Go to Post Being professional means doing things right. Being gracious means doing the right thing. They complement each other perfectly. But I think we should remember to use GP as a guide for our own behavior, not as a yardstick to measure others' shortcomings. - Alan Anderson [more]
  #31   Spotlight this post!
Unread 15-01-2007, 19:00
lopz056's Avatar
lopz056 lopz056 is offline
Chris Lopez
AKA: chris lopez
FRC #1388 (Eagle Robotics)
lopz056 is an unknown quantity at this point
Re: So, who has popped their tubes?
so far weve inflated both tubes, but weve only really used one to practice with on the prototyping manipulators, and yet no leaks
  #32   Spotlight this post!
Unread 15-01-2007, 19:12
Eric Scheuing's Avatar
Eric Scheuing Eric Scheuing is offline
FRC #0999 (MechaRAMS)
Eric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud of
None here yet. I'm pretty sure that a lot of rounded edges on the end effectors are going to be pretty important. Either that, or adding some sort of sheath for corners.
2005-2007: Bobcat Robotics 177
2015-20XX: MechaRAMS 999
  #33   Spotlight this post!
Unread 16-01-2007, 22:17
Otaku's Avatar
Otaku Otaku is offline
Where'd my wrench go?
AKA: Michael Baker
FRC #0675 (Tech High Phantom Robotics)
Otaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond repute
Send a message via AIM to Otaku Send a message via MSN to Otaku
Originally Posted by Cuog View Post
Somehow both of our tubes have survived, i don't know how really
Same for 675 xD
Originally Posted by Plooshiska View Post
All of our tubes are alive and well, but other then use them as chairs we haven't done anything that could possibly damage them.
Yep, same for 675
Originally Posted by Protronie View Post
Best thing I can tell yous... debur your edges... maybe add a couple layers of tape to any metal edge that might come in contact with a tube.
I am so anal about deburring things. I swear, I've deburred every edge I can get to.
"The [Otaku] is a simple creature." "Indeed. I cease to function when removed from a mill."
  #34   Spotlight this post!
Unread 16-01-2007, 22:28
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
One popped and one with a slow leak. I believe the first one popped while using our '05 bot to practice and it hit an exposed screw tip on a spider foot. I then made sure they debur and sand all our spider feet. Our second one has a slow leak, it was caused by a wood splinter since we practice on a wood floor and the spider feet are just OSB chipboard. Live and learn
  #35   Spotlight this post!
Unread 17-01-2007, 09:14
DHarris's Avatar
DHarris DHarris is offline
Professional Procrastinator
AKA: Dana McDanaface
FRC #1845 (Panthera Robotica)
DHarris is on a distinguished road
Send a message via MSN to DHarris Send a message via Yahoo to DHarris
We haven't popped either of ours yet, and neither of them are leaking, which is pretty good considering how often we use them as chairs, hula hoops, or play large-scale horseshoe games with them (using team members as the little post to throw the rings around).
  #36   Spotlight this post!
Unread 17-01-2007, 10:59
Jeremiah Johnson's Avatar
Jeremiah Johnson Jeremiah Johnson is offline
Go VOLS!!
AKA: Budda648
no team (QC Elite)
Jeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond repute
Send a message via AIM to Jeremiah Johnson Send a message via MSN to Jeremiah Johnson
Our red one has nice shiney grey duct tape on it in a couple of places. The other one has yet to make it down from the media center to build, so there has been no chance for robot-tube interaction.
Do The Tyler!
XBOX Live Gamertag = theVelvetLie
  #37   Spotlight this post!
Unread 17-01-2007, 11:27
Brandon Holley's Avatar
both of ours were gone after 2 days
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
  #38   Spotlight this post!
Unread 21-01-2007, 13:33
Chris2 Chris2 is offline
AKA: Christopher
FRC #0269 (CooneyTech Robotics)
Team Role: Webmaster
Chris2 has a spectacular aura aboutChris2 has a spectacular aura about
We inflated both tubes, but used only one. We haven't used it with anything metal, but yesterday it seems to be losing air very slowly, so it must have a slow leak.
CooneyTech Robotics Website
  #39   Spotlight this post!
