Go to Post Andymark has everything! - nighterfighter [more]
  #31   Spotlight this post!
Unread 11-01-2007, 16:53
cgredalertcc cgredalertcc is offline
AKA: Charlie Baxter
FRC #1747 (Harrison Boiler Robotics)
cgredalertcc is a name known to allcgredalertcc is a name known to allcgredalertcc is a name known to allcgredalertcc is a name known to allcgredalertcc is a name known to allcgredalertcc is a name known to all
Send a message via AIM to cgredalertcc
Re: Risk of the Lift?
This is my personal apology for my "attitude" earlier. Turns out after crunching the numbers lift = lighter than ramp. So drum roll please 1741 is.......lifting!! We'll see how it works. I do have a question. If we were to use honeycomb (the metal used for certain surfaces on comercial air craft) and used glue to attach the skin is that within the rules? As they read it says that you may not use adhesive back tapes, but this isn't tape so I think its legal but I wanted other opinions if you wouldn't mind.
Thanks
  #32   Spotlight this post!
Unread 11-01-2007, 17:01
Priyadarshy's Avatar
Priyadarshy Priyadarshy is offline
FRC #0612
Team Role: Mascot
Priyadarshy has a spectacular aura aboutPriyadarshy has a spectacular aura about
Send a message via AIM to Priyadarshy
remember last years ramp was pretty steep and also made out of diamond plate neither of which are requirements for anyonesramp
  #33   Spotlight this post!
Unread 11-01-2007, 17:03
Éowyn Éowyn is offline
no team ((no team))
Éowyn is a splendid one to beholdÉowyn is a splendid one to beholdÉowyn is a splendid one to beholdÉowyn is a splendid one to beholdÉowyn is a splendid one to beholdÉowyn is a splendid one to beholdÉowyn is a splendid one to behold
IMO, if done correctly, a lift can be just as safe as a ramp.
  #34   Spotlight this post!
Unread 11-01-2007, 17:12
MiniCChuck's Avatar
MiniCChuck MiniCChuck is offline
Master of all things small and vexy
FTC #3271 (Made In China)
MiniCChuck is an unknown quantity at this point
You could technically have a pneumatic lift that lifts your own bot so another bot can drive undernieth then you could raise your lifting mechanism thus you are off the floor!!!!
It just one of those days where it is hard to be me.
-- Dilbert
  #35   Spotlight this post!
Unread 11-01-2007, 17:19
Ericgehrken's Avatar
Ericgehrken Ericgehrken is offline
AKA: 3 Teams in 3 Seasons
FRC #0190 (Gompei and the Herd)
Ericgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud of
Send a message via AIM to Ericgehrken Send a message via Yahoo to Ericgehrken
Wouldn't it damage the other robot thus no alliance parter would want to drive under you and most offensive teams will have an arm or manipulator that is at least 3 feet high.
Team 3125
GHAMAS FIRST Robotics
Team President and Founder
2010-
2010 Suffield Shakedown Winner Thanks 178 and 177
2010 WPI Regional Rookie All Star
2010 WPI Dean's List Finalist
Team 195 Member 2007-2009
2007 CT Regional Winner Thanks to 1124 and 558
2008 FIRST Presidents Circle Winner
2009 Suffield Shakedown Winner thanks to 126 and 1124
  #36   Spotlight this post!
Unread 11-01-2007, 17:29
The Revolver's Avatar
The Revolver The Revolver is offline
The Rollercoaster Expert
AKA: Michael Foley
FRC #1741 (Red Alert Robotics)
Team Role: Driver
The Revolver is an unknown quantity at this point
Yeah, and the weight issue is a biggie there too...
  #37   Spotlight this post!
Unread 11-01-2007, 18:59
kyleg242's Avatar
kyleg242 kyleg242 is offline
FRC #0191 (X-Cats)
kyleg242 will become famous soon enoughkyleg242 will become famous soon enough
Yeah there's a big risk with that stragedy. This will only work if teams design has a large flat area with no appendages sticking out. Also if your arms were to give before your partner was fully in position the fall could cause huge damage to the front of a robot. Also unless other robots are benching 100-120 lbs...
  #38   Spotlight this post!
Unread 11-01-2007, 19:38
3@G13_1388's Avatar
3@G13_1388 3@G13_1388 is offline
FRC #1388
3@G13_1388 is an unknown quantity at this point
It is almost going to be impossible to use a lift to elevate your alliance's robots. It is going to be impossible because pneumanic cylinders are not going to give enough force to exert a lifting device.
im pretty sure that the pneumatic cylinders come in larger sizes than they gave us so i think it will be possible to lift other robots with a lift. and i thin the largest size is a 2 inch cylinder.
  #39   Spotlight this post!
