Go to Post why does everyone think im so violent? - Kim Masi [more]
Unread 17-01-2007, 13:38
Kevin Watson's Avatar
La Caņada High School
FRC #2429
2007 CMUcam2 Code
I've updated the camera code to version 2.1 with these minor changes:
Added IFI's new readme.txt file (replacing 2006 version).
Added IFI's new library files (replacing older versions).
Added IFI's new linker script files (replacing older versions).
Added IFI's new FRC_MASTER_V13.BIN file.
Added IFI's new LibReadMe.txt file.
Added IFI's new Using_a_2005_FRC.txt file (replacing older Using_Last_Years_FRC.txt).
Added new hardware-based PWM code (see pwm_readme.txt).
Added CMUCam2_commands.pdf file
Added CMUCam2_data_packets.pdf file
Updated user_routines.c/Default_Routine() with 2007 version.
Added Virtual_Window() function to camera.c/.h.
The code can be found here: http://kevin.org/frc.
-Kevin
Kevin Watson
http://kevin.org
Unread 17-01-2007, 15:34
Re: 2007 CMUcam2 Code
Thanks for the update Kevin; Your work is always appreciated.
The Virtual Window feature looks like it can be really useful this year.
Unread 17-01-2007, 16:17
DanDon's Avatar
DanDon DanDon is offline
ohhh MY god
AKA: Dan Hoizner
FRC #0375 (The Robotic Plague)
DanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond repute
Send a message via ICQ to DanDon Send a message via AIM to DanDon Send a message via MSN to DanDon
Thanks a bunch, Kevin! Your work is always greatly appreciated!!
Unread 17-01-2007, 17:56
FRC #2429
I just realized that I forgot to document the image orientation. If you've mounted the camera in the orientation I suggested, with the power switch down, the image is upside down with pixel 1,1 is located in the lower right corner. If you mounted the camera per the manual, with the power switch up, the image is right side up with pixel 1,1 in the upper left corner. If you mounted the camera any other way, you're on your own <grin>. I'll add this information to the camera FAQ.
-Kevin
Kevin Watson
http://kevin.org
Unread 17-01-2007, 19:58
Eric,1099 Eric,1099 is offline
AKA: Eric
FRC #1099 (The Lions)
Eric,1099 is an unknown quantity at this point
Thanks for the update it will defenetly help with the camera =)
Unread 08-03-2008, 16:18
SL8's Avatar
SL8 SL8 is offline
AKA: Jesus
FRC #0647 (Cyber Wolf Corps)
SL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud of
Send a message via Yahoo to SL8
The code wont compile in MPlab, it says that it can't locate stdio.h?
Unread 10-01-2009, 14:06
Chath Maral's Avatar
Chath Maral Chath Maral is offline
User
AKA: Chathus Marlaclusos Majere
FRC #1785 (Robocats)
Chath Maral is an unknown quantity at this point
Question Re: 2007 CMUcam2 Code
Will this code work for the 2008-2009 competition?
Two things:
Cake==lie;
IF(char pit=="mosh","fun","work");
GO TEAM Robocats!!!
2006 CMUcam2 Code Kevin Watson Programming 81 10-02-2007 20:17
CMUcam2 demo.llb for 2007 Superschill Programming 3 12-01-2007 10:00
2007 CMUCam2 Engineering Workbook SomeoneKnows Programming 1 10-01-2007 16:51
CMUcam2 code for EDU-RC? Calvin Programming 19 27-01-2006 10:41
Where is the CMUcam2 code? Matthew_H Programming 1 14-01-2005 17:49
