Go to Post DEKA is right next to the river, and when i got there this morning they wouldn't let us into the building, but apparently there is and standing water on the first floor. The ironic thing is that i work on the water project and we can't deal with a bit of water on the floor - Greg Needel [more]
Unread 18-01-2007, 10:26
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Re: Weight Reduction
Originally Posted by lukevanoort View Post
Replacing steel bolts with aluminum versions. Very light and still strong enough for most purposes.
Replace Aluminum bolts with Nylon ones.
Even better for some applications.
You don't really need a steel or aluminum bolt holding down the RC now do you?
Use 2 screws on muffin fans instead of all 4 corners.
TRIM THOSE WIRES!!! You don't need 1' of cable going from your battery to your quick connect if the battery is right next to the breaker.
ONLY SWISS CHEESE THE BOT IN WEEK 6!!!!!!
None of this "speed holes in week 1" nonsense!!!!
You can't put material back as easily as you can remove it if you need to mount anything, even something as simple as a potentiometer, limit switch, or a sensor of some kind.
Unread 18-01-2007, 10:36
Jonathan Norris Jonathan Norris is offline
Jno
FRC #0610 (Crescent Robotics)
Jonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond repute
Rivets, we were able to take almost 5 pounds of bolts off our robot last year by replacing them with rivets. Also choose your materials wisely, sheet metal is your friend, too much extruded aluminum is not. Even if you are not at the cheesing stage yet with your build, plan our where you can reduce weight if you have to, and expect to have to take apart your robot a couple of times throughout the season (keep welding till you know your weight).
Co-Founder of Taplytics.com
2013 World Champions (1241, 1477, 610)
Crescent Robotics Team 610 Mentor
K-Botics Team 2809 Founding Mentor ('09-'11)
Queen's University Mechanical Engineering, Applied Science '11
Crescent Robotics Team 610 Alumni
Unread 18-01-2007, 10:50
Joel J's Avatar
Joel J Joel J is offline
do you..
Corrugated lexan (green house material) instead of lexan for side shields, and coverings..
Joel Johnson
RAGE (173) Alumni, 1999-2003
Unread 18-01-2007, 10:55
Brandon Holley's Avatar
Heres a fun story from the Nu-Tron from around 4-5 years ago:
They brought the bot up to inspection and placed it on the scale. The scale read 130.0....130.1....130.0....130.1 (for all you youngens back in the day the limit was 130 pounds WITH a battery). Eventually the scale stopped at 130.1. One of the team members decided to check the air tanks, they were full so he released all the air pressure...the scale dropped to 130.0 and they were good to go. Moral of the story: EMPTY YOUR AIR TANKS!
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 18-01-2007, 10:56
Robo_Coyote's Avatar
Robo_Coyote Robo_Coyote is offline
Cheap_Shot
AKA: Chris Chandler
FRC #1323 (MadTown Robotics )
Robo_Coyote is a splendid one to beholdRobo_Coyote is a splendid one to beholdRobo_Coyote is a splendid one to beholdRobo_Coyote is a splendid one to beholdRobo_Coyote is a splendid one to beholdRobo_Coyote is a splendid one to behold
This year Team 1323 was able to cut 11 lbs of our basic chassis by welding our frame together it was a task our team was shooting for since the end of last year when we invested in a tig welder.
2005- Uc Davis Spirit Award
2006 nationals second highest score thanks to 233, and 1184
We need a longer highlight list....... sigh
"To invent all you need is imagination and a pile of junk" - Thomas Edison
Unread 18-01-2007, 11:31
Ben Piecuch Ben Piecuch is offline
Bengineer
Ben Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond repute
We've used some fairly large bolts in the past to mount various mechanisms, wheels, etc... A 1/2" bolt is typically overkill in terms of strength, but the diameter has been our requirement. So, we've actually drilled out the center of our larger bolts in order to reduce the weight of this large hardware, and it definitely works.
YMMV, good luck.
BEN
Unread 18-01-2007, 12:26
MattB703 MattB703 is offline
AKA: Matt
None #0703 (Team Pheonix)
MattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud of
We have a saying that we use over and over when looking for weight reduction;
Steel parts first, then alluminum, then plastic.
Cutting/drilling holes in a 1/8" lexan side plate for instance is pretty inaffectual. On the other hand, putting a gear or sprocket in a lath and taking some "meat" off it can pay big dividends.
Unread 18-01-2007, 13:16
s_forbes's Avatar
s_forbes s_forbes is online now
anonymous internet person
FRC #0842 (Falcon Robotics)
Our team is working hard to actually predict weight of the final design in order to avoid the problem we had last year. Every piece is being designed with speedholes included, so hopefully when it all goes together it will be underwieght.
In case anything is heavy and still has room for holes at the end of the build, we have a Rotex punch which can be used to speed up the cheesing process.
