Go to Post Adding an ounce or two of shields is way easier than filling out the mountains of paperwork for that one impatient person to stick their arm into the robot reaching for who knows what only to have their fingers meet up close and personal with a gearbox. - artdutra04 [more]
Unread 17-01-2007, 10:59
NextPerception NextPerception is offline
Sleep-Deprived
AKA: Matt
FRC #0437 (Richardson Robotics)
NextPerception has a spectacular aura aboutNextPerception has a spectacular aura aboutNextPerception has a spectacular aura about
Send a message via AIM to NextPerception
How well does this work on carpet?
I saw this picture
I am assuming those are just delrin skids and I was wondering how well these work on carpet. anyone know?
What is this S - L - E - E - P you speak of?
Battlebots - My Robotics Website
Unread 17-01-2007, 11:02
Jeremiah Johnson's Avatar
Jeremiah Johnson Jeremiah Johnson is offline
Go VOLS!!
AKA: Budda648
no team (QC Elite)
Jeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond repute
Send a message via AIM to Jeremiah Johnson Send a message via MSN to Jeremiah Johnson
Re: How well does this work on carpet?
I'm not sure how well that one worked, but I've seen others like that and they didn't really have any glaring problems. Could be pretty unstable and would easily get caught to the point of no return on the game field.
Do The Tyler!
XBOX Live Gamertag = theVelvetLie
Unread 17-01-2007, 11:10
Sleep-Deprived
AKA: Matt
really. I am not worried about the actuating part on that robot just the skids. it would make our design much simpler to use skids instead of casters or omni wheels (we are considering the 2-wheel drive with casters set up)
redbarron's Avatar
redbarron redbarron is offline
Mike Barron
AKA: Mike
FRC #1270 (Red Dragons)
redbarron is a splendid one to beholdredbarron is a splendid one to beholdredbarron is a splendid one to beholdredbarron is a splendid one to beholdredbarron is a splendid one to beholdredbarron is a splendid one to beholdredbarron is a splendid one to behold
If you are asking if they serve as a good skid plate than yeah it works, but you wil not have much traction at all. You will be pushed around very easily, especially if it gets pushed from the side towards the front. Also, if you are planing on going up a ramp the odds wil be against you.
The Red Dragons
2005 Buckeye Regional Woodie Flowers Regional Award
2005 Florida Regional Finalist Along with 1251 and 845
2006 Palmetto Regional Engineering Inspiration Award
2007 Florida Regional Judges Award and Regional Winners Along With 1251 and 86
2007 Curie Division Winner with 330 and 910
2008 Florida Regional Team Spirit Award Winners
Unread 17-01-2007, 11:11
ChuckDickerson's Avatar
ChuckDickerson ChuckDickerson is offline
FRC #0456 (Siege Robotics)
I am not familar with that particular robot but I believe it must have been from 2004 and designed to retract those front legs to get up on the platforms. The biggest problem I see would be if the air cylinder rams got bent you would be screwed because you couldn't retract the legs. I would be very careful about just a simple rod like that with a skid on the end for this reason. As far as a slick Delrin, etc. skid I think many teams have used them successfully over the years on the carpet.
redbarron's Avatar
Mike Barron
AKA: Mike
Why are you looking at casters or skids?
The Red Dragons
Unread 17-01-2007, 11:12
Sleep-Deprived
AKA: Matt
it shouldnt be any harder to push one with skid plates and a two wheel drive setup than one with a two wheel drive with omnis or casters correct?
Unread 17-01-2007, 11:15
redbarron's Avatar
Mike Barron
AKA: Mike
No I would think they were all in the same general category when it comes to resistance when being pushed, but why are you avoiding wheels?
The Red Dragons
Unread 17-01-2007, 11:18
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
If it has to go up a ramp, just make sure the skid pads have a large enough radius that they will go over the edge of most ramps without getting stuck.
Unread 17-01-2007, 11:22
Sleep-Deprived
AKA: Matt
It would just be lighter weight and easier to implement (i could put it in a tighter ground clearence) than casters or omnis. I'm not avoiding wheels but if there is a better solution then I am going to take it .
im not worried about ramps...
Unread 17-01-2007, 11:26
MrForbes's Avatar
AKA: Jim
yeah, I suppose if you're building the ramp, you don't need to worry about getting up on other ramps
Unread 17-01-2007, 11:28
Sleep-Deprived
AKA: Matt
tisk tisk squirrel.
that my friend is thinking inside the box
redbarron's Avatar
Mike Barron
AKA: Mike
Well I have seen these skid plates in action and they serve their purpose the only downside is that they have no traction. But are you going to be strictly a offensive robot?
The Red Dragons
Unread 17-01-2007, 11:35
Sleep-Deprived
AKA: Matt
"im not allowed to say" says matt as he nods his head up and down
atleast that is the plan right now
Unread 17-01-2007, 11:40
redbarron's Avatar
Mike Barron
AKA: Mike
Ok , Well, I would come up with something that is going to give you a little traction whether it be something you can activate or something that is permanent because if you are going to be an offensive bot this year I think you are going to be messed with a lot by defensive bots during the matches. Well good luck!! What events are you guys attending?
The Red Dragons
How does it work? Ryan O Control System 5 12-03-2006 19:15
How does Nationals work? coldfusion1279 Championship Event 29 30-03-2005 16:47
How Does a Winch Work? Aaron Lussier Technical Discussion 23 20-01-2004 21:14
how does crab drive work? Soukup Technical Discussion 13 25-04-2003 11:31
How does Nationals work?? LunchBox Championship Event 16 18-03-2003 15:55
