Go to Post You do know that totes are supposed to go through the chute right? Not humans? - themccannman [more]
Unread 17-01-2007, 20:47
Adama's Avatar
Adama Adama is offline
AKA: Matthew Eastman
FRC #2199 (Robo-Lions)
Adama is a name known to allAdama is a name known to allAdama is a name known to allAdama is a name known to allAdama is a name known to allAdama is a name known to all
Send a message via AIM to Adama
Bearings and axel size
Today i pressed the bearings into the KOP wheels and then went to grab the axel to see them spin. I found out that neither the thin axel or thick axel is the correct size. the thick being to large and the skinny not wide enough. Am i missing something or is there a mistake in the KOP?
Unread 17-01-2007, 21:06
Brian C's Avatar
Brian C Brian C is offline
Doer of Whatever
AKA: Brian Cholerton
FRC #1468 (J-Birds)
Brian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant future
Re: Bearings and axel size
No Mistake. You need to "adapt and overcome"
The easy way out is to head over to the Home Depot or Lowes or the home improvement location of your choice and get some aluminum tubing with a
3/8" ID and a 5/8" OD. Slip that over your 3/8" axle and the KOP bearing should fit nicely.
2017 Season; Game Announcer at
SBPLI Long Island Regional
Unread 17-01-2007, 21:33
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
Im pretty sure 1/2" axels work if you use the KOP AM wheels and bearings. Ill have to check tommorow though when I have the parts infront of me.
Unread 17-01-2007, 21:52
Hieb Hieb is offline
Hieb is a splendid one to beholdHieb is a splendid one to beholdHieb is a splendid one to beholdHieb is a splendid one to beholdHieb is a splendid one to beholdHieb is a splendid one to beholdHieb is a splendid one to behold
Yes, the KOP wheels with bearings have a 1/2" ID. And no--a 1/2" axle was not included in the KOP.
Unread 17-01-2007, 21:55
DonRotolo's Avatar
Back to humble
FRC #0832
Those nice pieces of Igus aluminum shaft are NOT axles - they are used with the igus motion sontrol stuff included with the KOP. Try this: Get the bigger shaft, and go into the kit and find the beige tube thingies that fit onto the shaft. Then slide it back and forth... Hey, a way to move things in a straight line with low friction!!
Don
Unread 17-01-2007, 22:26
Team 2021 Captain
AKA: Chris Davidson
Of course. You have to go get one yourself. If they put it in the kit it would make it to easy
Don
Hopefully people caught on to the fact that all those parts were in one bag, and that the shafts werent in the drive train bag
Unread 18-01-2007, 22:07
Adama's Avatar
its no big deal, i have .5 in axel on order and the problem has been solved, i just was making sure i wasn' t crazy
Unread 19-01-2007, 11:09
Dick Linn's Avatar
no team (Synergy)
Our wheel bearings have an inside diameter of around 0.499" and our axle material is 0.500", so it's time for the old emery paper.
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 19-01-2007, 12:55
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
wow....I'm glad we have a lathe in the fab shop, and a backup lathe in my garage....I did a little experimental turning on some 3/8" id x 1/2" od steel tube I had and discovered you need to reduce the diameter by about .0015" to get the KOP bearings to slide onto the tube.
Unread 19-01-2007, 13:20
MattB703 MattB703 is offline
AKA: Matt
None #0703 (Team Pheonix)
MattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud of
Tubular axle = way cool
Unread 19-01-2007, 14:15
Dick Linn's Avatar
no team (Synergy)
You can get DOM (Drawn On Mandrel) tubing in different wall thicknesses. OnLineMetals has it. .5: OD by .095 wall thickness is about $3./foot. Local suppliers would be cheaper.
(This size, incidentally, could easily be internally tapped for a 3/8" bolt.)
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Axel Diameters Booger Technical Discussion 18 25-07-2006 19:20
Robot size and weight Covey41 Rules/Strategy 8 10-01-2005 10:32
A little tip about those drill transmissions and bearings archiver 2001 6 24-06-2002 00:22
weight and size of parts Greg Needel Kit & Additional Hardware 2 27-01-2002 23:25
Are bolts to hold wheels on, and bearings, considered "fasteners"? kmcclary Off-Season Events 3 22-10-2001 23:35
