Re: Problem with unwired RC-OI
There is a polarity issue on the power input connector on the OI. Be sure the power adapter you use has the correct wiring. If it works with the tether, then it should work with the power adapter. |
| problem with .c files | incognito_NICK | Programming | 5 | 31-01-2005 13:19 |
| problem with navigate.c | magical hands | Programming | 2 | 13-02-2004 22:54 |
| Problem with communicating with STAMP through serial port | Skabana159 | Technical Discussion | 2 | 06-02-2003 21:10 |
| My Problem With Chiefdelphi... | Joe Matt | CD Forum Support | 25 | 08-12-2002 12:58 |
| Problem with OI / RC | Jay Lundy | Technical Discussion | 2 | 29-03-2002 23:07 |
