Go to Post "Programming is 1% talent and 99% not getting distracted by the Internet." - FRC4ME [more]
Unread 26-10-2006, 08:50
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
Re: Victor Brakes
Originally Posted by sanddrag
Also, the Victors have a Brake/Coast jumper (check the manual) when this jumper is set to Brake and the victor is in the neutral range, it will short the leads of the motor causing a resistance to motion. I believe you can somehow hook the brake coast jumper pins to the robot controller to have selectable braking.
Last year we did that. Then had a button the the joystick so the driver could turn it on or off depending on what they wanted. It worked pretty nice.
Unread 26-10-2006, 09:44
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Re: Victor Brakes
Originally Posted by EricS-Team180
At the Palmetto Regional, we built and successfully tested a wiring harness to switch our drive train Vics between Brake/Coast modes, from the Digital I/O pins of the FRC.
We did this as well after one of our regionals. To prevent the possibility of tipping over, though, we took into account our current speed before engaging the brake (since our position tracking system already was measuring wheel speed). So, when the drivers would put the joysticks in neutral, the brake mode would be engaged once the robot's speed fell below a certain minimum. When in low gear this made our robot much more difficult to push around but avoided the nasty side effect of possibly tipping over if the joysticks were released while running at full speed.
Unread 27-10-2006, 01:04
yongkimleng yongkimleng is offline
deus ex programmeur
AKA: James Yong
FTC #0747
yongkimleng is a jewel in the roughyongkimleng is a jewel in the roughyongkimleng is a jewel in the rough
Send a message via MSN to yongkimleng
Re: Victor Brakes
Hmm, assuming you had the braking feature of the victor hooked up to an IO pin, do you think a pulsed variable breaking system similar to ABS would provide varied levels of braking?
| jamesyong.net |
FVC2007, FTC2008
Unread 27-10-2006, 07:56
Re: Victor Brakes
Originally Posted by Alex698
I don't know if this thought will help, but what about regenerative braking?
I figure(correct me if you see errors), put a single-pole, double throw contact switch between motor, victor and leads to diodes then to a battery. By switching to the leads with diodes the motors are turned into generators by the forward motion of the robot. The diodes are so the battery doesn't back into the motors causing them to run at full.
Alex,
The speed controllers have this feature built in but using a slightly different method. The current supplied by the motor used as a generator is dumped into the transistors in the controller which are acting as a short. The controller is an "H" bridge design. Imagine the "H" with the motor connected from the center of the left vertical to the center of the right vertical. The top and bottom of each vertical is a set of power MOSFETs. The top of both upper vertical bars are connected to the positive battery connector and the bottom of both lower verticals is connected to the negative battery connector. To turn the motor on in one direction, the transistors in the upper left and lower right corners are turned on. To reverse the direction of the motor, the upper right and lower left transistors are turned on. To vary speed, you add a switching waveform to turn the transistors on and off, with speed determined by the ratio of the ON time to OFF. To provide braking, turn ON both of the bottom sets of transistors. Since they are both connected to the negative battery terminal, they are shorted together and that produces a short across the motor.
By varying the pulse that enables the brake you could vary the braking force. As pointed out by others in this thread, the braking is dependent on rotation. The slower the motor is turning, the less current is being developed in the motor, and the less effective the braking becomes.
Unread 27-10-2006, 18:16
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Victor Brakes
It could, but you can do it without pulsing as well. ABS doesn't pulse for the salke of pulsing, it does so to avoid wheel lockup, since only a spinning wheel has directional control. A locked wheel cannot steer. While optimally braked ABS wheels may have a slightly shorter stopping distance on some surfaces, that's not the point of ABS. Instead, it allows you to maintain heavy braking while steering around the potential crash.
Also note that the braking feature of a Victor is not all that powerful, since it is proportional to the motor speed. So, it would not be a good brake.
Don
Unread 29-10-2006, 15:16
gburlison gburlison is offline
gburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to all
Re: Victor Brakes
Originally Posted by xtolbert_gators
How do u hook a victor up so that you can reverse the polarity and cause the motors to stop. Could this cause a type of brake?Could there be a way to include it into the programming so that we can control it from the control board?
In the distant past (2000) we used a globe motor to rotate a set of forklift type arms from a stowed position. As the arms passed vertical, gravity would take over and the arms desended quickly. The globe motor was programmed to move foreward fast and then switched to a slow reverse to counteract the effect of gravity. The arms then continued to rotate forward but the action was less stressful on the mechanical parts. We have since learned that it is better to use springs to balance arms.
