Go to Post I dont think it matters too much what you do, as long as you do something that lets you apply what you're learning in class. - MrForbes [more]
Unread 18-01-2007, 19:15
Mona's Avatar
Mona Mona is offline
Spirit is my middle name
None #1620 (Robolution)
Mona is an unknown quantity at this point
Unhappy Looking for linear bearing solutions
ok heres the deal guys, im gunna try to explain a piece our team needs for our elevator, however we dont knowthe name but we can explain it as a opaque plastic fitting ta fits into extrusion to help the elevator move..we cant find it ANYWHERE, and we dont know the "technical" name for it PLEEAAASEEE HLLLPPP USSSS
Team 1620 Robolution
Unread 18-01-2007, 19:23
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Re: Looking for linear bearing solutions
I changed the title of this post and erased the two others you created about the same topic. In the future, please title your posts as explicitly as possible and post once in the correct forum. Spamming ChiefDelphi isn't going to make people go out of their way to help you.
It sounds like your team is using aluminum extrusion. This is available from a number of manufacturers -- Item, Bosch, 80/20, etc. -- and each has a corresponding part that'll do what you're seeking. Start looking online or through catalogs for linear slides or linear bearings and that ought to be a good start.
--Madison--
...down at the Ozdust!
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Are you guys using the Bosch Rexroth aluminum extrusions? They sell a product line called Eco-Slide, which fits into the T-slots in the extrusion. You'll find them called slider bearings, linear bearings or profile sliders. See here, and tell us if that's what you're looking for.
Unread 18-01-2007, 19:25
Mona's Avatar
hey, M Krass, yeah sorry, our elevator plan wont work without thanks A LOT, ididnt specify the title, because noone here knew what to call it. Thanks a Bunch
Unread 18-01-2007, 19:28
Mona's Avatar
hey tristan WE found EXACTLY what we wanted through your link thank you
Madison's Avatar
FRC #0488 (Xbot)
No worries. We're all here to help, but sometimes things can get a little crazy if we don't do a little bit of housekeeping at the same time
--Madison--
Unread 18-01-2007, 19:40
Justin M. Justin M. is offline
Mechanical/Driver
FRC #0321 (RoboLancers)
Justin M. is on a distinguished road
Send a message via AIM to Justin M.
80/20 makes a product called the UniBearing, if you want to try them, here is their catalog:
http://www.8020.net/Product-Catalog.asp
See section 9 for linear motion.
Team 321: CHS RoboLancers - Drexel University, CHS Alumni Assn., SDP, Philadelphia Motorsports, Lima Corperation
Looking for smaller 1/2 ID ball bearing sanddrag Technical Discussion 6 26-05-2005 19:44
pic: Linear bearing + mount Alex1072 Robot Showcase 6 02-02-2005 11:13
Looking for 1/2" id flanged bearing .25" thick or less (with flange) Travis Covington Technical Discussion 17 12-12-2004 21:26
Once again offering problems, but no solutions archiver 2000 1 23-06-2002 22:53
Compressor Warning & Solutions Mike McIntyre OCCRA 0 29-10-2001 21:30
