| View Poll Results: How wide is your ramp? | |||
| under 28" |
3 | 7.89% |
| 28"-34" |
9 | 23.68% |
| 34"-40" |
18 | 47.37% |
| 40"+ |
8 | 21.05% |
| Voters: 38. You may not vote on this poll | |||
Ramp compatibility & falling
The hybrid ramp/scoring robots I'm seeing are worrying me because their ramps are too thin for normal sized (28x38) robots to climb. (We're probably making our chassis smaller because of that.) If you have a ramp, how wide are you making it?
Also, how are you planning on dealing with tipping while climbing/being lifted? I'm not too worried about falling if we land right side up, but crashing over sideways could do some serious damage to our manipulator... (haha, note the 2005 manipulator bending in my icon) We could put in a weak joint that will break before the manipulator itself does, but it's still risky =P Last edited by rachal : 19-01-2007 at 02:16. |
Re: Ramp compatibility & falling
Team 1856's Ramp is 35 inches wide, 24 inches long and the climb to the top is 9 inches
I can't give you specific sizes, but I can tell you that our ramp will be plenty big for a robot of any size or orientation to get on. Along with that, the degree of our ramp should be less than 8 deg. And yes, we are planning on going for the 12" mark with 2 robots.
8 degrees? If I've done my math correctly, and you're raising a robot (or two) to 12" with the ramp alone, you're saying that your ramp will be over 7 feet long?
Well, every year I'm absolutely amazed by a few robots out there. Based on this thread alone, I guess I'll be amazed by at least two of them... BEN Ah, Rick beat me to the math...! |
#7
I am guessing maybe it is not just a ramp that gets the robots to 12", but also a lifting mechanism.
#8
... or the ramp is hinged at more than one point?
#9
We're going for 36" wide, 2 robots, 12" high, and....0 degrees. Weight has been the limiting factor for the width.
#10
If most other teams are building wide ramps, I guess we only need the narrow one we were considering
| Bumpers & the Ramp | Gary Bonner | Rules/Strategy | 2 | 26-01-2006 11:13 |
| Q&A Discuss: Does the line continue up the ramp? | CD47-Bot | Extra Discussion | 5 | 18-01-2003 01:01 |
| Falling Robot | Mullen | Technical Discussion | 1 | 16-01-2003 16:38 |
| Q&A Discuss: Ramp wire | CD47-Bot | Extra Discussion | 2 | 06-01-2003 20:57 |
| Ruler of the Ramp Q & A | archiver | 2000 | 0 | 23-06-2002 22:40 |
