Go to Post There are a maximum of 80 balls in play . If all the balls are in the goals or out of play and the human players won't throw them back in, I guess the robots might try line dancing or doing the cha-cha. - Rick TYler [more]
  #31   Spotlight this post!
Unread 08-11-2006, 08:34
Re: Custom Chargers for backup battery
Larry et al,
As I have said in this thread and elsewhere, I am not happy with the design of the IFI charge circuit. I would rather have a charger that indicates a fully charged battery and takes up zero weight and size on the robot. The only way to get all of those items is to take the time to take the battery off the robot and stick it in a charger in the pit. Easy, safe, and sure that the battery is charged. I like the idea of conversion to power poles as well. (hates Molex)
On another note from an experienced inspector...When mounting the backup battery, don't velcro to the top of the RC. As convenient as that is it blocks the tally lights on the RC from inspection during on-field troubleshooting by IFI and field personnel.
As a suggestion to IFI, if there is going to be a change in RC design, I would allow the main battery to feed the servo power through steering diodes so that the backup has less current draw during normal match operation. This would allow the backup to feed camera servos and normal battery fail circuitry while allowing the main battery to power everything else during the period in which the robot is turned on during matches.
  #32   Spotlight this post!
Unread 08-11-2006, 12:35
Don Wright's Avatar
Don Wright Don Wright is offline
FRC #0469
Don Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond repute
Send a message via MSN to Don Wright Send a message via Yahoo to Don Wright
You mean make the back-up battery just a *gasp* back-up battery?
Donald F. Wright Jr.
Product Manager
AVL Instrumentation & Test Systems, Inc.
  #33   Spotlight this post!
Unread 09-01-2007, 02:18
roboticsguy1988's Avatar
roboticsguy1988 roboticsguy1988 is offline
Larry Johnston
AKA: Larry Boy
FRC #1501 (Team THRUST)
Team Role: Electrical
roboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud of
Send a message via ICQ to roboticsguy1988 Send a message via AIM to roboticsguy1988 Send a message via MSN to roboticsguy1988 Send a message via Yahoo to roboticsguy1988
So this year it seems that a custom circuit is legal going by the phrase at the end which says "The use of this circuit is strongly encouraged."
I am still going to ask on Q & A when it gets up and going
Larry Johnston, Team THRUST, Team #1501, Team THRUST webpage
2005 IRI - Imagery and Design Award
2005 - 2006 BMR - Professional Grade Award
2006 BMR - Delphi Driving Tomorrow's Technology Award
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~ RogerR
~Da team that uses all tha rivets, Team #1501~
The FIRST Software Repository ~ Chief Admin
openFIRST ~ Project Supporter (Former editor)
DMOZ.org - FIRST - US Teams Section ~ Chief Editor
  #34   Spotlight this post!
Unread 18-01-2007, 22:03
Josh_VK's Avatar
Josh_VK Josh_VK is offline
Robot Lover
AKA: Josh Vlodarchyk
FRC #0773 (Kingsville Kukes)
Josh_VK is an unknown quantity at this point
Send a message via ICQ to Josh_VK Send a message via MSN to Josh_VK
We have built a few of the circuts according the diagram they do put out a nice voltage for charging. I will be adding one to last years robot to test for the backfeed i've read about.
We found it VERY diffucult to find all the parts, we needed to order from an online source who had high minimum order, thus we have a large quantity of extra parts.
For teams looking for a kit of required parts we have kits avaliable for a nominal fee. Please see link in my Sig for more info..
Team 773 Kingsville Kukes
2007 -
2006 - Kukinator 4 Driver
2005 - Kukinator 3 Driver
2004 - Kukinator 2 Driver
2003 - Team 773 Scout
Kit of parts to build 2007 Custom Charge Circuit
KingsvilleKukes.com
  #35   Spotlight this post!
Unread 18-01-2007, 23:27
Larry Johnston
AKA: Larry Boy
We will be posting a schematic of our charger circuit on www.frcsoft.com once we get it built and tested and stuff.
  #36   Spotlight this post!
Unread 19-01-2007, 03:43
6600gt's Avatar
6600gt 6600gt is offline
AKA: Lohit
FRC #0226 (Hammerhead)
6600gt is a jewel in the rough6600gt is a jewel in the rough6600gt is a jewel in the rough
Do the backup battery chargers provided in the KIT have overcharge prevention?
Is it possible, for just PRACTICE/TEST purposes, to drive the 5V form the D I/O or the Analog straight to the backup battery connection slot so that we can get 5V out of the PWM pins? I don't see problem with this since there is not voltage regulators on the PWM lines(I know its custom circuitry but the backup battery circuity has just as much chance of failure, since individuals build it) The backup batteries are a pain when you are trying to play with the camera.
  #37   Spotlight this post!
Unread 19-01-2007, 07:15
That's a good question. The chargers we received in past years have an indicator light to show full charge; this year's does not. I left a battery plugged in to this year's charger overnight, and the battery got very warm. I am going to use last year's backup battery charger instead.
  #38   Spotlight this post!
Unread 19-01-2007, 08:10
Larry,
You may only use the supplied charger or the IFI charger for the backup battery.