Unread 18-01-2007, 13:28
robotguru1717's Avatar
robotguru1717 robotguru1717 is offline
AKA: Martin Cacan
FRC #1717 (D'Penguineers)
robotguru1717 will become famous soon enoughrobotguru1717 will become famous soon enough
This year it already looks like we are having weight issues so we have been taking the weight of EVERYTHING (components, motors, spikes) and adding them into an excel file. Then for things that arn't built yet like the chassis, wheels and stuff we have done extrememly acurate Solidwork models of them and these give us the weight.
#1 tip to avoid overweight issues:
Plan/design everything first then build. dont design as you go.
Quote of 2007: "That nub looks cattywampus" -Amir Abo-Shaeer
(fyi there were about 50 nubs on the robot)
Team 1717: D'Penguineers
2008: LA-Regional Winner
2008: SD-Regional Winner
2008: SD-Delphi "Driving Tomorrow's Technology" Award
2007: LA-Semi Finalist
2007: SD-Finalist
2007: SD-Imagery Award
2006: Phoenix Semi-Finalist
2006: Phoenix Regional-Rookie Inspiration Award
2006: LA-Rookie All-Star Award
Unread 18-01-2007, 13:43
RichardJames's Avatar
RichardJames RichardJames is offline
AKA: Eric
FRC #0296 (Northern Knights (or Northern Ninjas))
RichardJames will become famous soon enough
weight relieve every sprocket, pulley, gear, and gear box that you can. weight relieve all aluminium and lexan plates. These are some of the densest things on most people`s bots. also, make sure you are using gears belts or chain that is appropriate (not overkill), as jumping up to the next strongest category can mean doubling the weight of these components.
To design a good mechanical system, you have to design something so simple it almost doesn't work, then increase the complexity until it does.
Unread 18-01-2007, 18:21
maltz1881 maltz1881 is offline
maltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant future
Just as a funny story although it wasn't funny then. When i was with a now defunct team we had an engineer who insisted we had to use 1/4 in thick aluminum for our sides. This was several years ago when you could only weight 130 with your battery. I told him many times it wasn't necessary to go with something so heavy. He still insisted. When we finished the robot we weighed it and came in at a whooping (are you sitting down!!) 217 lbs . What could I say other then I told you so which of course I didn't. Shaking my head and handing out the sawzalls we made it down finally to 130 on the dot. It only took us 9 days of making swiss cheese out of EVERYTHING. Needless to say that engineer was never seen nor heard from again.
Unread 18-01-2007, 21:37
Cuog's Avatar
Cuog Cuog is offline
Registered Linux User: 390661
AKA: Alex
FRC #0422
Programmers: Get rid of that White space, no comments. Those extra electrons are killing us
file everything smooth, I havent teste4d it but im sure of you filed everything on the robot to a smooth surface almost a half pound of dust would be removed.
KK4KQO
http://voltair.us
Unread 19-01-2007, 11:14
Brian C's Avatar
Brian C Brian C is offline
Doer of Whatever
AKA: Brian Cholerton
FRC #1468 (J-Birds)
Brian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant future
Team 190 had their robot a couple of years back where pretty much the entire chassis was made of Lexan.
You can do some pretty cool stuff with Lexan........
2017 Season; Game Announcer at
SBPLI Long Island Regional
Unread 19-01-2007, 11:44
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Yes, you can! Just keep in mind that the modulus of elasticity is around 30 times less than aluminum, which means you have to have a good design to keep deflection down, but it also allows you to have that deflection if you need it for your design.
Unread 19-01-2007, 20:26
FourPenguins's Avatar
FourPenguins FourPenguins is offline
Back in the Game
AKA: Ed Venator
FRC #2399
FourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud of
Words of warning:
Two years ago, MORT built the infamous plastic fantastic end effector out of lexan, acrylic, and polyurethane foam. It was about 30 lbs over weight. The moral: light materials are not a cure-all. If the engineering is flawed, the material won't save you.
Oh yeah. And don't forget that Lexan doesn't break, but it flexes easily, so don't use it for anything that needs to be rigid.
MORT 11
-2006 Palmetto Regional Winner
-2007 New York Regional Delphi Driving Tomorrow's Technology Award
-2008 New Jersey Regional Finalist, Chesapeake Regional Winner, Championship Event Overall Top Seed
HB 2399
-2009 Buckeye Regional Delphi Driving Tomorrow's Technology Award, Pittsburgh Regional GM Industrial Design Award
Quoted picture size reduction sanddrag CD Forum Support 1 25-07-2006 19:05
Weight Reduction Help. Mirza95vx Technical Discussion 11 07-02-2005 16:03
Gear reduction question dmellich Motors 6 25-01-2003 08:54
Speed Reduction for Drill Motors Ian W. Programming 5 18-01-2003 23:57
Drill Motor Gearbox Reduction Ratios archiver 2000 3 23-06-2002 23:05
