Go to Post So, apparently I have my own division in nationals going by the search, "elgin clock division". Why was I not told about this? jeesh... - Elgin Clock [more]
Unread 18-01-2007, 14:18
ManicMechanic ManicMechanic is offline
AKA: Yolande
VRC #0438 (Metal Gear)
ManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond repute
Extension Cables - keeping connected
We use PWM extension cables for motors on manipulators that get moved around quite a bit. We've found that the cables have a tendency to come unplugged (not enough friction), and we've been using scotch or masking tape to keep them together, which is illegal. We've tried anchoring the cables down using zipties, which are clumsy and not as effective as tape. Does anyone have a better solution that's FVC legal? The cables are long enough, with no tension (except gravity) on them.
Unread 18-01-2007, 14:48
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Re: Extension Cables - keeping connected
Hot Glue gun. One glue spot on the place the PWM plugs into the housing works. Both sides if you want to really hold it down.
Unread 18-01-2007, 17:27
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
This is an FVC thread, not an FRC, and glue is not legal in the 2006/7 FIRST Vex Challenge.
The best solution I have seen is just being mindful of where your wiring runs are, and placing the cables and connectors in places they shouldn't be pulled apart.
Unread 18-01-2007, 23:17
You can also loosely knot the connection.
Unread 19-01-2007, 11:54
Phalanx's Avatar
Phalanx Phalanx is offline
Formerly Team 1089 (Mercury)
AKA: Michael Reffler
FRC #5431 (Titan Robotics)
Phalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond repute
In the past we slightly seperate the wires from one another at the connector and then use a small zip tie to keep both ends connected.
In the future we plan to make our own custom lengths to fit as needed to avoid that situation.
Don't just ask the experts, become one!
Leadership is not about ability. It's about responsibility!
Diagonally Parked in a Parallel Universe. It's okay we do Quantum Physics
Unread 19-01-2007, 11:58
I thought that wasn't allowed for the Vex competition?
I thought it had to be a standard off-the-shelf vex part to qualify.
Unread 19-01-2007, 12:57
Whoops!!! Sorry about that confusion. I should pay more attention to what forum something is in before I post next time.
As far as an effective solution, it would work and maybe FVC will relax that rule as a solution next year if you give them feedback relating to the problem and the solution I suggested.
Sorry again for the confusion!
Unread 19-01-2007, 17:47
skimoose's Avatar
skimoose skimoose is offline
Parent/Mentor/Engineer
AKA: Arthur Dutra
FRC #0228 (GUS)
Team Role: Electrical
skimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond repute
Currently, the only FVC legal way to keep pwm extension cables together is to zip tie the each side of the connector to some part of the robot. Even splitting the pwm cable to slip a zip tie through, is modifying an electrical component which is not allowed under the FVC rules. Also, custom built or custom length pwm cables is NOT legal for FVC.
I have asked IFI to create a FVC legal product which would function similar to one I found, and use for FRC, made by Maxx Products - a Universal Security Clip. It is being considered and, hopefully, it will be available for next year. If you think its a good idea, you might want to drop IFI or the GDC a post asking to make these FVC legal.
If you'd like to try these clips for FRC here's the link:
http://www.maxxprod.com/mpi/mpi-3.html
Look about half way down the page for the Universal Security Clip.
2009 CT Regional Motorola Quality Award
2010 VRC Connecticut Championship Winners & Amaze Award
2010 VRC Championship Divisional Energy Award
2010 WPI Regional Winner
2010 WPI Regional Engineering Inspiration Award
2011 WPI Regional Chairman's Award
2012 WPI Regional Finalists
Unread 20-01-2007, 10:06
fredliu168's Avatar
fredliu168 fredliu168 is offline
FTC #0478 (Mustang Robotics 478)
fredliu168 has much to be proud offredliu168 has much to be proud offredliu168 has much to be proud offredliu168 has much to be proud offredliu168 has much to be proud offredliu168 has much to be proud offredliu168 has much to be proud offredliu168 has much to be proud of
Send a message via MSN to fredliu168
I hate when pwm cables get unplugged. Happened to us during a competition, and we lost a match because of it...
anyways, the best way is probably zip tie both sides of the pwm cables tightly, so only the middle stretches/compresses because of your robot's manipulator moving.
