Go to Post Mob JVN for autographs - Jay Trzaskos [more]
Unread 19-01-2007, 14:21
Roger Roger is offline
FRC #1153
Rookie Year: 1900
Roger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond repute
Re: _entry_scn error on building
I’m sorry this is taking so long. I thought with the //FILES c018i.o I was free and clear!
Both the MPLAB and IFIloader are from last year’s kit. We’ve loaded this year's disk on other computers, but at the time we only had last years set and ready. Also, the robot code is last years, and we’ve been loading it onto last year’s robot.
Right now I’m not with the computer nor robot, but I have my own computer with duplicates of everything. It also tested the code and compiled successfully, just to see if a different computer can do it.
Here is the output from the last successful build:
Clean: Deleting intermediary and output files.
Clean: Deleted file "C:\CODE\0601-SHOOTER\2007-01-14 TEST\camera.o". Clean: Deleted file "C:\CODE\0601-SHOOTER\2007-01-14 TEST\camera_menu.o".
Clean: Deleted file "C:\CODE\0601-SHOOTER\2007-01-14 TEST\eeprom.o". Clean: Deleted file "C:\CODE\0601-SHOOTER\2007-01-14 TEST\ifi_startup.o". Clean: Deleted file "C:\CODE\0601-SHOOTER\2007-01-14 TEST\ifi_utilities.o". Clean: Deleted file "C:\CODE\0601-SHOOTER\2007-01-14 TEST\main.o". Clean: Deleted file "C:\CODE\0601-SHOOTER\2007-01-14 TEST\serial_ports.o".
Clean: Deleted file "C:\CODE\0601-SHOOTER\2007-01-14 TEST\terminal.o". Clean: Deleted file "C:\CODE\0601-SHOOTER\2007-01-14 TEST\tracking.o". Clean: Deleted file "C:\CODE\0601-SHOOTER\2007-01-14 TEST\tracking_menu.o".
Clean: Deleted file "C:\CODE\0601-SHOOTER\2007-01-14 TEST\user_routines.o". Clean: Deleted file "C:\CODE\0601-SHOOTER\2007-01-14 TEST\user_routines_fast.o".
Clean: Done.
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8722 "camera.c" -fo="camera.o" /i"C:\mcc18\h" -mL -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa- -nw=2066 -D_FRC_BOARD Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8722 "camera_menu.c" -fo="camera_menu.o" /i"C:\mcc18\h" -mL -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa- -nw=2066 -D_FRC_BOARD Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8722 "eeprom.c" -fo="eeprom.o" /i"C:\mcc18\h" -mL -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa- -nw=2066 -D_FRC_BOARD Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8722 "ifi_startup.c" -fo="ifi_startup.o" /i"C:\mcc18\h" -mL -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa- -nw=2066 -D_FRC_BOARD Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8722 "ifi_utilities.c" -fo="ifi_utilities.o" /i"C:\mcc18\h" -mL -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa- -nw=2066 -D_FRC_BOARD Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8722 "main.c" -fo="main.o" /i"C:\mcc18\h" -mL -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa- -nw=2066 -D_FRC_BOARD Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8722 "serial_ports.c" -fo="serial_ports.o" /i"C:\mcc18\h" -mL -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa- -nw=2066 -D_FRC_BOARD Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8722 "terminal.c" -fo="terminal.o" /i"C:\mcc18\h" -mL -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa- -nw=2066 -D_FRC_BOARD Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8722 "tracking.c" -fo="tracking.o" /i"C:\mcc18\h" -mL -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa- -nw=2066 -D_FRC_BOARD Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8722 "tracking_menu.c" -fo="tracking_menu.o" /i"C:\mcc18\h" -mL -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa- -nw=2066 -D_FRC_BOARD
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8722 "user_routines.c" -fo="user_routines.o" /i"C:\mcc18\h" -mL -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa- -nw=2066 -D_FRC_BOARD Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8722 "user_routines_fast.c" -fo="user_routines_fast.o" /i"C:\mcc18\h" -mL -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa- -nw=2066 -D_FRC_BOARD
Executing: "C:\mcc18\bin\mplink.exe" /l"C:\mcc18\lib" "C:\mcc18\lkr\18f8722.lkr" "C:\CODE\0601-SHOOTER\2007-01-14 TEST\camera.o" "C:\CODE\0601-SHOOTER\2007-01-14 TEST\camera_menu.o" "C:\CODE\0601-SHOOTER\2007-01-14 TEST\eeprom.o" "C:\CODE\0601-SHOOTER\2007-01-14 TEST\ifi_startup.o" "C:\CODE\0601-SHOOTER\2007-01-14 TEST\ifi_utilities.o" "C:\CODE\0601-SHOOTER\2007-01-14 TEST\main.o" "C:\CODE\0601-SHOOTER\2007-01-14 TEST\serial_ports.o" "C:\CODE\0601-SHOOTER\2007-01-14 TEST\terminal.o" "C:\CODE\0601-SHOOTER\2007-01-14 TEST\tracking.o" "C:\CODE\0601-SHOOTER\2007-01-14 TEST\tracking_menu.o" "C:\CODE\0601-SHOOTER\2007-01-14 TEST\user_routines.o" "C:\CODE\0601-SHOOTER\2007-01-14 TEST\user_routines_fast.o" "C:\mcc18\lib\FRC_library_8722.lib" /m"2007-01-14 TEST.map" /o"2007-01-14 TEST.cof"
MPLINK 3.90, Linker Copyright (c) 2004 Microchip Technology Inc. Errors : 0 MP2COD 3.90, COFF to COD File Converter Copyright (c) 2004 Microchip Technology Inc. Errors : 0
MP2HEX 3.90, COFF to HEX File Converter Copyright (c) 2004 Microchip Technology Inc. Errors : 0 Loaded C:\CODE\0601-SHOOTER\2007-01-14 TEST\2007-01-14 TEST.cof. BUILD SUCCEEDED: Fri Jan 19 06:42:17 2007
Note the COFF to HEX part matches yours.
