Go to Post I suppose this would be a bad time to reveal that Q and LookingForward are the same robot person hybrid thing... - EricVanWyk [more]
Unread 17-01-2007, 11:45
NextPerception NextPerception is offline
Sleep-Deprived
AKA: Matt
FRC #0437 (Richardson Robotics)
NextPerception has a spectacular aura aboutNextPerception has a spectacular aura aboutNextPerception has a spectacular aura about
Send a message via AIM to NextPerception
Re: How well does this work on carpet?
Originally Posted by redbarron View Post
Ok , Well, I would come up with something that is going to give you a little traction whether it be something you can activate or something that is permanent because if you are going to be an offensive bot this year I think you are going to be messed with a lot by defensive bots during the matches. Well good luck!! What events are you guys attending?
well usually if you have enough torque (and enough motors) on your two wheel drive coupled to a gyro you can program it in a way to compensate for any outside forces. we have used the two wheel drive platform many times before and what it lacks in stability it makes up for in simplicity and weight.
Lonestar regional
What is this S - L - E - E - P you speak of?
Battlebots - My Robotics Website
Unread 17-01-2007, 12:12
MattB703 MattB703 is offline
AKA: Matt
None #0703 (Team Pheonix)
MattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud of
If you increase the torque to your wheels as you say, you will quickly hit the point where you are traction limited. Assume that we are all working with the same coeficient (sp) of friction on the carpet and that all the bots are at the same weight, a robot that has all of it's weight on driven wheels will out-push a robot that has caster/skids.
Unread 17-01-2007, 12:26
Sleep-Deprived
AKA: Matt
well of course this is going to be true but isnt it also true (correct me if i am wrong, i might be) that when trying to turn with a four wheel drive robot it is not as smooth and quick as when turning as a 2 wheel drive robot. therefore you lose time and it is really hard to get accurate position measurements from your encoders
Unread 17-01-2007, 12:42
GeoffP GeoffP is offline
Engineer
FRC #1222 (Falcons)
GeoffP is an unknown quantity at this point
I like the glides. it is likely just UHMW(PE). On carpet it will wear approximately 1/4" per hour of drive time. it may also get metal shavings imbedded and such imbedded in it from being moved around in the pit -- this will cause friction issues. I've considered the same but have not implemented to date. One nice thing about a static glide is that it will not get wrapped up in a deflated tube on the field like a caser will.
Unread 17-01-2007, 13:00
Matt,
The rules that come into play here are 1) will there be any chance that this would allow metal to come into contact with the floor? 2) will it cause any damage to the carpet.
I think you will find that driving will cause this setup to heat considerably from the friction with the carpet. If the answer to either of the questions above is yes, it will not be allowed. The first is an inspection issue reguiring a close up look at construction and implementation. The second is to be determined by field people. If they think any damage is possible, they may disable your robot and disqualification for repeated offenses is a real consideration for your team. Without close inspection, only you can make a determination at this point.
Unread 17-01-2007, 16:05
Sleep-Deprived
AKA: Matt
Matt,
I don't understand how either of these things could happen as long as a little bit of care is taken in the pits (aka replacing the slides after they wear down to a certain level or when they get metal shavings in them).
Unread 17-01-2007, 16:22
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Originally Posted by squirrel View Post
yeah, I suppose if you're building the ramp, you don't need to worry about getting up on other ramps
Wait 'til the match all 3 teams on an alliance have that mentality...
As for the delrin skids, several teams have used them in the past with success (success being in that they could move and control their robot accurately, not always actually winning matches). That being said, depending on your design, they may or may not offer any advantages or disadvantages over casters or dead omnis.
I know 422 has used skids several times, including 2003, 2004, and 2006 (probably 2005 as well, but I'm not positive). Here's a picture of their 2006 bot (which could make it up the ramp):
Unread 17-01-2007, 16:33
Umm Errr...
Our second year, we had a system with two wheels and two skids like the one in the pic. It had trouble turning and was far too easy to push around. I would highly discourage this configuration.
If however you have two wheels in the middle and 4 skids at each corner of the bot, you have a highly maneuverable bot. We have tried this config with great success. It still suffers from the problem of being easy to rotate but it never presented a problem for us. If you are looking for a 2wd setup i think this would be the way to go. One thing to keep in mind with this config is that the skids must be a elevated a small distance from the height of the wheels. because of this the bot may rock slightly but it is usually negligible. This might not be a good setup for this year because it cannot climb obstacles but it is something to keep in mind.
I think the best overall combination for this yer would be simple 4wd.
1139 Alumni
Unread 17-01-2007, 19:46
Matt,
Just speaking from experience.
