Go to Post if you've got the guts you will get the job done. - JamesCH95 [more]
Unread 18-01-2007, 19:26
bruss6's Avatar
bruss6 bruss6 is offline
FRC #0843 (Wildcats)
bruss6 is an unknown quantity at this point
Problems with Kevin's 2007 default code
Ya so when we upload Kevin's new 2007 code to the robot controller, we would get all green lights, but nothing would work. Anybody having the same problem/ have any suggestions.
Unread 18-01-2007, 19:53
DanDon's Avatar
DanDon DanDon is offline
ohhh MY god
AKA: Dan Hoizner
FRC #0375 (The Robotic Plague)
DanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond repute
Send a message via ICQ to DanDon Send a message via AIM to DanDon Send a message via MSN to DanDon
Re: Problems with Kevin's 2007 default code
Did you download the new master code as well? (And were you either connected with radio or through tether?)
And what exactly isn't working?
Unread 18-01-2007, 21:08
bruss6's Avatar
Well we think we might have it figured otu but is it risky to change the master code. And we were looking at the posts that talked about PWMs 13-16 and think that may have also been a problem
Unread 18-01-2007, 21:24
Cuog's Avatar
Cuog Cuog is offline
Registered Linux User: 390661
AKA: Alex
FRC #0422
Changing the Master code is a matter of following the instructions that are on IFI's website somewhere and installing the code they give you.
KK4KQO
http://voltair.us
Unread 18-01-2007, 21:49
bear24rw's Avatar
bear24rw bear24rw is offline
Team 11 Programming Captain
AKA: Max T
FRC #0011 (MORT)
bear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to behold
Send a message via AIM to bear24rw
Nothing works because by defaults kevins code doesnt call Default_Routine()... call default routine in the main loop and everything will work fine..
Unread 19-01-2007, 02:11
6600gt's Avatar
6600gt 6600gt is offline
AKA: Lohit
FRC #0226 (Hammerhead)
6600gt is a jewel in the rough6600gt is a jewel in the rough6600gt is a jewel in the rough
Be careful, I believe his code is configured to use the PWM 1 and 2 for the camera servos. Change that before you enable the default routine.
Unread 19-01-2007, 03:28
Bomberofdoom's Avatar
Bomberofdoom Bomberofdoom is offline
Biggest FIRST addict in Israel
AKA: Nir Levanon
FRC #2230 (Zcharia's Angels)
Bomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond repute
Send a message via MSN to Bomberofdoom
That reminds me, wasn't the input for PWM01 and 02 p1_y and p2_y? Then how do the servos work??
Unread 19-01-2007, 09:21
bruss6's Avatar
okay that helps. Will try to call the code.
Unread 19-01-2007, 15:42
6600gt's Avatar
AKA: Lohit
if you look in the Tracking.h then you will see what pwmXX is labeled to the PAN_Servo and the TILT_Servo defines.
If they are pwm01 and pwm02 then you will have serious problems if you have the camera on while trying to drive the joysticks.
Just change the pan and tilt pwms...look into the ifialiases.h to get some better understanding.
2007 Default Code? Binome Programming 52 11-01-2007 14:27
problems using gyro/adc code with camera default code tanstaafl Programming 7 22-01-2006 23:09
What are with the Ls in Kevin's code??!!! HELP!!! RbtGal1351 Programming 2 18-02-2005 16:57
problem with the default code MarkVH Programming 7 28-01-2005 00:04
Problem with FRC Default code AsimC Programming 2 11-01-2004 19:22