Unread 11-01-2007, 19:59
mizscience's Avatar
mizscience mizscience is offline
your friendly geek-next-door
AKA: Melissa Smith
FRC #1251 (TechTigers)
mizscience is a glorious beacon of lightmizscience is a glorious beacon of lightmizscience is a glorious beacon of lightmizscience is a glorious beacon of lightmizscience is a glorious beacon of lightmizscience is a glorious beacon of light
Good point. I think many people would overlook the possibilty of being dropped if planning on being lifted instead of the one lifting...
Once a TechTiger, always a TechTiger.
@mabsmith
Currently a PhD student in VA, volunteering at the DC/FL Regionals and Championships.
16 years and counting with FIRST! FIRST changed my life; how's it changing yours?[/size]
  #40   Spotlight this post!
Unread 11-01-2007, 21:36
cgdtgurl07 cgdtgurl07 is offline
drive train/ mechanic
AKA: Autumn
FRC #1741 (Red Alert)
cgdtgurl07 is an unknown quantity at this point
Send a message via AIM to cgdtgurl07
if they are planning on being lifted they might design the robot so that it can take a little more impact from the bottom (if dropped). But if the lift is designed correctly it probably won't be likely that it will drop a robot. Teams will take the risk into consideration and make it efficient because they wouldn't want to be dropped either.
  #41   Spotlight this post!
Unread 11-01-2007, 22:24
AKA: Michael Foley
Team Role: Driver
Thanks
Thanks for letting out our secret!!!! Just kidding... At first our team went unanimously for the ramp, then the vote flipped and I was stuck on the ramp. Now, well I still think a ramp is going to be lighter, safer, and easier to build, but a lift does have its advantages. So I guess it's official that our team (1741) is lifting...
  #42   Spotlight this post!
Unread 18-01-2007, 14:00
team 888's Avatar
team 888 team 888 is offline
FRC #0888
team 888 is an unknown quantity at this point
Originally Posted by Pavan View Post
With this years game there are two main ideas of how to get the robot up either four inches or twelve inches. They are by ramp or by lifting. For those that are lifting and for those that plan to either climb or be lifted, I believe that the lift is much more dangerous. Although with the ramp you have to to keep it in your base and with 2" of clearance due to bumpers you will need to have a small angle thus a longer ramp, it is much more safer. Your robot is always on solid ground. With the lift you are in the air. Are you sure 30 points is worth the risk of your robot falling twelve inches off of the ground? Although I hope this never happens, I think before teams start thinking of being lifted that they should all consider the possibilities both positive and negative. The main one is a robot falling, and today when my team was discussing this I thought of the fact that if you are being lifted up, you are no longer in control of your robot, and that if anything happens your robot will fall. What if it does? Will your team build a more robust robot that can take a twelve inch fall? Will your team prepare for a worst case scenario?
Before you answer keep in mind that six hard weeks of planning, designing, and building went are going to go into your creation.
Pavan.
hi my name is Matt and I think that if you have 1/3 of the robots w/ramps that they will be more valuable than others. I also think that if you have a bot that can be like a tank or a blocker and or some how create a robot with a arm that sits stationary in between your rings and the spider rack and with a pivoting arm meaning that if you create an arm that rotates 180 to 270 degrees that I think would also be valuable
  #43   Spotlight this post!
Unread 18-01-2007, 14:05
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
In 2004 team 1141 had 4 pneumatic cylinders (one at each corner of the robot) that lifted them 1 ft so that their 9ft arm could grapple onto the bar. This allowed them to make it geometrically impossible for the robot to not be high enough. So the stock pneumatics CAN lift a robot.
  #44   Spotlight this post!
Unread 18-01-2007, 16:20
Brandon Holley's Avatar
Cmon man you gotta put up a better argument than broad statements like "its almost going to be impossible..." or "im pretty sure..."...If you think teams cannot be lifted with pneumatics, you might wanna scroll through CD-media back to 2004 where quite a lot of teams used pneumatics to lift there 120lb+ selves............VERY SUCCESSFULLY
Get creative...impossible is a dangerous word my friend
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
  #45   Spotlight this post!
Unread 18-01-2007, 17:28
pascoea pascoea is offline
AKA: Adam pascoe
FRC #0093 (New Apple Corps)
pascoea is an unknown quantity at this point
Why are you limiting yourselves to pneumatics? There are MANY more options that would work just fine.
And I would agree, things that were impossible 10 years ago are now old news.
Keep the good ideas coming.
Risk tournament [527]phil Games/Trivia 1 29-09-2005 17:22
Interface of the window lift motors Marjory Frosty Motors 3 14-01-2005 22:57
PHP as a security risk purplehaze357 Website Design/Showcase 9 02-07-2003 21:50
A little lift for the final week George1902 General Forum 1 11-02-2003 22:48
Amount of Force to lift the bridge? archiver 2001 2 23-06-2002 23:21
