Go to Post It's not a problem, it's a feature! - smokescreen [more]
Unread 15-01-2007, 07:48
Re: Crab drive without a pot
There are a couple of things that teams can do to use a standard 270 degree pot without breaking it. You can easily use a couple of nylon gears (from Small Parts) to couple the pot to your steering mechanism. You can mechanically limit the travel of your crab so that you stop turning before the pot is broken or you can spend some money and buy a continuous pot.
But dpick, as you can see, no one is telling you to do crab without a pot. There is no way for the robot or the driver to know that the crab system has actually gone where the driver has told it to go or for the software to get it back to driving forward.
Unread 15-01-2007, 10:17
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Why not an absolute encoder? (Like this.)
Unread 17-01-2007, 18:40
fledman fledman is offline
AKA: David Feldman
FRC #1525
fledman is an unknown quantity at this point
Is there any functional difference between a pot and an absolute encoder? (I realize that they are different internally.) Why would someone use one over the other (for low speed applications, eg arms, steering)? Is there a reason teams use encoders that give counts instead of absolute encoders on higher speed applications (wheels)?
Unread 17-01-2007, 19:43
B.Johnston B.Johnston is offline
AKA: Bruce Johnston
B.Johnston will become famous soon enough
Yes, the most significant advantage of this encoder is its free rotating shaft.
Plus it costs about the same as a 10 turn precision pot without the potential for value shifting due to vibration or temperature.
One possible reason to use raw quadrature input is to "count" beyond 1 revolution.
The source of this encoder USDigital has several other devices which can emulate pots by actively providing an analog voltage "incremented or decremented" by a quadrature pulse train (edac2) or an analog voltage feedback of the rate of pulses per second(etach2).
Additionally these devices incorporate the ability to self calibrate via a precise index marker pulse.
By selecting your counts per revolution carefully you can tailor the precision of the output to the neccessary resolution.
Unread 17-01-2007, 22:42
DonRotolo's Avatar
Back to humble
FRC #0832
Don't be afraid of potentiometers. Do use the correct value (I think 2.5k is the best match for the RC - or is it 5k??). Linear taper, as eshteyn noted, is what you need.
Connect a pot to the RC - one end to red, the other end to black, and the center to white, hooked up to an analog input - and get a feel for what kind of information you can get from it. You will see values in the range of 0 to 1023, varying linearly (linear taper, remember?) with rotational position.
Pots are available with 360 degree rotation, but these often have a small dead zone, where no signal is available.
Absolute encoders are great, can get costly (Mouser 594-601-1045 is one example, $60, get the connector wire too), but feature true 360 rotation, no dead zone, reliability and precision.
Multi-turn post can be a good solution, but you can eventually run out of turns if you don't enforce some kind of discipline on which way the wheels turn.
Running without pots (or similar) will lead to astoundingly poor performance.
Don
Unread 18-01-2007, 07:50
Don
100k wired as shown in the RC manual.
Unread 18-01-2007, 09:15
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
100K is for the OI. The RC manual shows 10K in use, but says anything between 250 ohm and 100K can be used.
Unread 18-01-2007, 09:17
From the 2007 RC Reference Guide...
9. Analog Inputs
The analog inputs on the Robot Controller can be used to measure various conditions on the robot and
trigger automatic responses by the control program. There are 16 analog inputs available on the
ANALOG INPUTS connectors on the Full-Size Robot Controller.
Any sensor which outputs a variable 0-5V signal may be read with 10-bit resolution on these inputs.
Popular devices include potentiometers and gyro (yaw rate) sensors. Potentiometers should be wired per
the diagram below when connecting to the Analog Inputs. Always use 100kΩ potentiometers. For
wiring yaw rate sensors, refer to the sensor manufacturer’s data sheet.
Unread 18-01-2007, 09:21
Software Engineer
Rookie Year: 1995
9. Analog Inputs
The 2007 RC Reference Guide (dated 6-13-2006, and I just downloaded it from IFI) I have open says:
Originally Posted by 2007 RC Reference Guide
9. Analog Inputs
The analog inputs on the Robot Controller can be used to measure various conditions on the robot and trigger automatic responses by the control program. There are 16 analog inputs available on the ANALOG INPUTS connectors on the Full-Size Robot Controller. Any sensor which outputs a variable 0-5V signal may be read with 10-bit resolution on these inputs.
Popular devices include potentiometers and gyro (yaw rate) sensors. Potentiometers should be wired per the diagram below when connecting to the Analog Inputs. Use 250Ω – 100KΩ potentiometers. For wiring yaw rate sensors, refer to the sensor manufacturer’s data sheet.
And the diagram below it shows a 10K pot being used.
Are you looking at an old version?
Unread 18-01-2007, 09:25
Yes you're right, the version I had downloaded earlier this month was dated in February sometime and that was what I quoted. I just downloaded the newest version and it contains the above quote. Old is deleted.
Unread 19-01-2007, 20:05
AKA: Bruce Johnston
I'm not sure if everyones missed the link that tristan posted, but, there's everything to "fear" about pots.
Even the best Linear pots exhibit some degree of non linearity especially near the outer portions of their range.
They suffer from thermal drift to some degree.
Mechanical forces on the shaft (not true to the rotational axis) affect the value at the wiper.
Shocks to the housing can shift values even when the pot isn't being rotated.
And last but not least exceeding the stop at the end of travel usually causes bad things to happen.
Why not revisit Tristans post and have another look at an "active" system with the potential to eliminate most of these problems.
I know that to a team, every Niagara First Team 1680, 1503 and 1114 would caution that if you can find a device for as close to the price of a precision pot without the drawbacks. Try it. 1503 and 1680 won't be going back to pots again if they can help it.
Unread 20-01-2007, 00:51
Bharat Nain's Avatar
We have used pots successfully for many years. Ofcourse we have to recalibrate them from time to time, but as long as you make sure you dont break(mechanically, and wire them correctly, and use the correct potentiometer) them, they work wonderfully(atleast for us).
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
pic: Crab Drive Joe_Widen Extra Discussion 3 23-04-2006 15:49
Crab Drive Joe_Widen Technical Discussion 9 21-04-2006 21:50
Crab drive question Tazlikesrobots Technical Discussion 13 31-07-2005 20:51
EduRobot Crab Drive OneAngryDaisy Robotics Education and Curriculum 8 03-10-2003 10:06
Crab Drive Collin Fultz Technical Discussion 3 04-09-2002 16:35
