Go to Post ..."A bad day at college is always better then a good day at work" - KyleGilbert45 [more]
Unread 18-01-2007, 09:12
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
Re: Using a USB to 15 pin converter
Long answer: There's a reason the Chicklet is so expensive, it's effectively a small computer. USB uses bursts of serial data carrying the values of the gamepad/joysticks axes and buttons, much like the OI sends to the RC. You can't simply convert the connection, you need a smart chip to interpret the serial stream, there is no "analog" data for the OI to read until the Chicklet generates it from the data coming in from the controller.
Short answer: The Chicklet is your only option for USB controllers this year unless you gut them and re-wire them.
Matt Krass
Voltage-to-resistance converter for using any joysticks ConKbot of Doom Control System 14 15-07-2006 12:13
BAFO USB to 9 Pin Adapter Skiguy523 Programming 2 29-01-2005 01:49
USB to Serial converter for controller Ryan Collings Programming 10 22-01-2005 13:14
USB to 9-pin serial port (HELP!!) n00b Technical Discussion 10 01-02-2004 21:25
using set screw or dowel pin/pin to hold on drill motor coupler thinggy Travis Covington Motors 1 04-02-2002 03:02
