Go to Post It is proper to have a disagreement, but it is improper to be disrespectful. - Bill Moore [more]
Unread 18-01-2007, 07:14
Wayne Doenges's Avatar
Wayne Doenges Wayne Doenges is offline
We Build Robots......and Careers
AKA: Warthog
FRC #1501 (Team T.H.R.U.S.T.)
Wayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond repute
Conflict with rules R05 & R06?
This was posted on FIRST Q&A. Does there seem to conflict with Rules R05 and R06?
Re: Robot lifting outside of homezone
Is it acceptable to lift up disabled or malfunctioning alliance partners and transport them to the homezone in order to score bonus points?
There is nothing in the rules that would prohibit this action.
<R05> "Wedge” ROBOTS are not allowed. ROBOTS must be designed so that interaction with
opposing ROBOTS results in pushing rather than tipping or lifting. Neither offensive nor
defensive wedges are allowed. All parts of a ROBOT between 0 and 8.5 inches from the
ground (the top of the BUMPER ZONE) that are used to push against or interact with an
opposing ROBOT must be within 10 degrees of vertical. Devices deployed outside the
ROBOT footprint should be designed to avoid wedging. If a mechanism or an appendage
(e.g. a harvester for retrieving GAME PIECES) becomes a wedge that interferes with other
ROBOTS, penalties, disabling, or disqualification can occur depending on the severity of the
infraction.
<R06> Ramps, platforms as other mechanisms specifically designed to elevate ROBOTS during
the END GAME are exempt from Rule <R05> when they are deployed in the HOME ZONE.
Such devices deployed outside the HOME ZONE are not covered by this exemption.
We Build Robots and Careers
World's - #1 seeded in Archimedes, WON Archimedes and made it to Einstein
2016 NC District - Guilford County. #13 seeded, Finalist. Won Quality award.
IN District - Tippecanoe. #4 seeded. Won Innovation in Control award.
IN District - Perry Meridian. #3 seeded. Finalist. Won Excellence in Engineering award.
IN District - State Championship. #1 seeded. Finalist. Won Excellence inn Engineering award.
Unread 18-01-2007, 07:19
Re: Conflict with rules R05 & R06?
The relevant rules are worded to apply only to interaction with opposing robots. Wedges are not prohibited if they are used only on alliance robots.
Unread 18-01-2007, 08:17
Alan,
R06 is pretty specific and in keeping with last year's interpretation. Any part of the robot within the bumper zone must remain within 10 degrees of vertical until the END GAME and "when they are deployed in the HOME ZONE. "
Unread 18-01-2007, 09:08
O-H
FRC #0048 (Delphi E.L.I.T.E.)
This needs to be a Q&A. Wayne volunteers! Actually, I'll try to find the time to post this today.
"Devices deployed outside the
infraction."
These bolded words are not absolutes. I believe the intent of the rule is to permit ramps to be deployed for PARTNERS to use outside of the home zone only. If while deployed, the ramp is actively used to herd tubes or play defense against the opposing alliance, that is not permitted.
An arm is a "device deployed outside the robot footprint". R05 specifically refers to mechanisms (i.e. ramps) AND appendages (i.e. arms). Who's to say lowering an arm to pick up a ringer off the floor doesn't present a wedge-type angled hazard for other robots to drive up on? If the GDC rules in the Q&A that ramps can't be lowered to the floor outside of the home zone because of R05, then unless the rule is rewritten, manipulator arms should not be permitted to do so for the same reason.
Also, since R06 says that all statements in R05 are null and void while within the home zone, does that imply that it's legal to use your ramps to fend off any opposing robots hanging around in your home zone? This would be analogous to the relaxation of pinning and tipping penalties while on the ramps in the Aim High game.
I propose we hold off on further discussion and wait for an official Q&A answer. Then someone will post the answer in this thread.
Unread 18-01-2007, 10:39
kawelch kawelch is offline
Formerly of 1653
FRC #1984
kawelch is a splendid one to beholdkawelch is a splendid one to beholdkawelch is a splendid one to beholdkawelch is a splendid one to beholdkawelch is a splendid one to beholdkawelch is a splendid one to beholdkawelch is a splendid one to behold
Asked and answered...twice.
http://forums.usfirst.org/showthread.php?t=1261
Unread 18-01-2007, 10:55
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Originally Posted by kawelch View Post
While this answer satisfies the question of picking up disabled partners, it doesn't answer if you can violate <R05> to do it.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 18-01-2007, 11:42
Alan,
<R06> provides a HOME ZONE exception to <R05>. But <R05> explicitly applies only to interaction with opposing robots:
...ROBOTS must be designed so that interaction with opposing ROBOTS results in pushing rather than tipping or lifting. Neither offensive nor defensive wedges are allowed. All parts of a ROBOT between 0 and 8.5 inches from the ground (the top of the BUMPER ZONE) that are used to push against or interact with an opposing ROBOT must be within 10 degrees of vertical...
