Go to Post You don't have enough money, you're under-staffed, you're not quite sure what the customer wants, requirements change, and they want it yesterday. - Kimmeh [more]
Unread 18-01-2007, 11:29
rustlerharv rustlerharv is offline
FRC #0857
rustlerharv is an unknown quantity at this point
Re: servo on AM shifter
i developed a servo shifter for the AM tranny last season and it made it through the season without and glitches. shifting is slightly slower the pneumatics but you are using a lot less force to shift. the upside its you can lose a lot of weight in pneumatics if you only need it to shift.
Showdown: Shifter type CraigHickman Technical Discussion 7 21-04-2006 08:37
AM Shifter 2 question ForgottenSalad Technical Discussion 2 20-02-2006 14:26
Servo shifter for AndyMark transmissions Robby Technical Discussion 3 17-01-2006 01:41
AndyMark shifter feedback Max Lobovsky Technical Discussion 1 11-01-2006 22:26
Servo behavior question / advanced servo/PIC programming question DanL Electrical 12 18-10-2005 18:33
