Go to Post Winning medals and awards, being on TV or in a magazine while cool doesn’t even begin to compare to the relationships I’ve developed working with a bunch of great students. - ebarker [more]
Unread 18-01-2007, 09:59
Rob Colatutto's Avatar
Rob Colatutto Rob Colatutto is offline
Roboticsrob
FTC #10092 (Green.Griffins;)
Rob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to behold
Question Weight Reduction
While in the computer lab at midnight last night, thinking about how much weight fasteners will add to our robot, I figured it might be a good resource for some teams if we made a sort of "Weight reduction - How to do it" thread.
So if your in the mood to share, feel free to tell us all how you make your robot lighter. Anything from the smallest task of say, making your spacers have as thin a wall as possible, up to say, removing an arm.
Follow me on twitter @roboticsrob and my FTC team @griffins10092
Unread 18-01-2007, 10:01
Adam Richards's Avatar
Adam Richards Adam Richards is offline
I'm baaaaaaack.
FRC #1902 (Exploding Bacon)
Adam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond repute
Send a message via AIM to Adam Richards
Re: Weight Reduction
I've said it before:
Originally Posted by Adam Richards View Post
Step 1: Get Drill
Step 2: Insert 1/2"-1" bit into drill
Step 3: Drill Those Speed Holes!
This was already discussed here: http://www.chiefdelphi.com/forums/sh...ad.php?t=44155
Unread 18-01-2007, 10:05
in between teams
AKA: Luke Van Oort
Replacing steel bolts with aluminum versions. Very light and still strong enough for most purposes.
Team 1219: 2009 - Mentor
Unread 18-01-2007, 10:16
Billfred's Avatar
Billfred Billfred is offline
1618 hasn't gotten into the weight-reduction business (their past two robots have been far underweight, and this year's is still obviously in the pipeline), but I do remember a few tricks from 1293:
-Switching out our 1/8" aluminum hopper for a thinner stainless one
-Hacking off most of our tower (not because we were overweight, but because the weight was high up)
-Gratuitous use of the slugbuster (a hydraulic device for poking large circular holes in sheetmetal)
-Cutting the team numbers into our covers, causing us to lose weight for a required feature rather than gain it
-Rivets, rivets, and more rivets (and rivet nuts for places we needed to get in and out of)
-Running as short a wire as we could safely use (something I'm sure Al Skierkiewicz is happy to see as well)
-Thin-walled metal spacers on our Kitbot axles
-Going from six polycord runs on our ball pickup to four (and ultimately zero with the top getting chopped, but that's a whole other ball of wax)
-Plastic belt pulleys instead of metal
-Plain paper and Velcro for attaching school and sponsor information. (It works, I swear!)
Unread 18-01-2007, 10:26
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Replace Aluminum bolts with Nylon ones.
Even better for some applications.
You don't really need a steel or aluminum bolt holding down the RC now do you?
Use 2 screws on muffin fans instead of all 4 corners.
TRIM THOSE WIRES!!! You don't need 1' of cable going from your battery to your quick connect if the battery is right next to the breaker.
ONLY SWISS CHEESE THE BOT IN WEEK 6!!!!!!
None of this "speed holes in week 1" nonsense!!!!
You can't put material back as easily as you can remove it if you need to mount anything, even something as simple as a potentiometer, limit switch, or a sensor of some kind.
Unread 18-01-2007, 10:36
Jonathan Norris Jonathan Norris is offline
Jno
FRC #0610 (Crescent Robotics)
Jonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond repute
Rivets, we were able to take almost 5 pounds of bolts off our robot last year by replacing them with rivets. Also choose your materials wisely, sheet metal is your friend, too much extruded aluminum is not. Even if you are not at the cheesing stage yet with your build, plan our where you can reduce weight if you have to, and expect to have to take apart your robot a couple of times throughout the season (keep welding till you know your weight).
Co-Founder of Taplytics.com
2013 World Champions (1241, 1477, 610)
Crescent Robotics Team 610 Mentor
K-Botics Team 2809 Founding Mentor ('09-'11)
Queen's University Mechanical Engineering, Applied Science '11
Crescent Robotics Team 610 Alumni
Unread 18-01-2007, 10:50
Joel J's Avatar
Joel J Joel J is offline
do you..
Corrugated lexan (green house material) instead of lexan for side shields, and coverings..
Joel Johnson
RAGE (173) Alumni, 1999-2003
Unread 18-01-2007, 10:55
Brandon Holley's Avatar
Heres a fun story from the Nu-Tron from around 4-5 years ago:
They brought the bot up to inspection and placed it on the scale. The scale read 130.0....130.1....130.0....130.1 (for all you youngens back in the day the limit was 130 pounds WITH a battery). Eventually the scale stopped at 130.1. One of the team members decided to check the air tanks, they were full so he released all the air pressure...the scale dropped to 130.0 and they were good to go. Moral of the story: EMPTY YOUR AIR TANKS!