Here is 18f8722.lkr:
// $Id: 18f8722.lkr,v 1.2 2004/09/13 22:07:05 curtiss Exp $
// File: 18f8722.lkr
// Sample linker script for the PIC18F8722 processor
LIBPATH .
//FILES c018i.o
FILES clib.lib
FILES p18f8722.lib
CODEPAGE   NAME=vectors    START=0x0            END=0x29           PROTECTED
CODEPAGE   NAME=page       START=0x2A           END=0x1FFFF
CODEPAGE   NAME=idlocs     START=0x200000       END=0x200007       PROTECTED
CODEPAGE   NAME=config     START=0x300000       END=0x30000D       PROTECTED
CODEPAGE   NAME=devid      START=0x3FFFFE       END=0x3FFFFF       PROTECTED
CODEPAGE   NAME=eedata     START=0xF00000       END=0xF003FF       PROTECTED
ACCESSBANK NAME=accessram  START=0x0            END=0x5F
DATABANK   NAME=gpr0       START=0x60           END=0xFF
DATABANK   NAME=gpr1       START=0x100          END=0x1FF
DATABANK   NAME=gpr2       START=0x200          END=0x2FF
DATABANK   NAME=gpr3       START=0x300          END=0x3FF
DATABANK   NAME=gpr4       START=0x400          END=0x4FF
DATABANK   NAME=gpr5       START=0x500          END=0x5FF
DATABANK   NAME=gpr6       START=0x600          END=0x6FF
DATABANK   NAME=gpr7       START=0x700          END=0x7FF
DATABANK   NAME=gpr8       START=0x800          END=0x8FF
DATABANK   NAME=gpr9       START=0x900          END=0x9FF
DATABANK   NAME=gpr10      START=0xA00          END=0xAFF
DATABANK   NAME=gpr11      START=0xB00          END=0xBFF
DATABANK   NAME=gpr12      START=0xC00          END=0xCFF
DATABANK   NAME=gpr13      START=0xD00          END=0xDFF
DATABANK   NAME=gpr14      START=0xE00          END=0xEFF
DATABANK   NAME=gpr15      START=0xF00          END=0xF5F
ACCESSBANK NAME=accesssfr  START=0xF60          END=0xFFF          PROTECTED
SECTION    NAME=CONFIG     ROM=config
STACK SIZE=0x100 RAM=gpr14
Here is the .HEX code:
:020000040000FA
:06002A000B00156600004A
:100030004B0300000A000000136600006E0300007E
:10004000020000000E6600005503000005000000DD
:100050000A6600006603000004000000F16500006D
:10006000C702000019000000EF6500006C030000EB
:1000700002000000EB6500006203000004000000C5
:10008000E5650000F7020000060000000608000019
:100090006A03000002000000DE650000F9010000B4
:1000A000070000001265000000010000CC00000005
<snip>
:10659000000201320005020A0005010A0005020A94
:1065A000061600FE63FE0002012800FE63FE0002E4
:1065B000061600FE63FE00020A0A00FE63FE0002E9
:1065C000012800020A0300FE63FE0002011E000211
:0E65D0000A0300FE63FE070002000000000048
:0265DE000000BB
:0565E0007F7F000000B8
:0665E500000000000100AF
:0465EB0000000000AC
:0165EF00FEAD
:0165F000FFAB
:0F65F10000000100000000000001000000000198
:0A660000000000000000010000008F
:04660A00000000008C
:02660E0000008A
:0366100001000086
:02661300000085
:0A6615000000000000000001010178
:020000040030CA
:0E000000FF36F6FEFFFF8BFFFFBFFF9FFFBF27
:00000001FF
(I’ve snipped out the exciting middle 1000 lines.) I’m assuming the beginning numbers on each line are some hexadecimal address, except yours stays low, but mine jumps up to the 1000’s at the 3rd line.
Build Options – General:
Include Path: C:\mcc18\h
Library Path: C:\mcc18\lib
(all others blank)
Finally, I’ve attached a picture of the MCW list, and one of Build Options – MPLAB C18. -- Well, I would have, except it's not doing what I thought
Build Options, MPLAB c18 tab, Use Alternate Settings:
-mL -Ou- -Ot- Ob- -Op- -Or- -Od- -Ooa- -nw=2066 -D_FRC_BOARD
mcw ~ mcp list: Along with all the C and H files, FRC_library_8722.lib and 18f8722.lkr.
One final thing. I took Kevin.org's frc_camera_21.zip files and compiled them successfully, straight out of the box, butgot the same error with IFIloader. The HEX file supplied successfully downloaded.
Hopefully this is enough for you. If I have to I can get to the school tonight for more, but I’ll be there tomorrow for sure. The internet is a little flaky there, so it’s a choice of being next to the robot or on the internet. Thanks again for your help!
Roger.
C18 v2.4 -- Syntax error where there is no syntax error Joel J Programming 7 12-01-2007 17:27
stupid Array error: Error [1300] stack frame too l Validius Programming 7 27-01-2006 10:53
Building material archiver 2000 1 24-06-2002 00:10
Goal Building archiver 2001 0 23-06-2002 22:51