In 2006
Team Name: 3652 FLAME
Michigan VEX Competition WINNERS
Pennsylvania VEX Competition WINNERS
Atlanta World Championships Runner-up alliance
Only team to win two regionals in 2006
In 2007
Team Name: 478 Mustang Robotics and 163 UHS Robotics
Events:
Toronto FTC Competition - Finalists (478, 163, 298)
MA FTC Competition - Winners! (738, 478, 427)
Unread 22-01-2007, 10:47
Ken Delaney 357 Ken Delaney 357 is offline
FTC #101(Radnor Robotics)
FRC #0357 (Royal Assault)
Ken Delaney 357 is a splendid one to beholdKen Delaney 357 is a splendid one to beholdKen Delaney 357 is a splendid one to beholdKen Delaney 357 is a splendid one to beholdKen Delaney 357 is a splendid one to beholdKen Delaney 357 is a splendid one to beholdKen Delaney 357 is a splendid one to behold
This rule makes no sense. I don't know why taping the pmw connections together should be illegal. No one wants to win because the other team's robots pwm cables came apart. I hope they give this rule a good hard look, and either change it or create a product as skimoose suggested
“Far better it is to dare mighty things, to win glorious triumphs, even though checkered by failure, than to take rank with those poor spirits who neither enjoy much nor suffer much, because they live in the gray twilight that knows not victory nor defeat.” ~Teddy Roosevelt
Thus spake the master programmer:
"A well-written program is its own heaven; a poorly-written program is its own hell."
Unread 23-01-2007, 00:10
clean399's Avatar
clean399 clean399 is offline
Mr. Clean
AKA: Nick Hayes
FRC #0399 (Eagle Robotics)
clean399 is a jewel in the roughclean399 is a jewel in the roughclean399 is a jewel in the rough
Send a message via AIM to clean399
we used eletrical tape which we still had a couple problems with but we found if you can get the close to a stationary object or at least stays straight like a piece of metal zip tie both side down tight. that seemed to work for us but only because we had something to zip tie to. I also agree losing a match because a PWM slips out is not fun it happened to us in the semis at a scrimmage and then in the finals at the socal CSUN competition.
Unread 23-01-2007, 05:56
gdo's Avatar
gdo gdo is offline
Never too much duct-tape ;)
AKA: Patrick
FTC #0001 (Team Unlimited)
gdo is a splendid one to beholdgdo is a splendid one to beholdgdo is a splendid one to beholdgdo is a splendid one to beholdgdo is a splendid one to beholdgdo is a splendid one to beholdgdo is a splendid one to beholdgdo is a splendid one to behold
Send a message via AIM to gdo Send a message via MSN to gdo
I'm not sure if it would work, but try placing a strip of non slip mat over the cables and fasten it down on both ends, the holes int he mat should expand enough for the cables to go in, but should close enough to keep the cables in.
I've never tried that, but it could work, otherwise zip ties are the only vex legal way to go unfortinately
FTC #1: http://unlimited.syraweb.org
Got any question for me; AIM, MSN or PM me
Unread 23-01-2007, 18:20
skimoose's Avatar
AKA: Arthur Dutra
FRC #0228 (GUS)
The rule comes from the FRC side. Electrical tape can only be used as an insulator. No tape, of any kind, can be used to join components together.
Engineering doesn't involve duct tape.
Unread 01-02-2007, 00:51
zerozio2u's Avatar
zerozio2u zerozio2u is offline
CAMS
AKA: DemonKing
FTC #3350 (Cheesecake)
Team Role: Student
zerozio2u is on a distinguished road
Send a message via AIM to zerozio2u
the idea that skimoose suggested is similar to tied the cable down to a stationary part with two zip-ties at both end. this rule make us think of a way around it. . but using tape seem convenient, too.
Unread 01-02-2007, 08:16
I think Mark had the best soultion, tie the junction in a simple overhand knot and use a trywrap to hold the whole thing together.
<R86> No more than one motor may be connected to each speed controller. Michael Hill Electrical 2 08-01-2006 02:00
Camera not working when connected to robot MarkVH Programming 5 14-02-2005 15:40
Camera not working when connected to robot MarkVH Programming 2 05-02-2005 18:08
Acceleration Sensor Connected, but values are odd.... Leav Electrical 7 04-02-2005 15:28
Fisher price motors connected to the relays? zainali Motors 1 09-02-2004 18:50
