Go to Post (Don't you hate it...) "when... no more buttons can fit onto your clothing at competitions?" - mcb [more]
Unread 19-01-2007, 00:17
WRGibbens WRGibbens is offline
Instructor Materials Fabrication
FRC #1583 (Rambotics)
WRGibbens will become famous soon enough
pic: 6 Wheel drive Rh side
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
Re: pic: 6 Wheel drive Rh side
Looks like you don't have much chain wrap on that center sprocket. That could cause it to skip teeth when you have a lot of resistance.
Unread 19-01-2007, 02:14
NOV8R's Avatar
NOV8R NOV8R is offline
AKA: Chuck Brant
FRC #1583
NOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud of
What you can't see is an idler hidden by the top frame rail that wraps the chain more around the top in addition to what you see of the bottom of the sprocket . Almost 50 percent of the sprocket's teeth are in contact with the chain. The final drive ratio is 22:1 and it can push rather nicely.
Unread 19-01-2007, 08:35
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Judging from the picture, there is only about 45 degrees worth of chain wrap around that center sprocket. At the very least, you should always have at least 180 degrees of chain wrap around a sprocket. In a high torque application such as a drivetrain, you're much more likely to skip teeth on the sprocket if you do not have adequate wrap of the sprocket.
Art Dutra IV
世上无难事,只怕有心人.
Unread 19-01-2007, 09:21
Dan_Karol Dan_Karol is offline
Mentor and Coach
AKA: Daniel Karol
FRC #0131 (CHAOS)
Dan_Karol has a spectacular aura aboutDan_Karol has a spectacular aura about
Send a message via AIM to Dan_Karol
I have just one question,
does the chain touch on the top and the bottom of the sprocket or does it wrap around it? If it touches in two places you may want to be weary of the chain breaking, jumping, falling off, or simply stretching so it doesn't nicely touch
just my first reactions,
-Dan
2004 - 2012: Team 1100
2013 - ????: Team 131
Unread 19-01-2007, 11:45
NOV8R's Avatar
AKA: Chuck Brant
FRC #1583
Dan and Gus you're both right. Yes, the chain meshes on both sides of the sprocket and the sprocket on the transmission is in the position of the second idler Gus shows. There is no chain/sprocket contact that is less than 120 deg of circumference. In fact both end sprockets are almost 240 deg. We played around with many designs for a single chain six wheel drive during the off season and this one is the one that met our requirements (reliable, durable, and simple). We've run it and this design seems to be nuke proof. However, the true test will be on the field with other robots.
pic: KitBot 4 CIM 2 Wheel Drive Chasis: Side Vince Extra Discussion 6 09-01-2008 19:17
pic: 6 Wheel Drive Chasis AJ R Extra Discussion 5 06-01-2007 08:49
pic: Jester Drive:Mecanum Wheel Drive Train Ken Delaney 357 Technical Discussion 64 29-03-2006 22:16
pic: Chantilly Academy's 4 Wheel Drive 4 Wheel Steering!!!! jskene Robot Showcase 25 18-02-2005 20:24
pic: 710 2004 side view of drive train CD47-Bot Robot Showcase 6 16-02-2004 19:43
