Go to Post Curse you and your logic! - Koko Ed [more]
Unread 17-01-2007, 09:31
D_Price's Avatar
D_Price D_Price is offline
Engineer/Mentor
AKA: Derek
FRC #1708 (Amp'd Robotics (formally Natural Selection))
D_Price has much to be proud ofD_Price has much to be proud ofD_Price has much to be proud ofD_Price has much to be proud ofD_Price has much to be proud ofD_Price has much to be proud ofD_Price has much to be proud ofD_Price has much to be proud ofD_Price has much to be proud of
Clear or Plastic Board for Electronics??
Do u think it is better to use clear plexiglass or if heavier plastic or metal is needed.
Voice your input.
Unread 17-01-2007, 09:36
Ted Boucher Ted Boucher is offline
Its been awhile.....
FRC #0237 (Black Magic Robotics)
Ted Boucher has a reputation beyond reputeTed Boucher has a reputation beyond reputeTed Boucher has a reputation beyond reputeTed Boucher has a reputation beyond reputeTed Boucher has a reputation beyond reputeTed Boucher has a reputation beyond reputeTed Boucher has a reputation beyond reputeTed Boucher has a reputation beyond reputeTed Boucher has a reputation beyond reputeTed Boucher has a reputation beyond reputeTed Boucher has a reputation beyond repute
Re: Clear or Plastic Board for Electronics??
237 has used clear plexiglass or wood for the electronics board in the past. We always try to stay away from metal, since it is easier to have a short occur on a metal surface. We never mount the electronics board in a way that it needs to support a load, so there is no need to use for a stronger material.
The lighter it is, the better.
FRC Team 237 Alumni (04-07)
Western New England College Class of 2011
FRC Team 237 Mentor (11-?)
RKElectricalman's Avatar
RKElectricalman RKElectricalman is offline
Meezy the Mentor
AKA: Rameez
FRC #0384 (Sparky 384)
RKElectricalman is just really niceRKElectricalman is just really niceRKElectricalman is just really niceRKElectricalman is just really nice
Send a message via AIM to RKElectricalman
lexan will do just fine Just don't use 1/16" that's to flimsy
ahhh Division Finalists!!
Unread 17-01-2007, 10:05
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Stay away from Plexiglas (acrylic), because it cracks easily. Lexan (polycarbonate) is much more durable when used on robots, and it's easier to work with (less melting when being machined). The thickness depends on what you want to do with it, and how well it's supported. Metal or heavy plastic (e.g. HDPE) are certainly valid options, but by no means necessary.
Consider that you may want to make your electrical board a structural component of the robot, adding stiffness and reducing the need for other structures.
pic: 1501 Electronics Board roboticsguy1988 Robot Showcase 43 20-02-2006 00:40
pic: 1023 Electronics Board KTorak Robot Showcase 1 13-02-2006 21:57
pic: 701 Electronics Board Doug G Robot Showcase 19 13-02-2006 19:40
Electronics Board Construction/Design zdeswarte Electrical 10 28-01-2005 00:09
Hows your electronics board? eR1c599 Electrical 19 16-01-2005 23:54