Unread 21-01-2007, 14:14
JamesByrne's Avatar
JamesByrne JamesByrne is offline
FRC #0360 (The revelution)
JamesByrne is on a distinguished road
We have only inflated one, and it has popped, we found that leak and sealed it with duct tape. Then it has get a few more holes since then. Now we can not find the leak, it is slow so we are going to keep using it for prototyping.
also does anyone know the manufacturers, or place to order new rings that are the same as the competition ones.
thanks for the help
  #40   Spotlight this post!
Unread 21-01-2007, 17:22
technoL's Avatar
technoL technoL is offline
AKA: Noelle Manning
FRC #0108 (SigmaC@T)
technoL has much to be proud oftechnoL has much to be proud oftechnoL has much to be proud oftechnoL has much to be proud oftechnoL has much to be proud oftechnoL has much to be proud oftechnoL has much to be proud oftechnoL has much to be proud of
Send a message via AIM to technoL
I originally thought that it was insane that so many tubes were popped, but then after doing some prototyping, I quickly realized how easily they could be popped (we didn't pop any yet). Even with deburred edges, many corners were really sharp and had to be bent back or rounded off.
Just curious, when your tubes pop, is it loud, or does the air just slowly leak out?
Team Leader | Mechanical | Driver | SOAP | Anything
2008: NJ GM Industrial Design Award, 4th Seed | FL Rockwell Automation Innovation in Control Award, 1st Seed, Semifinalists
2007: FL Finalists | LV Xerox Creativity Award, Quarterfinalists | Mission Mayhem Champs
2006: FL Delphi's Driving Tomorrow's Technology | Curie Quarterfinalists
  #41   Spotlight this post!
Unread 21-01-2007, 17:30
Kim Masi's Avatar
Kim Masi Kim Masi is offline
125 Member, cause Brando says so :p
FRC #0125 (NUTRONS)
Kim Masi has a reputation beyond reputeKim Masi has a reputation beyond reputeKim Masi has a reputation beyond reputeKim Masi has a reputation beyond reputeKim Masi has a reputation beyond reputeKim Masi has a reputation beyond reputeKim Masi has a reputation beyond reputeKim Masi has a reputation beyond reputeKim Masi has a reputation beyond reputeKim Masi has a reputation beyond reputeKim Masi has a reputation beyond repute
Send a message via AIM to Kim Masi
Today when I was testing my prototype, I noticed the tube was starting to deflate a bit....hmm....coincidence?
Bobcat Robotics-Team 177: 2004-2007
The NUTRONS-Team 125: 2008-2009, 2011-2012ish
  #42   Spotlight this post!
Unread 21-01-2007, 17:35
Tube order info is here.
  #43   Spotlight this post!
Unread 21-01-2007, 18:11
Ericgehrken's Avatar
Ericgehrken Ericgehrken is offline
AKA: 3 Teams in 3 Seasons
FRC #0190 (Gompei and the Herd)
Ericgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud of
Send a message via AIM to Ericgehrken Send a message via Yahoo to Ericgehrken
Team 195 put rubber tubing around our manipulator prototypes to enhance grip and protect the tubes, we also ordered more.
Team 3125
GHAMAS FIRST Robotics
Team President and Founder
2010-
2010 Suffield Shakedown Winner Thanks 178 and 177
2010 WPI Regional Rookie All Star
2010 WPI Dean's List Finalist
Team 195 Member 2007-2009
2007 CT Regional Winner Thanks to 1124 and 558
2008 FIRST Presidents Circle Winner
2009 Suffield Shakedown Winner thanks to 126 and 1124
  #44   Spotlight this post!
Unread 21-01-2007, 18:57
JamesByrne's Avatar
when our tubes popped it was just a slow leak, but you can also tear a hole in them. no loud noises were noticed.
Thanks for the order info also.
  #45   Spotlight this post!
Unread 27-01-2007, 14:44
JamesByrne's Avatar
any teams that have ordered the tubes, how long did it take to get them. I have an order # but i do not see any order tracking on the site.
thanks in advance for you help.
Who Has Their vCard Set Up? Joe Matt Chit-Chat 6 09-12-2003 19:43
Who has their own, personal robot? Caleb Fulton General Forum 1 14-04-2003 10:26
Has anyone's schools cancelled their trips? CyberKnights182 Championship Event 37 20-03-2003 12:49
Who has their 2003 robot complete? LBK Rules General Forum 30 09-01-2003 22:48
To all teams who have Pics of their robot on their website.. archiver 2001 7 24-06-2002 00:26