If you have a wedge-like part but never touch an opposing robot with it, it doesn't violate the rule as I read it.
Unread 18-01-2007, 12:14
ttedrow's Avatar
ttedrow ttedrow is offline
Herding electrons
AKA: Tim Tedrow
FRC #0281 (EnTech)
ttedrow will become famous soon enoughttedrow will become famous soon enough
From an Inspectors point of view:
If there is an area on any side of the robot that would likley cause an opposing robot to climb up or under the your robot, then it will not pass my inspection.
Sr. Design Engineer
Caterpillar Inc.
Greenville, SC
KD4EGM
FRC 281 Greenvillains
Infected with the FIRST virus in 2000
Yes, Chute Door!!!
Unread 18-01-2007, 13:50
There isn't any conflict for 2 reasons. Alan did a good job on the first one. The second is that you don't have to use a wedge to lift a robot, there are other ways. In fact, if they are completely disabled, a wedge would likely do you no good.
Unread 18-01-2007, 15:25
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Alan,
Can you tell me how you arrived at the conclusion in bold here? Can we not expand very large in the home zone during the teleoperated period?
Unread 18-01-2007, 15:37
Brandon Holley's Avatar
That is ridiculous...what if this "area" is of use to have an alliance teammate climb up you
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 19-01-2007, 10:34
ttedrow's Avatar
Herding electrons
AKA: Tim Tedrow
FRC #0281 (EnTech)
Then you must have a way of protecting that area (an angle +/- 10 degrees of vertical) while outside of the home area. Since the inspectors will not be able to know or verify how the robot will be used during the competition, all robots must be able to meet the wedge requirements while outside of the home zone.
Sr. Design Engineer
Caterpillar Inc.
Greenville, SC
KD4EGM
Yes, Chute Door!!!
Unread 19-01-2007, 10:40
Sanddrag,
The boldface is from the rule book, just highlighted for this discussion. In the end game when in the home zone, the rule doesn't apply. Although I am a little fuzzy on when the 'end game' actually starts.
Unread 19-01-2007, 10:45
Eric O's Avatar
Eric O Eric O is offline
AKA: Eric O'Brien
FRC #0177 (Bobcat Robotics)
Eric O has a reputation beyond reputeEric O has a reputation beyond reputeEric O has a reputation beyond reputeEric O has a reputation beyond reputeEric O has a reputation beyond reputeEric O has a reputation beyond reputeEric O has a reputation beyond reputeEric O has a reputation beyond reputeEric O has a reputation beyond reputeEric O has a reputation beyond reputeEric O has a reputation beyond repute
Send a message via AIM to Eric O Send a message via Yahoo to Eric O
Al,
End game is the last 15 seconds of a match. There is a sound to go along with it as descibed in <G03>:
<G03> END GAME - The final 15 seconds of the TELEOPERATED PERIOD is called the END
GAME. During this period, no ROBOT may be in an opposing ALLIANCE HOME ZONE.
The intent of this period is to permit ALLIANCES to attempt to score bonus points without
undue interference. An audio signal will sound five seconds before the start of the END
GAME period, and again at the start of the END GAME period.
Eric O'Brien
Team 177 - Bobcat Robotics (00-01,06-?)
Team 229 - Division by Zero - Clarkson University (02-05)
Unread 19-01-2007, 10:56
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Remember, inspectors are not the only line of defense here. Both R05 and R06 contain wording that indicates that both the design AND use of these mechanisms is considered when evaluating compliance with the rule. You are 100% correct that you do not know how the robot will be used, so why should you make a judgment on it (as long as it's not a safety issue)? Leave it to the referees, that's why they're there! Some rules are game-time rules and are not the inspector's place to judge.
Separate Processor & Robot Rules JoeXIII'007 Control System 7 20-01-2006 19:59
Robot Weight Limit: Rule Conflict Specialagentjim Rules/Strategy 10 06-08-2005 17:52
Autonomous robots working & interacting with each other & their environment. Elgin Clock Math and Science 0 19-05-2005 01:00
Conflict between "Initialize_Tracker()" and "pwm13 & pwm15"? Kevin? gnormhurst Programming 3 22-02-2004 02:55
Rule <R06> Jack Technical Discussion 18 11-01-2004 13:36
