Go to Post Once I see that it is black with aluminum ends, I only care about the inside. Sort of like Oreo's. - Al Skierkiewicz [more]
Unread 11-01-2007, 15:21
stuntman551's Avatar
stuntman551 stuntman551 is offline
AKA: Finni
FRC #0521 (L33T Crew)
stuntman551 is an unknown quantity at this point
Send a message via AIM to stuntman551
human player interaction with tubes
is it legal to rotate and ilt the tube wile its in the player station chute as long as the human players hand does not go through the chute?
If at first it doesn't work, use a hammer.
If that doesn't work, use a bigger hammer.
Unread 11-01-2007, 15:24
KitKat89's Avatar
KitKat89 KitKat89 is offline
The Blonde in Charge
AKA: Kat Henry
FRC #0888 (Robotiators)
KitKat89 is an unknown quantity at this point
Send a message via AIM to KitKat89 Send a message via MSN to KitKat89 Send a message via Yahoo to KitKat89
Re: human player interaction with tubes
Well the only thing specified in the rules is that the human player can't reach through the slot, so I guess yes.
Unread 11-01-2007, 16:10
Setsanto's Avatar
Setsanto Setsanto is offline
FRC #1334 (OTHS RobOTics)
Team Role: Animator
Setsanto is a jewel in the roughSetsanto is a jewel in the roughSetsanto is a jewel in the rough
Send a message via MSN to Setsanto
It is legal, but I'm not quite sure what you man by rotating. Tilting the ring to the left and right will do quite little as the chute is almost exactly as wide as the rings themselves.
Unread 11-01-2007, 18:25
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
http://www.chiefdelphi.com/media/photos/26159
Unread 11-01-2007, 18:39
Nica F.'s Avatar
Nica F. Nica F. is offline
Mechanical Design Engineer
AKA: That silly panda girl from back in the day.
Nica F. has a reputation beyond reputeNica F. has a reputation beyond reputeNica F. has a reputation beyond reputeNica F. has a reputation beyond reputeNica F. has a reputation beyond reputeNica F. has a reputation beyond reputeNica F. has a reputation beyond reputeNica F. has a reputation beyond reputeNica F. has a reputation beyond reputeNica F. has a reputation beyond reputeNica F. has a reputation beyond repute
Yeah if you look at the link Sean posted up, it shows that there really isnt a lot of room to "tilt" or rotate the tube in any way.
Product Designer, Mechanical Engineer
Purdue Aeronautical and Astronautical Engineer Graduate - Boiler up!
Team 22 Double Deuce / Team 4 Element Alumni / Former 1646 Precision Guessworks Mentor
Unread 11-01-2007, 19:13
AKA: Finni
ok thank you every one
Unread 16-01-2007, 22:54
Swampdude's Avatar
Swampdude Swampdude is offline
AKA: Dan Quiggle
FRC #0179 (Children of the Swamp)
Swampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond repute
After skimming the rules, it doesn't say anywhere that the HP's hand cannot pass the station wall though the chute. It just says you can't touch your robot, and that the robot can't pass through the chute. I think they might add this rule if they think about it for safety purposes, but at this point theres nothing saying you can't manipulate beyond that plane. I need to go post that question...
www.179swampthing.org
Unread 16-01-2007, 23:29
Arkorobotics's Avatar
Arkorobotics Arkorobotics is offline
Robots!
AKA: Ara Kourchians
FRC #0589 (FalkØn)
Arkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to behold
Send a message via AIM to Arkorobotics
Hmmm.. I looked through the rules. I cannot find anything wrong with grabbing a tube and holding it out for your robot to drive by and pick it up. Having your hand just behind the wall (not past that chute plane) and have a robot drive by the side and grasp it through the hole in the tube.
Does anyone see anything wrong with that?
2007 Rockwell Automation Innovation in Control Award winners (Southern California Regional)
Crescenta Valley High School Team 589
http://www.arkorobotics.com My Blag
3.141592653589793238462643383275902884197 <- Current memorization of Pi
Callsign: N6ARA
Unread 17-01-2007, 00:20
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Except for some freak case where the human player's attention was averted for a half second, and the robot clamped onto the tube and immediately started to drive away while the human player was still holding onto it...
Art Dutra IV
世上无难事,只怕有心人.
Unread 17-01-2007, 06:38
Swampdude's Avatar
AKA: Dan Quiggle
But my point is that you can have your hand past the chute plane. It doesn't say anywhere that you can't (at least in the sections where it should).
Unread 17-01-2007, 11:55
Cowmankoza's Avatar
Cowmankoza Cowmankoza is offline
KoZa
AKA: Matthew Koza
FRC #1251 (The Tech Tigers)
Team Role: Operator
Cowmankoza has a spectacular aura aboutCowmankoza has a spectacular aura about
Send a message via AIM to Cowmankoza
Guarenteed the idea that a human players appendages could enter the field via the chute will be addressed during an update, it is very unsafe due to driving inaccuracies and robot to robot contact, with safety in mind I wouldn't suggest that a team use that to their advantage
Team 1251 The Techtigers
2008 UCF Regional Champs thanks to 233 and 86
2008 UCF Regional GM Industrial Design Award
2007 Palmetto Regional finalists thanks to 1626 and 1758
2007 Palmetto Regional Motorola Quality Award
2007 UCF Regional Champs thanks to 1270 and 86
2007 UCF Regional GM Industrial Design Award
2006 Palmetto Regional Champs thanks to 11 and 247
2006 UCF Regional Semifinalist thanks to 86 and 710
2005 Palmetto Regional finalist thanks to 25 and 301
2005 Palmetto Regional Xerox Creativity Award
2005 UCF Regional finalists thanks to 845 and 1270
2005 UCF Regional Judges Award
2004 UCF Regional Rookie All-star Award (The real winner)
Unread 17-01-2007, 12:15
MattB703 MattB703 is offline
AKA: Matt
None #0703 (Team Pheonix)
MattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud of
........ unless you like the nickname "stumpy"
Unread 17-01-2007, 12:40
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
Wait but what if you just wanted to get the tube flat... which is, and i'm just on a hunch, what the original intention of the thread starter might have been?
Anyhow, is there anything that says you can't just push one tube through with another so it lands on the field flat?
Thanks in advance,
-Q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Unread 17-01-2007, 12:54
GeoffP GeoffP is offline
Engineer
FRC #1222 (Falcons)
GeoffP is an unknown quantity at this point
I would assume people are building their robot today around the premise that they can reach their arm through the slot and place the tube however they want on their robot. Example, reach through and lift it a foot and turn it 30 degrees and hang it on a hook on the robot. why would those people assume they cannot continue building around that premise based on the rules?
Unread 17-01-2007, 12:55
Brandon Holley's Avatar
i think you'd have to be pretty dumb to clamp onto a tube so tight that when a robot grabs you and starts pulling you still clasp to it....thats just my opinion tho
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Human Player Joe_Widen General Forum 62 24-04-2006 21:18
the importance of strategy with the human player Nimmy Rules/Strategy 0 06-04-2006 10:04
Human/Computer Interaction Experiment Tom Schindler Chit-Chat 13 14-11-2005 15:44
Coach/ Human Player interaction psychoCHIPMUNKK Rules/Strategy 8 10-03-2004 19:30
Human Player Interaction Tech Fusion Off-Season Events 1 03-11-2001 16:43
