Go to Post "Maybe if I stare at it long enough our robot will actually work" - frcguy [more]
Unread 18-01-2007, 00:29
Bharat Nain's Avatar
Re: Team Update #3 Posted
Board and marker or paper and pad.
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
Unread 18-01-2007, 01:09
Cody Carey's Avatar
Cody Carey Cody Carey is offline
AKA: C. Carey
FRC #0306 (CRT)
Cody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond repute
Send a message via AIM to Cody Carey Send a message via Yahoo to Cody Carey
Originally Posted by Joel J. View Post
In the heat of a match, to look away from the field could prove disorienting and costly.. especially when you have to reframe your brain to fiddle with graphic screens, touchpads, or keyboards.. you may forget what you are doing, or miss some important event on the field. I'd say find a better way.
That is crazy talk
One of the members on our team already made a palmpilot app. for scoring calculations, and all he needs to do is press two buttons to place a tube on the virtual rack. The program even tells the score of each alliance, and he is working on a 'Next best Move' algorithm... Which is MUCH easier than a pencil and paper or dry-erase board. There is absolutely no reason to use Paper/Board when you have access to a palm-pilot, Its only purpose is to detract from the usefulness of your coach.
Unread 18-01-2007, 01:15
Nawaid Ladak's Avatar
Nawaid Ladak Nawaid Ladak is offline
The Banana People Are Awsome!
AKA: Nawaid Ladak
FRC #0945 (Team Banana)
Team Role: Tactician
Nawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant future
Send a message via AIM to Nawaid Ladak Send a message via MSN to Nawaid Ladak Send a message via Yahoo to Nawaid Ladak
would there be a way to get a wired connection to the feed on the big screen on a laptop?
that could possibl seeing the other side of the rack
"When you make a mistake, admit it, correct it, and learn from it - immediately."-Stephen Covey
I can still learn from this quote, how about you?
Nawaid Ladak
2003-2006 FRC # 1402: Freedom Force. Scouting
2007 FRC # 1694: RoboWarriors. Mentor
2008-Present FRC # 945: Team Banana. Mentor
Contact me
E-mail: LadakN (at) GMail (dot) com
Twitter / Facebook / Youtube
Unread 18-01-2007, 01:18
Elgin Clock's Avatar
FRC #0237 (Black Magic)
that could possible seeing the other side of the rack
No, just look up.
It can prove to be an advantage sometimes, but most regionals that have big screens have multiple cameras/ camera angles so it will be very ineffective. But it could help.
Unread 18-01-2007, 07:44
Brandon Holley's Avatar
I say if you MUST keep track use a board and marker or a pad and paper like bharat said, otherwise, i think your coach should be plenty capable of devising your "next best move" in his/her head.
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 18-01-2007, 08:44
Ali Ahmed's Avatar
Ali Ahmed Ali Ahmed is offline
FRC #0004 (Team 4 ELEMENT)
Ali Ahmed is a splendid one to beholdAli Ahmed is a splendid one to beholdAli Ahmed is a splendid one to beholdAli Ahmed is a splendid one to beholdAli Ahmed is a splendid one to beholdAli Ahmed is a splendid one to beholdAli Ahmed is a splendid one to behold
I think if you used a program specifically designed for the game, like Cody said, for use on a tablet or Palm would be the best choice. In my opinion, using a normal laptop would be too distracting because a coach needs to keep his mind on the field the ENTIRE time because a lot of things happen at the last second. The next best thing would be pen and paper and draw some sort of diagram that suits your coach the best. I would advise against whiteboards because dry-erase markers dry out fairly quickly and I would hate it if someone was in the middle of a match and their pen drys out. My point is, use a method that allows the coach to keep his/her mind in the match.
Student: Team 22
Mentor: Team 4
Unread 18-01-2007, 08:50
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (EarthQuakers)
I agree. In the month between now and regionals, your coach(es) should have a very good understanding of the game and gameplay. I would trust a dry-erase board, some markers, and a well-prepared coaching staff over an electronic device prone to malfunction (battery life, interference, programming error, crazy electrons bumping into each other, etc.). I may be an old-timer at 27, but I think there's enough technology on the field and in the drivers stations.
