Go to Post Learn the ideas, look up the formulas. The other way round will drive you mad - Joe Johnson [more]
Unread 17-01-2007, 13:30
DavidGitz's Avatar
DavidGitz DavidGitz is offline
Lead Technical Advisor
FRC #1208 (MeTool Brigade)
DavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud of
Send a message via AIM to DavidGitz Send a message via MSN to DavidGitz Send a message via Yahoo to DavidGitz
Muffin Fans
This is probably a stupid question, but can you hook two big muffin fans up to the same spike?
Unread 17-01-2007, 13:43
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
Re: Muffin Fans
Well if by hook up, you mean wire, yes I you can wire 2 muffin fans to the power side of the speed controller.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 17-01-2007, 13:50
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Re: Muffin Fans
This is not a stupid question. As it turns out, the manual doesn't say anything about connecting fans to Spikes. The power distribution diagram shows them connected directly to the breaker panel. As such, I suspect that you can connect them to Spikes, but I would only recommend it if you're wanting to turn the fans on and off in software, and only if your load isn't going to come anywhere close to 20A (which would take a lot of fans to do).
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 17-01-2007, 14:37
MikeDubreuil's Avatar
Carpe diem
FRC #0125 (Nu-Trons)
Re: Muffin Fans
If your intent is to cool a motor or speed controller I would connect it directly to the breaker panel. This way if the robot is "disabled" but still has power the components will still remain cooled.
Unread 17-01-2007, 14:51
Ben Piecuch Ben Piecuch is offline
Bengineer
Ben Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond repute
Re: Muffin Fans
Mike, while I agree that keeping motors cooled is important, I believe the direct wiring of fans is not allowed. I believe that fans, non-functional decorations, and the like are all required to be on a spike.
We directly ran a fan (without a spike) back in 2003 to help cool our motors. The inspectors noticed it right away, as the fan was spinning away anytime the robot was turned on, and on the field... We were told to correctly wire before our next match.
BEN
Unread 17-01-2007, 16:27
Carpe diem
Re: Muffin Fans
Ben,
Unfortunately, the 2007 manual does a very poor job addressing muffin fans. The power distribution diagram seems to show them not needing a Spike. The Robot section of the manual only specifies what gauge electrical wire to use with them. Based on the power distribution diagram I would say FIRST is allowing the direct connection to the breaker panel.
As far as your bad experience in 2003... If the muffin fans on the Victors are directly connected to the breaker panel I don't see why other muffin fans shouldn't be. It's unfortunate not every regional can have a lead inspector who's a FIRST veteran and also an electrical engineer.
Unread 17-01-2007, 17:47
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
Re: Muffin Fans
My question is probably stupid, but out of curiosity. Why the heck do they call the small fans Muffin Fans? I think it's a strange name. But I think that you should be able to connect the fans directly to a breaker since we do that with the fans on the Victors. However, it might be illegal to connect two fans to one Spike. Even though the current draw is no where close to burning out the Spike, rule R90 might keep you from doing this. It depends on what FIRST considers the fans to be.
<R98> Relay modules must be protected with a 20A circuit breaker. Multiple devices may be
connected to relay modules if desired (but only one motor may be connected to each relay
module).
I consider Muffin Fans to be part of the "Multiple devices", but you would have to contact FIRST about their interpretation.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 17-01-2007, 20:09
Re: Muffin Fans
In the past, fans were allowed (and expected) to be connected directly to a 20 circuit breaker. I am surprised that an inspector required a Spike for this purpose. The rules specify which loads a Spike may control.
The fans in this size origianally were small and looked like they were made from muffin tins. (unpainted aluminum rotors and housings look just like aluminum cup cake or muffin tins.) It has become common usage for all small, square fans to be called 'muffin" but each manufacturer uses a different term in referring to fans of this type in different sizes.
Be aware that the Chalupa motors (both large and small) are closed devices and blowing cool air over the surface does little to cool the inside. The only conduction to the armature is through the end plates and shaft. The same can be said for virtually all motors in our kit even if they have openings in the case. If your motors are running hot in a two minute match, you should reconsider your design calculations. If they are running hot during long practice sessions, then do whatever you can to keep them cool so you don't have to replace them. Burnt motors stink forever.
BTW, remember you can't modify the motors in any way other than to facilitate mounting or shaft mods. See the robot rules. I know what you are thinking and drilling holes in the Chalupas is illegal and reduces the output power of the motor as it reduces the magnetic field.
Unread 17-02-2007, 13:00
hunter7 hunter7 is offline
AKA: Spence
FRC #2226 (Broncos)
hunter7 is an unknown quantity at this point
Send a message via MSN to hunter7
Re: Muffin Fans
I have been reading through the threads about the muffin fans, but I still can't figure out the best way to connect the large muffin fans. I f anybody can help, it would be appreciated.
Unread 17-02-2007, 16:06
RedHeadRobotics's Avatar
RedHeadRobotics RedHeadRobotics is offline
AKA: Brigid
FRC #2081 (Icarus)
RedHeadRobotics will become famous soon enoughRedHeadRobotics will become famous soon enough
Re: Muffin Fans
Yeah, we hooked our fans together on the same power sources, but it wasn't a spike relay, it won't have that much outcome on the plays anyway
Unread 19-02-2007, 07:25
Re: Muffin Fans
You may connect your fans to a 20 amp circuit breaker on one of the small fuse blocks. You didn't specify how many fans you plan to use, but two are acceptable on a 20 amp breaker. Were you planning on more?
Unread 19-02-2007, 11:43
AKA: Spence
FRC #2226 (Broncos)
Re: Muffin Fans
we will probably use two thanks for the help.
Muffin Fan Wiring Gusman1188 Electrical 3 16-02-2005 07:44
Victor Muffin Fans - Height Clearance? Mr. Lim Electrical 4 28-01-2005 15:32
Questions on Muffin Fans sanddrag Electrical 6 22-01-2005 10:57
Muffin Fans lizs702 Technical Discussion 1 21-02-2004 12:26
Muffin fans .. Mike Hendricks Electrical 4 19-02-2004 19:26
