Go to Post You're here for them, not for you. - Chris is me [more]
Unread 17-01-2007, 20:38
team877's Avatar
team877 team877 is offline
FRC #0877 (Cub Robotics)
team877 is an unknown quantity at this point
Exclamation autotracking and driving with Easy C???
What I would like to know is after you get your cam working in labview load it over to easy C what do you do??? i got a code that is suppose to do eveything but it remains motionless. Do you have to tweak things with the 2007 demo to make the servos work properly, and do you have to set it to a certain color or something??? This is my first year working on this, if someone could tell me everything they know about getting this working with easy C and getting it to run i would be more than thankful....Thank You
Cub Robotics
Unread 17-01-2007, 20:47
JBotAlan's Avatar
JBotAlan JBotAlan is offline
Forever chasing the 'bot around
AKA: Jacob Rau
FRC #5263
JBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond repute
Send a message via AIM to JBotAlan Send a message via Yahoo to JBotAlan
Re: autotracking and driving with Easy C???
http://www.chiefdelphi.com/forums/sh...threadid=52137
Please don't double-post. If you need the thread you already created moved, please let a mod know.
Aren't signatures a bit outdated?
Unread 17-01-2007, 22:47
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Check out the FRC forum and download my Drive Code. It has camera functions in it.
http://www.chiefdelphi.com/forums/at...8&d=1165872883
Also check out the Tutorial PDF posted it walks you right throught it.
http://www.chiefdelphi.com/forums/at...3&d=1168964099
Unread 18-01-2007, 18:53
hanan hanan is offline
hanan has a spectacular aura abouthanan has a spectacular aura about
Could you please post a link for its specific location?
Thanks king for your update (link)
Unread 19-01-2007, 12:36
Chris_Elston's Avatar
Chris_Elston Chris_Elston is offline
Controls Engineer
AKA: chakorules
FRC #1501 (Team THRUST)
Chris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond repute
You can also download our last years robot code that had an AUTO AIM system during regular game play, and automode that uses the camera to update the drive system error.
http://www.frcsoft.com/forums/index.php?download=11
Team T.H.R.U.S.T. 1501
Download all of our past robot's source code here:Repository
Favorite CD quote:
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~RogerR: Team #1369
CMUCam, Easy C, and Labview JJMax7 Programming 28 07-02-2007 22:20
Basics for autotracking and driving with it team877 Programming 1 17-01-2007 20:27
Need help with easy c about the CMU . Ami Schwartz Programming 2 15-01-2006 10:58
Wiring for CMU and Easy C chadbarbe Programming 4 15-01-2006 00:29
