 is offline
El Presidente
AKA: The Elf
FRC #1701 (Robocubs)
imax48236 will become famous soon enough
Send a message via AIM to imax48236
Our team has decided (through democratic voting and discussion...) to use a three-wheel drive system, with a steerable, powered third wheel.
The final thing is going to look a lot like a forklift.
2007 Events:
Great Lakes Regional
Detroit Regional
<THIS SPACE FOR RENT, $3000 donation to Team 1701>
Unread 27-01-2007, 22:58
foote stepped in
AKA: E. Foote
FRC #0868
2 wheel drive (ifi traction wheels) with 2 speed transmissions. should be a fun time!
Be Healthy. Never Stop Learning. Say It Like It Is. Own It.
Like our values? Flexware Innovation is looking for Automation Engineers. Check us out!
pic: Team 612 Drive System RoboMadi Robot Showcase 7 08-02-2006 16:38
Students, what is your fantasy education system? Ken Leung General Forum 28 04-01-2006 09:20
Using 6 motors in a drive system? FIRST JerseyKid Motors 7 12-01-2005 23:49
What teams have desgined a 6 wheel drive system? Alex Cormier Technical Discussion 41 24-11-2004 12:26
