Go to Post By affiliating yourself with a team, you are representing them at all times, as you are a member and part of that team. - Chris is me [more]
Unread 18-01-2007, 18:50
hanan hanan is offline
hanan has a spectacular aura abouthanan has a spectacular aura about
Question controlling the leds
Hi,
I am using easyC.
Can I control the leds in the OI, that when I am writing setPWM(pwm_relay,value), the led in OI corresponding that relay switch will trun on? (just like the ability to control each pin in plab)
Thanks
Unread 18-01-2007, 21:50
Jimmy Cao Jimmy Cao is offline
AKA: Jimmy Cao
Jimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant future
Re: controlling the leds
Yes. I do not use Easy-C but i can't believe it'll be too different from normal coding, cept it has nice buttons
The code would put a 0 or a 1 into the value of the LED you want to set (1 = on 0 = off)
Suposing you want to control Pwm1_green, just do this
if (something_is_true)
  Pwm1_green=1;
else
  Pwm1_green=0;
or whatever you variation of that you want to do. It can also be used to set the Relay LEDs.
Jimmy Cao
Team 469 2006-2010 Student/Alumni
Team 830 2011-2012 Mentor
Unread 18-01-2007, 22:05
Gamer930's Avatar
Gamer930 Gamer930 is offline
Team 930 and 171 Alumni
AKA: Justin
Gamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to behold
SetOILED ( 5 , 1 ) ;
This sets Relay 1 Red to on
There is "OI LED" under RC Control menu.
2010 to Present, Scorekeeper/Field Power Volunteer for FRC/FTC/FLL
2005 - 2010, Team 171 College Mentor
2002 - 2005, Team 930 Student
Controlling team 803 Programming 10 21-02-2006 13:56
Another question about LEDs on the OI. DemonYawgmoth Control System 2 18-02-2006 21:51
Controlling motors railerobotics Programming 6 17-01-2006 17:17
Fading LEDs using a PWM signal from the Edubot DanL Programming 22 30-03-2004 00:07
controlling with the radio Lord Nerdlinger Programming 2 17-02-2004 22:40
