Go to Post For what it's worth, while they may or may not be legal as safety glasses, Steampunk goggles are perfectly legal as forehead protectors. - Nuttyman54 [more]
Unread 17-01-2007, 16:10
itsme itsme is offline
FRC #2217 (FOMH)
itsme is an unknown quantity at this point
Problem with unwired RC-OI
My team has already connected the RC and the OI with the tether cable and everything worked fine. Now we connected the radio connections and removed the red tether cable, but it didn't work. The OI won't get on (yes, the power is on)
Unread 17-01-2007, 16:37
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: Problem with unwired RC-OI
For clarification, a checklist:
1. You set your team number on the Operator Interface and tethered it to the Robot Controller, then had the robot on and were running it around.
2. You have the Robot Controller radio connected to the radio port on the Robot Controller with a black cable.
3. You have the Operator Interface radio connected to the radio port on the Operator Interface with a black cable.
4. You have the provided AC adapter plugged into a 120V wall socket and the Power port on the Operator Interface.
5. The robot is turned on. (I know it's obvious, but you'd be surprised.)
6. You haven't changed the team number on your Operator Interface after it was tethered.
If all those things are true and the OI doesn't have any lights on it, then it might be something you'll need to talk to IFI about.
EDIT: HIGHLY important. Israel appears to have a 220V power system. The adapter supplied to you in the kit is almost certainly an adapter for 110-120V. Chances are, trying to use this adapter will either explode the adapter or explode your OI, or possibly both. I strong recommend you get in contact with IFI to find a compatible AC adapter that is designed for 220V. I also recommend you hold on to your 120V adapter, but brightly label it. You may need it if you bring your robot to the States.
Unread 18-01-2007, 00:04
FRC #2217 (FOMH)
We did that...
Well, we know that we can't use the adapter given to us, so we are currently using power supply (12 volt).
I did everything that you said.. I'll try again, maybe realy the power was of or something.
Unread 18-01-2007, 01:07
mtaman02's Avatar
mtaman02 mtaman02 is offline
FIRST's Spare, Queuer & Tech guy =)
AKA: Mike M. / Mouse =)
no team (FRC Volunteer)
mtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant future
Send a message via AIM to mtaman02 Send a message via Yahoo to mtaman02
Originally Posted by itsme View Post
We did that...
the OI is rated for 9vdc only anything more may blow the OI
Past FIRST Robotics Events that I proudly volunteered at:
FLL: NY State Competition '03
FRC: NYC Remote Kickoff '04 & NYC Regionals '04-'15 ,'10-'13 & NJ Regionals '06-'10, Finger Lakes Regional '09 & SBPLI Regional '08-'15 and the World Championship in '05 (Galileo Field) '07 (Newton Field) '09 (Practice Fields Attendant / FTA(A)), CeBIT Convention in '04 & NextFEST in '06 both held @ the Javitts Center, Monty Madness '07-'10, Panda-monium '08, B.Eruption '08 & '09, Ramp Riot '08, PARC '09 & '10, BR^2 '09 & Wol. Inv. '09 -'15
2015 FIRST Robotics Off Season Events that I hope to volunteer at:
Where is Wolcott Invitational
2015 FIRST Robotics Events that I will be volunteering at:
SBPLI Reg. & Championships
Volunteer Resume:
Alt & Lead Team Queuer, Field Repair/Reset, Field Setup/Breakdown, Spare Parts Attendant, Field Power Controller/Score Keeper, Co-Emcee & Official Scorer, Control System Advisor, FIRST Tech Advisor Assistant & recently Practice Field Attendant.
Unread 18-01-2007, 01:26
Daniel367's Avatar
Daniel367 Daniel367 is offline
Dan
AKA: Daniel Rahamim
FRC #0008 (Paly Robotics)
Daniel367 is on a distinguished road
Send a message via AIM to Daniel367
i thought the PS that came with the OI was an 18.something V power supply?
I could be wrong though.
Unread 18-01-2007, 01:30
mtaman02's Avatar
Nope its a 9vdc Power Supply for the OI and a 12vdc Battery for the RC and I think its 7.5vdc for the back-up battery
Volunteer Resume:
Unread 18-01-2007, 01:33
Daniel367's Avatar
Dan
AKA: Daniel Rahamim
7.2V (ifi website)
Unread 18-01-2007, 01:37
mtaman02's Avatar
I was close. You could use a 12vdc PS on the OI BUT just be prepared to by a new one. I plugged a 12vdc PS into the OI the other day and it did work but it makes a high frequency whistling sound needless to say I checked the PS and found out it was the wrong voltage for the OI and unplugged it right away. I had the OI on for maybe about a minute or so - Luckily no damage was done to the OI.
Volunteer Resume:
Unread 18-01-2007, 07:46
Gamer930's Avatar
Gamer930 Gamer930 is offline
Team 930 and 171 Alumni
AKA: Justin
Gamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to behold
Unsure what type of connector you are using off the PS but remember you need a center positive.
We tried once using a universal connector that we got at Wal-Mart because we forgot ours in a crunch. . . Come to find out it was outside positive and the OI wouldn't turn on or anything. . . . Did no damage to the OI.
2010 to Present, Scorekeeper/Field Power Volunteer for FRC/FTC/FLL
2005 - 2010, Team 171 College Mentor
2002 - 2005, Team 930 Student
Unread 18-01-2007, 08:09
itsme,
There is a polarity issue on the power input connector on the OI. Be sure the power adapter you use has the correct wiring. If it works with the tether, then it should work with the power adapter.
problem with .c files incognito_NICK Programming 5 31-01-2005 13:19
problem with navigate.c magical hands Programming 2 13-02-2004 22:54
Problem with communicating with STAMP through serial port Skabana159 Technical Discussion 2 06-02-2003 21:10
My Problem With Chiefdelphi... Joe Matt CD Forum Support 25 08-12-2002 12:58
Problem with OI / RC Jay Lundy Technical Discussion 2 29-03-2002 23:07