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 18-01-2007, 10:56
Robo_Coyote's Avatar
Robo_Coyote Robo_Coyote is offline
Cheap_Shot
AKA: Chris Chandler
FRC #1323 (MadTown Robotics )
Robo_Coyote is a splendid one to beholdRobo_Coyote is a splendid one to beholdRobo_Coyote is a splendid one to beholdRobo_Coyote is a splendid one to beholdRobo_Coyote is a splendid one to beholdRobo_Coyote is a splendid one to behold
This year Team 1323 was able to cut 11 lbs of our basic chassis by welding our frame together it was a task our team was shooting for since the end of last year when we invested in a tig welder.
2005- Uc Davis Spirit Award
2006 nationals second highest score thanks to 233, and 1184
We need a longer highlight list....... sigh
"To invent all you need is imagination and a pile of junk" - Thomas Edison
Unread 18-01-2007, 11:31
Ben Piecuch Ben Piecuch is offline
Bengineer
Ben Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond repute
We've used some fairly large bolts in the past to mount various mechanisms, wheels, etc... A 1/2" bolt is typically overkill in terms of strength, but the diameter has been our requirement. So, we've actually drilled out the center of our larger bolts in order to reduce the weight of this large hardware, and it definitely works.
YMMV, good luck.
BEN
Unread 18-01-2007, 12:26
MattB703 MattB703 is offline
AKA: Matt
None #0703 (Team Pheonix)
MattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud of
We have a saying that we use over and over when looking for weight reduction;
Steel parts first, then alluminum, then plastic.
Cutting/drilling holes in a 1/8" lexan side plate for instance is pretty inaffectual. On the other hand, putting a gear or sprocket in a lath and taking some "meat" off it can pay big dividends.
Unread 18-01-2007, 13:16
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
Our team is working hard to actually predict weight of the final design in order to avoid the problem we had last year. Every piece is being designed with speedholes included, so hopefully when it all goes together it will be underwieght.
In case anything is heavy and still has room for holes at the end of the build, we have a Rotex punch which can be used to speed up the cheesing process.
Unread 18-01-2007, 13:28
Brian C's Avatar
Brian C Brian C is offline
Doer of Whatever
AKA: Brian Cholerton
FRC #1468 (J-Birds)
Brian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant future
Well one of our experiences last year was that we were 12oz overweight at tech for the regional. This was already AFTER drilling and trimming the snot out of the robot before we shipped.
So one of the engineering mentors goes around the robot with 2 of the students and tells them which bolts, nuts and washers to remove. After about a 1/2 hour he stood there with 2 hands FULL of "extraneous, unnecessary hardware" that weighed.....you guessed it - 3/4 of a pound. Much of it came fro the KOP frame joints where 1 fastener was just fine due to our design last year.
Assign a couple of team members to monitor the weight of everything you put on a robot. It will help you during week 6. Remember, everything weighs something (even paint).
2017 Season; Game Announcer at
SBPLI Long Island Regional
robotguru1717's Avatar
robotguru1717 robotguru1717 is offline
AKA: Martin Cacan
FRC #1717 (D'Penguineers)
robotguru1717 will become famous soon enoughrobotguru1717 will become famous soon enough
This year it already looks like we are having weight issues so we have been taking the weight of EVERYTHING (components, motors, spikes) and adding them into an excel file. Then for things that arn't built yet like the chassis, wheels and stuff we have done extrememly acurate Solidwork models of them and these give us the weight.
#1 tip to avoid overweight issues:
Plan/design everything first then build. dont design as you go.
Quote of 2007: "That nub looks cattywampus" -Amir Abo-Shaeer
(fyi there were about 50 nubs on the robot)
Team 1717: D'Penguineers
2008: LA-Regional Winner
2008: SD-Regional Winner
2008: SD-Delphi "Driving Tomorrow's Technology" Award
2007: LA-Semi Finalist
2007: SD-Finalist
2007: SD-Imagery Award
2006: Phoenix Semi-Finalist
2006: Phoenix Regional-Rookie Inspiration Award
2006: LA-Rookie All-Star Award
Unread 18-01-2007, 13:43
RichardJames's Avatar
RichardJames RichardJames is offline
AKA: Eric
FRC #0296 (Northern Knights (or Northern Ninjas))
RichardJames will become famous soon enough
weight relieve every sprocket, pulley, gear, and gear box that you can. weight relieve all aluminium and lexan plates. These are some of the densest things on most people`s bots. also, make sure you are using gears belts or chain that is appropriate (not overkill), as jumping up to the next strongest category can mean doubling the weight of these components.
To design a good mechanical system, you have to design something so simple it almost doesn't work, then increase the complexity until it does.
Quoted picture size reduction sanddrag CD Forum Support 1 25-07-2006 19:05
Weight Reduction Help. Mirza95vx Technical Discussion 11 07-02-2005 16:03
Gear reduction question dmellich Motors 6 25-01-2003 08:54
Speed Reduction for Drill Motors Ian W. Programming 5 18-01-2003 23:57
Drill Motor Gearbox Reduction Ratios archiver 2000 3 23-06-2002 23:05
