Go to Post As you get more into your years in FRC, you start becoming friends with more people. You should try it out. Robotics people are pretty nice. - [more]
Unread 18-01-2007, 07:32
falconmaster's Avatar
falconmaster falconmaster is offline
AKA: Ledge
FRC #0842 (Falcon Robotics)
falconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond repute
Send a message via MSN to falconmaster
pic: new battery mount
Unread 18-01-2007, 07:37
jcatt's Avatar
jcatt jcatt is offline
AKA: Jonathan Catt
FRC #1902 (Exploading Bacon and FRC #1251 TechTigers)
jcatt is a glorious beacon of lightjcatt is a glorious beacon of lightjcatt is a glorious beacon of lightjcatt is a glorious beacon of lightjcatt is a glorious beacon of lightjcatt is a glorious beacon of light
Re: pic: new battery mount
That battery clamp is awesome!! Could you please show more pictures of how it works? Also, very nice job of keeping the wiring under control. Even though it's probably a prototype its always a good idea to have tidy wiring. Easy to diagnose problems.
Jonathan Catt
Co-Owner and Systems Architect of ColorScene Inc.
Co-Sponsor of The RoboShow: Orlando
FRC 1251 Alumni
FRC 1902 Mentor
Unread 18-01-2007, 08:12
Fredi,
Looks good. I caution teams about severely bending the #6 near the Anderson connector. The sharp bends close in, can cause individual strands to break or pull out. I suggest 1" minimum bend radius when close to the connector.
Unread 18-01-2007, 10:33
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Fredi,
Working in the industry in place that makes connectors and cable assemblies, and more specifically in a cable engineering department, I can respect and second that suggestion!!!
All cable has a spec sheet with a minumum bending requirement that should be followed as closely as possible.
I'll see if I can pull some data up for the specific type of cable used on the Anderson quick disconnect if I can.
Unread 18-01-2007, 13:55
RichardJames's Avatar
RichardJames RichardJames is offline
AKA: Eric
FRC #0296 (Northern Knights (or Northern Ninjas))
RichardJames will become famous soon enough
Brilliant use of the butterfly clip for fast release! I may take a page out of your book on that one.
To design a good mechanical system, you have to design something so simple it almost doesn't work, then increase the complexity until it does.
Unread 18-01-2007, 22:41
AKA: Ledge
Fredi,
Thanks for the heads up, we will check them.
Faridodin "Fredi" Lajvardi KD7WKD
Unread 18-01-2007, 22:42
AKA: Ledge
will do, check back tomorrow, see ya
Unread 18-01-2007, 22:57
Jeremytice's Avatar
Jeremytice Jeremytice is offline
Addicted to FIRST!
FRC #1126 (SparX)
Jeremytice is a name known to allJeremytice is a name known to allJeremytice is a name known to allJeremytice is a name known to allJeremytice is a name known to allJeremytice is a name known to all
Send a message via AIM to Jeremytice
Very cool idea. I'm liking the clamp a lot!
2006 SparX FLR champions with 229 and 1567 after being seeded 1st and Radio shack innovation in controls at FLR
2006 Galileo Division-DIVISION CHAMPION (thanks to 177 and 201)
2006 BattleCry great alliance 1519 and 195.
2006 RCCR hometown champs with 378 and 2567
2007 FLR Innovation in Contols award
2007 Buckeye General Motors Industrial Design Award
2007 Buckeye Finalist with 1038 and 1528
2007 Galileo quarterfinalists with 229 and 191
2008 FLR finalists with 378 and 1551
2008 Buckeye Champs with 1024, 1386, and 2048
2008 Buckeye Motorola Quality Award
2008 IRI Finalists with 1024 , 1625, and 1731
Unread 18-01-2007, 23:15
David's Avatar
David David is offline
FRC #1647 (Iron Devils)
David is a jewel in the roughDavid is a jewel in the roughDavid is a jewel in the roughDavid is a jewel in the rough
Send a message via AIM to David
good design, but couldn't you just use a couple pieces of angle, long, thin bolts and Velcro tie down straps and save a pound or so
Unread 19-01-2007, 00:10
AKA: Ledge
The clamp is aluminum and weighs almost nothing and the angle is fiberglass and weights almost nothing. I think velcro can come loose, thin bolts can bend. If you have done before then I guess ours is overbuilt.
New Battery Andy Brockway Kit & Additional Hardware 10 31-01-2007 17:51
pic: 862 Radio Mount Joe J. Extra Discussion 7 13-03-2006 02:09
pic: Main drive mount falconmaster Extra Discussion 2 18-01-2006 20:05
pic: AM shifter mount close up falconmaster Extra Discussion 2 18-01-2006 19:27
pic: 1351 camera mount sciguy125 Robot Showcase 6 05-02-2005 09:11
