#31
Re: Risk of the Lift?
This is my personal apology for my "attitude" earlier. Turns out after crunching the numbers lift = lighter than ramp. So drum roll please 1741 is.......lifting!! We'll see how it works. I do have a question. If we were to use honeycomb (the metal used for certain surfaces on comercial air craft) and used glue to attach the skin is that within the rules? As they read it says that you may not use adhesive back tapes, but this isn't tape so I think its legal but I wanted other opinions if you wouldn't mind.
Thanks |
#32
remember last years ramp was pretty steep and also made out of diamond plate neither of which are requirements for anyonesramp
#33
IMO, if done correctly, a lift can be just as safe as a ramp.
#34
You could technically have a pneumatic lift that lifts your own bot so another bot can drive undernieth then you could raise your lifting mechanism thus you are off the floor!!!!
#35
Wouldn't it damage the other robot thus no alliance parter would want to drive under you and most offensive teams will have an arm or manipulator that is at least 3 feet high.
#36
Yeah, and the weight issue
is a biggie there too... |
#37
Yeah there's a big risk with that stragedy. This will only work if teams design has a large flat area with no appendages sticking out. Also if your arms were to give before your partner was fully in position the fall could cause huge damage to the front of a robot. Also unless other robots are benching 100-120 lbs...
#38
It is almost going to be impossible to use a lift to elevate your alliance's robots. It is going to be impossible because pneumanic cylinders are not going to give enough force to exert a lifting device.
im pretty sure that the pneumatic cylinders come in larger sizes than they gave us so i think it will be possible to lift other robots with a lift. and i thin the largest size is a 2 inch cylinder. |
#39
Good point. I think many people would overlook the possibilty of being dropped if planning on being lifted instead of the one lifting...
#40
if they are planning on being lifted they might design the robot so that it can take a little more impact from the bottom (if dropped). But if the lift is designed correctly it probably won't be likely that it will drop a robot. Teams will take the risk into consideration and make it efficient because they wouldn't want to be dropped either.
#41
#42
Get creative...impossible is a dangerous word my friend |
#45
Why are you limiting yourselves to pneumatics? There are MANY more options that would work just fine.
And I would agree, things that were impossible 10 years ago are now old news. Keep the good ideas coming. |
| Risk tournament | [527]phil | Games/Trivia | 1 | 29-09-2005 17:22 |
| Interface of the window lift motors | Marjory Frosty | Motors | 3 | 14-01-2005 22:57 |
| PHP as a security risk | purplehaze357 | Website Design/Showcase | 9 | 02-07-2003 21:50 |
| A little lift for the final week | George1902 | General Forum | 1 | 11-02-2003 22:48 |
| Amount of Force to lift the bridge? | archiver | 2001 | 2 | 23-06-2002 23:21 |
