Re: EasyC OI Inputs?
Brad,
I tried including the WPILib downloaded from Internet (I did run the setup script that came with that). Following the EasyC tutorial to "Add a Library", we found that the Add Library failed in EasyC due to a pre-existing definition for TwoWheelDrive() in API.H. As a result, there is no Drive() function available. Any suggestions? |
| VEX inputs | Andrew Blair | FIRST Tech Challenge | 22 | 31-05-2006 18:17 |
| Analog Inputs | bush | Programming | 5 | 13-03-2006 17:49 |
| Kickoff easyC workshop integrated into EasyC help file | Dan Larochelle | Programming | 0 | 11-01-2006 06:12 |
| PWM inputs? | ghansel | Control System | 7 | 14-09-2005 17:57 |
| Joystick Inputs | Jatheon4316 | Programming | 12 | 06-02-2005 17:25 |