Also, there are no rules about drivers/coaches handling non-electronic devices. A picture's worth a thousand words, and if the drivers can see a pictoral representation of the rack, that could be much better than a coach shouting directions in their ears (not to mention all the noise that happens during gameplay).
Hi!
Unread 18-01-2007, 08:54
Rick's Avatar
Rick Rick is offline
Ready to STRIKE!
AKA: Rick Blight
FRC #0078 (AIR STRIKE)
Rick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond repute
Real coaches dont use "strategy assistants" during matches.
Like Aquidneck Island Robotics on Facebook!
Unread 18-01-2007, 09:14
camtunkpa camtunkpa is offline
it's like shooting fish in a barrel
AKA: Cliff Mock
FRC #0222 (Tigertrons)
camtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond repute
All the devices people are mentioning on here are great tools for planning strategy, but coming from lots of experience on the field this game will be too fast paced to take your eyes off for entering ringer locations into any device. I'm not saying that the listed devices definately won't help. I'm just saying with one coach per team it will be very difficult to record ringer placement, monitor ringer placement you have recorded and coach the drivers all at the same time in a 2 minute and 15 second time period. That's just my $.02. I'm not trying to discourage anyone because I've seen some great devices for planning strategy and keeping track of the score.
"Engineering is making the impossible happen"
"We are here to create, not merely survive" - unknown fortune cookie
"If you don't push the envelope you're just spinning your wheels"
Unread 18-01-2007, 11:13
Wetzel's Avatar
Wetzel Wetzel is offline
DC Robotics
FRC #2914 (Tiger Pride)
Wetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond repute
Send a message via AIM to Wetzel
Originally Posted by Greg Marra View Post
I agree that a tablet is the best option for keeping track of real time scores. However, I think that having a tablet is amazingly expensive, and most teams will have to settle for some sort of paper-based solution instead.
My roomate got a convertable (a laptop that the screen revereses to make a tablet) for $1400 with decent power. They are getting surprisingly cheap.
Originally Posted by Elgin Clock View Post
No, just look up.
Elgin, some regionals have the screen behind one of the player stations, which makes it real inconveinent for one alliance to use. Things are only mostly even between regionals.
Wetzel
Viva Olancho!
Unread 18-01-2007, 18:18
Nick M. Nick M. is offline
I Hate C Programming!!!
FRC #0306 (Corry Robotics)
Nick M. will become famous soon enoughNick M. will become famous soon enough
I am currently writing a scoring program that will run on a PDA with a touch-screen. Simply choose what color alliance you’re on, and touch a rack position where a tube has been placed. As you select tube placements, it will automatically calculate the score. It also has dynamic scoring based on spoiler (black) and the opposing alliance tube placements.
Unread 21-01-2007, 19:41
Barry Bonzack's Avatar
Barry Bonzack Barry Bonzack is offline
Impossible to rain on my parade.
FRC #1902 (Exploding Bacon)
Barry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond repute
Send a message via AIM to Barry Bonzack
There is a thread dedicated to using scoring aids; further discussion about that should probably continue there. This thread is about the Update 3.
Will you be using a scoring aid?
That being said, I am interested in seeing pictures of user made scoring aids or palm programs.
Chair of Florida FIRST Alumni
Orlando Regional Planning Committee
FIRST Tech Challenge Florida Leadership Team
Program Planner on the Orion Spacecraft at the Kennedy Space Center
Twitter: @FL_FIRST_Alumni
Events I'm Emceeing/Game Announcing:
1/10/2015 FTC Jacksonville League Championship
1/11/2015 FTC Central FL Tesla League Championship
1/17/2015 FTC South Florida League Championship
1/24/2015 FTC Tampa/St. Pete League Championship
2/7/2015 FLL Orlando Regional
2/14/2015 FTC State Championship
2/26-2/28/15 FRC South Florida Regional
3/8/2015 FLL State Championship
3/12-3/14/15 FRC Orlando Regional
4/22-4/25/15 FIRST World Championship Event - FTC Franklin Field
Team Update #2 Posted Billfred Rules/Strategy 4 15-01-2007 04:00
Team Update #2 is Posted geo General Forum 1 16-01-2004 10:56
Team Update 8 Posted! Harrison General Forum 1 30-01-2003 08:08
Team update #6 posted Joe Ross General Forum 6 22-01-2003 10:14
