access error
Hi,
When I start up Mplab on my school's laptop it load for a little bit and then it displays "access denied" then ends mplab. I'm just wondering if the account I am using have to be an admin because I’m using a 'student account' on it also my os is Window XP professional Last edited by riku84kills : 17-01-2007 at 16:48. |
Re: access error
I know for a fact that you don't have to be an admin to run mplab. Are you sure that it is already installed?
If it is, there is nothing you can do but contact your IT department. |
Re: access error
Yes i'm sure it's installed and when IT check on the admin account it worked
Re: access error
Show them that it doesn't work. They probably set the permissions for the program wrong.
Re: access error
I'll talk to them about that then
Re: access error
that pretty definately sounds like a permission issue. the tech people for my school have mostly lightened up on programs, partly because students kept ignoring the blocks, and mostly let anything run.
| C18 v2.4 -- Syntax error where there is no syntax error | Joel J | Programming | 7 | 12-01-2007 17:27 |
| stupid Array error: Error [1300] stack frame too l | Validius | Programming | 7 | 27-01-2006 10:53 |
| Pictures in MS Access | Lindsey | Scouting | 4 | 19-05-2003 09:08 |
| Wi-Fi access @ Manchester? | MattK | Regional Competitions | 2 | 06-02-2003 23:41 |
