Go to Post Since this thread doesn't seem to have quite enough numbers yet, here are some more. - William Frost [more]
Unread 17-01-2007, 23:55
AdamHeard's Avatar
Lead Mentor
Keyang Window Motor Gear pitch
We need to add a single stage reduction to the window motor. We calculated a pitch of 12 but we are unsure. We just need a 27 tooth gear to match it.
Unread 18-01-2007, 10:31
mentorDon's Avatar
mentorDon mentorDon is offline
FRC #1764
mentorDon is infamous around these partsmentorDon is infamous around these partsmentorDon is infamous around these partsmentorDon is infamous around these partsmentorDon is infamous around these partsmentorDon is infamous around these partsmentorDon is infamous around these partsmentorDon is infamous around these partsmentorDon is infamous around these partsmentorDon is infamous around these partsmentorDon is infamous around these parts
Re: Keyang Window Motor Gear pitch
Iam also looking for that same info and sent a note to Keyang requesting some help. I am assuming that the gear is metric, so instead of DP they use module. Hopefully I or someone else will come up with something.
Unread 18-01-2007, 13:21
Gabe's Avatar
Gabe Gabe is offline
Pocket Full of Tools
FRC #0604 (Quixilver)
Gabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond repute
FOUND! After a whole lot of searching: http://www.amequipment.com/fhp/801-1...SS_PINIONS.PDF
Also found some of the other motor dimensions in the Kit of Parts, as well as having CAD files on them.
Team site: Q U I X I L V E R
My favorite tool is my imagination; I’m always finding new ways to use it.
Unread 19-01-2007, 12:12
mentorDon's Avatar
FRC #1764
I pulled the gear off the Keyang and it not the same as the amequipment.com. The keyang has a smaller splined end used for the drive instead of the 2 flats. I also was checking on the dimensions of the gear on their site and the numbers don't match to any standard gear, English or metric. The Keyang gear does appear to have a DP of 12. I plotted 3 gears out using Mechanical Desktop, DP12, M2 and M2.25. The DP12 fits very well to the plot. The other two closest metric plots are smaller or larger. The next best thing would be to calculate a center to center distance with the Keyang and another DP12 gear and make a test bar with pins to make sure there is not any binding during rotation.
Denso Window Motor gear profile? Joshua Lynn Inventor 2 23-01-2006 23:57
Mating gear for the window motor? nwbutterfly Motors 2 24-01-2005 10:53
Window Motor Gear?? BBFIRSTCHICK Motors 6 03-02-2003 14:09
Window motor mating gear Gui Cavalcanti Technical Discussion 5 24-01-2003 01:13
DP of Window Motor Gear? archiver 2001 9 23-06-2002 23:24