Gordon Burlison - Mentor
662/Rocky Mountain Robotics
"Every silver lining's got a Touch of grey - Robert Hunter"
"No sense in being pessimistic, it wouldn't work anyway"
Unread 16-01-2007, 09:03
mluckham's Avatar
mluckham mluckham is offline
FRC #0758 (Sky Robotics)
mluckham will become famous soon enoughmluckham will become famous soon enough
Re: Victor Brakes
When I tried hooking the SIGNAL pin of a Digital Output directly to the centre pin of the Victor Brake/Coast header (2006 Robot Controller) the red HARDWARE LED comes on (Master Reset), on the Robot Controller.
This can't be good
Shouldn't the Relay Outputs on the Robot Controller be used instead???
I have been unable to find a schematic for the Victor controller showing the Brake/Coast jumper.
Unread 16-01-2007, 11:25
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Re: Victor Brakes
Originally Posted by EHaskins View Post
You can't connect a digital output to the victors this year.
<75> Digital outputs of the Robot Controller may be connected directly to brake/coast headers on the speed controllers to permits programmable control of this speed controller function. The brake/coast header on the speed controller may NOT be connected to any other circuit or input.
What? That definitely says that you *can* connect a digital output to a Victor.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 16-01-2007, 11:28
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
Re: Victor Brakes
Sorry, I misread it.
Eric Haskins KC9JVH
Unread 16-01-2007, 13:37
Re: Victor Brakes
This can't be good
In my experience, that red light usually means something is drawing too much current from the RC's +5v output. Are you absolutely certain you got the connection the way you intend it to be? Might your connector be faulty and have a short between signal and ground? Did you perhaps accidentally also connect the +5 from the digital header to the ground (I think it's the Coast end, but I might have that backwards) on the Victor?
Unread 17-01-2007, 14:47
mluckham's Avatar
Re: Victor Brakes
Thanks Alan.
It is either something like that, or a short somehow via the chassis (unlikely - but I will be checking it).
Last night we did try using the Relay Out ports, which seem to work. However the rules state that only the Digital Output can be used.
We modified a standard servo cable so that it has one end normal (at the RC) and the other (at the Victor) routes the white (SIGNAL) wire to the centre conductor. The black and red servo wires are not connected to anything.
This assumes that the PWM cable going to the Victor supplies the ground return - however since I cannot find a schematic for the Victor (or the RC for that matter), I don't know if this is correct. But IFI Robotics FAQ for the Victors does state:
Only connect to the center pin of the 3 pin header on the Victor to control Brake/Coast with a Digital Output pin on the RC unit. A high output will put the Victor in Coast and a Low will put the Victor in Break Mode. Your PWM cable will connect the two grounds together. Be Careful, some of these pins connect directly to the uP and miss wiring or shorting can damaged the uP. We can not comment on whether it is FIRST legal.
Unread 17-01-2007, 19:42
Re: Victor Brakes
mluckham,
I would check the operation of your wiring by removing the brake connection at the Victor and checking it with a VOM. It should not have voltage and should read a short to ground when Low and open circuit when High. You might be one pin off on the RC and feeding +5 volts to the jumper.
Unread 17-01-2007, 20:25
Software Engineer
Rookie Year: 1995
Re: Victor Brakes
If you are referring to the digital output from the RC, it will actually output 5V when high and ground when low. We used it in this configuration last year.
Unread 18-01-2007, 07:35
Re: Victor Brakes
Dave,
I thought this was not an active high. So if it is disconnected from the Victor, there is no pull up.
Unread 18-01-2007, 09:16
Software Engineer
Rookie Year: 1995
Re: Victor Brakes
Dave,
No, it's just a standard digital output on the RC. When set to high it outputs 5V and when low it shorts to ground.
Brakes pakrat Technical Discussion 34 06-05-2006 11:45
pic: Brakes in action! falconmaster Robot Showcase 4 04-02-2006 12:57
Plants in my Victor? Rickertsen2 Electrical 1 23-10-2005 20:47
Victor 884's not behaving the same as Victor 883's programmer1 Programming 13 10-03-2004 21:51
Victor problems quickie25 General Forum 2 18-02-2004 19:51