<R56> The 7.2v backup battery may be charged on or off the ROBOT. When off the ROBOT, the
battery is to be charged with the provided 7.2V backup battery charger. When mounted on
the ROBOT, the backup battery may be charged from the 12VDC primary battery by using
the custom charging circuit available from Innovation First Inc. (note: IFI will provide the
design for this circuit on the IFI website, however teams must obtain the parts for this circuit
and assemble it themselves). The use of this circuit is strongly encouraged.
  #39   Spotlight this post!
Unread 19-01-2007, 23:04
Raym Raym is offline
FRC #1138
Raym is on a distinguished road
OK, it has been resolved that if you are going ot charge the BU battery on the robot, you must use the IFI circuit design.
Could someone please post the circuit theory on that circuit?
Looking it over, it seems like it might waste more power than it provides to the BU battery.
  #40   Spotlight this post!
Unread 21-01-2007, 23:17
Larry Johnston
AKA: Larry Boy
Larry,
You quoted it yourself "The use of this circuit is strongly encouraged." therefore meaning you do not HAVE to use the IFI design.
I will double check on that and post a question in the Q & A.
  #41   Spotlight this post!
Unread 21-01-2007, 23:30
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
I believe the intent was that you use their circuit in lieu of not having an onboard charger. It seems very unlikely they'd let you connect any "non-official" circuitry to either of the power systems in such a manner, a mistake could result in dangerous damage to the backup battery and it's not easy for an inspector to look through every circuit to make sure its legal. I believe the correct interpretation is that you have an option of using the IFI circuit, or not using one, and they recommend you use it.
Matt Krass
  #42   Spotlight this post!
Unread 21-01-2007, 23:40
Larry Johnston
AKA: Larry Boy
well, i see what your saying, which i agree partially, but the same thing is true for any custom circuit
  #43   Spotlight this post!
Unread 22-01-2007, 07:20
Larry,
You need to read the rule again. You must use the IFI charger design. And it is "strongly encouraged" that use an onboard charger.
  #44   Spotlight this post!
Unread 22-01-2007, 11:08
dcbrown dcbrown is offline
AKA: Bud
dcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud of
I'd like to take a stab at the theory of operations of the ifi supplied charger. Some things make sense... others leave me confused. Hopefully others can help correct and fill-in the pieces.
The LM317 regulator changes its output so as to maintain a 1.25v drop across R2 (220). Since the same current through R2 goes through R3,
Vout = 1.25 * (1+(R3/R2)) or about 8.3v. So far so good I think. R4 (22) limits the charge current that can be provided to the 7.2v battery. When the backup battery is near full, this would be ~45ma. This supply will be fairly constant as the regulator will hold Vout at 8.3v independent of input supply, as long as Vin is > ~9.5V
R1 (43) seems to be able to provide a constant charge current of ~110-130ma based upon the voltage differential of a 12v battery and the 7.2v battery independent of the regulated LM output. If or when the battery voltage drops to 10.8v - like under heavy discharge of a running robot - current available via R3 will drop down to about 80ma.
This is one of the things that is confusing... why go through the trouble of a regulated supply if the simple resistor is capable of supplying upwards of 2x or more than the regulated circuit is capable of?
So there is a total current available of ~150-170ma draw from the 7.2v circuit as shown?
Why D1? I'd be tempted to replace this with a LED until competition to show when the 7.2V is in discharge. That is, if you disconnect the 12v battery the regulator circuit input supply voltage will be back fed through R1. In addition, D1 will bypass R4 and 7.2V will be applied to (R2+R3). This equates to an approximately 5ma current constant discharge. So, if you are like us who routinely "safe" the robot by unplugging the main battery but don't disconnect the backup, then we'll end up draining/discharging the 7.2v battery through this charging circuit overnight. A small red led where D1 is would provide a visual reminder that this is occuring.
Many regulator circuits worry about sudden current discharges and transient spikes delivered back into the output pin of the regulator and put a protection diode across the input/output pins. D1 in essense is across the pins but in the reverse direction of what is needed so the regulator isn't protected. I guess if you burn out the chip you might not notice because you still have R1 delivering 100ma+ charging current?
Ok, pull the backup battery and what happens. In an open circuit with a load <~80ma through R1, the 'batt' point floats above 8.7V and the zener diode draws current to clamp it at 8.7V. The zener could see current spikes up to ~180ma as it does this.
I'm sure I have some of this incorrect and would like feedback.
thanks,
bud
http://www.ifirobotics.com/docs/firs...up-charger.pdf
Last edited by dcbrown : 23-01-2007 at 08:02. Reason: add reference to pdf schematic
  #45   Spotlight this post!
Unread 22-01-2007, 23:11
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
Sketched up a parts layout for the charger tonight: (be sure to double check before using):
Automatic battery chargers only? sanddrag Electrical 1 12-01-2005 23:38
[OCCRA]: different battery chargers? no chance OCCRA Q&A 1 28-10-2004 05:34
Off-topic battery stuff. FotoPlasma Electrical 4 06-01-2003 12:19
So what's in YOUR Custom Circuit this year? kmcclary Technical Discussion 7 10-04-2002 12:20
Voltage Range of Analog Inputs Ulibrium Electrical 21 15-02-2002 14:11