Unread 18-01-2007, 10:05
Sleep-Deprived
AKA: Matt
Matt,
I always apreciate anyones input that anyone is willing to give it
out of those who have tried it, is it noticably easier or harder to rotate a delrin skid 2 wheel drive robot vs. a caster 2 wheel drive robot?
Unread 18-01-2007, 11:02
redbarron's Avatar
redbarron redbarron is offline
Mike Barron
AKA: Mike
FRC #1270 (Red Dragons)
redbarron is a splendid one to beholdredbarron is a splendid one to beholdredbarron is a splendid one to beholdredbarron is a splendid one to beholdredbarron is a splendid one to beholdredbarron is a splendid one to beholdredbarron is a splendid one to behold
Though I have no personal experience in the skid area I have driven a robot with casters, and I would say that the two wheel drive setup will not only lack in traction but it will tend to over steer until you practice with the bot a little bit. As far as wheels losing you time while turning, they will not with the right setup. If you have a bot that is wider than it is long than you will not have that problem. On th other hand if your designed bot is longer than it is wide it will tend to "jump" while turning, which is why it is popular for long bots to have > 4 wheels.
The Red Dragons
2005 Buckeye Regional Woodie Flowers Regional Award
2005 Florida Regional Finalist Along with 1251 and 845
2006 Palmetto Regional Engineering Inspiration Award
2007 Florida Regional Judges Award and Regional Winners Along With 1251 and 86
2007 Curie Division Winner with 330 and 910
2008 Florida Regional Team Spirit Award Winners
Unread 20-01-2007, 14:39
Sleep-Deprived
AKA: Matt
wow, this makes a lot of sense now that you said that. does anyone know how to make a robot with theoretical values of, oh i dunno, 21.5 inches between the centers of the front and back wheels and 22 inches between the left and right wheels more stable as a four wheel drive robot (aka no bouncing). i know different types of wheels will matter but is it the coefficient of friction that is important. I know that what we do on our battlebot is use wheels that wear down when lateral force is applied and that is why it stays planted to the floor when doing turns on its 4 wheel drive but thats the only experience i have with 4 wheel drive
Unread 20-01-2007, 21:56
Kyveck Kyveck is offline
FRC #1014 (Dublin Robotics)
Kyveck is an unknown quantity at this point
This is only my teams experience, but we used a drive train with two wheels in the center and four delrin skids on the corners in 2005. I don't have any pictures of the drive train though. The chassis was about 1//2" off of the ground in the center and the skids were raised 1/4". Initially we didn't do that, and had some trouble turning consistenty. It was definately a little difficult to learn to drive becuase it overshot turns so easily, but with a little practice and a lot of feedback control, our driver was able to control it very well.
As you would imagine, whenever we were bumped on a corner, we spun, but this wasn't as much of a disadvantage as we thought it would be. Our drivetrain was so maneuverable that we found it much easier to avoid the other robots, or just get out of the way. If we were bumped and couldn't move, we only spun, and we could spin back into position very quickly.
We replaced the delrin skids whenever they began so show strain or crack marks, about every 5 or six matches. They were very reliable, although they took a lot of time to form carefully with files and a dremel.
In 2006, we mistakenly tried the same drivetrain again, hoping to use powered wheels in the front which were usually off the ground to go up the ramp. The design, like most of our 2006 robot, was a flop. This drive base is inherently bad at ramps. We're trying something new this year, since we still want to be able to go up ramps.
Hope this might be helpful, and if you have any questions, I'd be glad to answer.
Kyle W,
Team 1014
Unread 20-01-2007, 22:03
slickguy2007 slickguy2007 is offline
Copioli is the man!!!
FRC #1403 (Cougar Robotics)
slickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond repute
Send a message via AIM to slickguy2007
Matt,
Team 1403 used plastic sliders in 2004, and I don't recall having any issues with them. You are considerably more maneuverable, but do realize that you will be very easy to push when on the field. You will have slightly less control over the robot, and the driver will have to become used to the changes.
Make sure you have some extra sliders when at the competition because make no mistake, they will wear down. It's always good to have spares.
Team 1403 is Proudly Sponsored By:
How does it work? Ryan O Control System 5 12-03-2006 19:15
How does Nationals work? coldfusion1279 Championship Event 29 30-03-2005 16:47
How Does a Winch Work? Aaron Lussier Technical Discussion 23 20-01-2004 21:14
how does crab drive work? Soukup Technical Discussion 13 25-04-2003 11:31
How does Nationals work?? LunchBox Championship Event 16 18-03-2003 15:55
