Go to Post I won't tar and feather you, I'll disagree though. - Andrew Schreiber [more]
Unread 19-01-2007, 16:48
Bochek's Avatar
Bochek Bochek is offline
AKA: Adam Bochek
FRC #2200 (MMRambotics)
Bochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud of
question about rules (size/orientation)
i was fairly sure that i read somewhere that when in the starting position, if your robot has anything that folds from the horizontal position to the vertical position it must have it in the vertical position for measuring the size of the dimensions.
can anyone confirm this? or is it just me?
- Bochek
Adam Bochek - FRC 2200
http://www.mmrambotics.com
http://www.watchfirstnow.com
Unread 19-01-2007, 17:08
Setsanto's Avatar
Setsanto Setsanto is offline
FRC #1334 (OTHS RobOTics)
Team Role: Animator
Setsanto is a jewel in the roughSetsanto is a jewel in the roughSetsanto is a jewel in the rough
Send a message via MSN to Setsanto
Re: question about rules
Not quite. The actual rule specifies that a robot must be taller vertically than horizontally, and must not exceed the 6-foot footprint. Other than that, you're good to go.
2008 : GTA Regional 7th Seed, Quarters
2008 : Waterloo Regional 4th Seed, Quarters
2007 : GTA Regional 2nd Seed, Quarters
2007 : Waterloo Regional Quarters
Unread 19-01-2007, 17:12
Steve W Steve W is offline
Grow Up? Why?
Steve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond repute
The robot must start with a foot print of no larger than 28 x 38. The height depends on weight or vice versa. 6 ft = 100 lb. 5 ft = 110 lb. 4 ft = 120 lb.
We do not stop playing because we grow old;
we grow old because we stop playing.
Unread 19-01-2007, 17:14
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Oh really? I think not. There are no minimum dimensions for the robot.
Unread 19-01-2007, 17:18
DonRotolo's Avatar
Back to humble
FRC #0832
No, there are no minimums specified (although there is a practical minimum), but there is one rule relevant:
<G29> ROBOT orientation - ROBOTS must start the match with their long (maximum) dimension in a vertical orientation. After the start of the match, ROBOTS may change their orientation such that the long dimension is either vertical or horizontal. Refer to Rule <R37> in Section 8 to determine how this affects the use of bumpers.
To me that means that a robot must have its longest dimension in the vertical plane. This may affect low rolling "bricks", but can be easily cured with a tall, thin and flexible 'antenna' (maybe a flag holder?) that is taller than any other robot dimension.
Don
Unread 19-01-2007, 17:21
Setsanto's Avatar
Team Role: Animator
Don
Explained quite alot better than how i did.
Unread 19-01-2007, 17:27
Grow Up? Why?
This rule is for robots that flop down. You can have a robot with a 50" wheel base if it is orientated vertically to start the game then flops down to be horizontal.
Unread 19-01-2007, 17:29
DonRotolo's Avatar
Back to humble
FRC #0832
Yes, but a 38 x 28 x 12 'rampbot' would need to start vertically.
Unread 19-01-2007, 17:32
Bochek's Avatar
AKA: Adam Bochek
so if i make a 48" long arm lay down on a 52 degree angle so that it only takes up 32" of vertical space is that allowed?
- Bochek
Unread 19-01-2007, 17:33
Grow Up? Why?
What you are reading is poorly written. The reasoning behind the rule is for flop down robots. FIRST does not intend for teams to have to "stand on their heads" to start the game. If all 4 wheels are on the floor and you fit into the foot print then you are OK. If you are uncertain please post the question in the Q&A forum on the FIRST website.
Unread 19-01-2007, 17:35
DonRotolo's Avatar
Back to humble
FRC #0832
<snip>
I dunno, seems pretty clear to me.
Unread 19-01-2007, 17:38
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
How do you know that?
Unread 19-01-2007, 17:40
Grow Up? Why?
I am not 100% sure that is why I mentioned to ask on the Q&A for an official answer.
Unread 19-01-2007, 17:45
EricLeifermann's Avatar
EricLeifermann EricLeifermann is offline
Taking some personal time
The rule IS for flop down robots and always has been. In 2002 my previous team, Team 93, had a robot that was the max 28 X 38 though i think it was a little bit different dimensions that year but it was only like 15 inches tall, it did not have to stand on its side and then fall to its wheels. it for if your robots wheel base is like 28x60 then you must start with the 60 in direction vertical and fall down.
Unread 19-01-2007, 17:52
Bochek's Avatar
AKA: Adam Bochek
so then my plan follows the rules?
About the new rules-about the updated Rule <G09> aten Rules/Strategy 1 13-01-2007 13:20
Max Control Board Size Question Dermot_135 Control System 5 07-02-2006 22:12
Question about rules: Does ball damage count as field damage? Jevin H Rules/Strategy 11 17-01-2006 14:21
Questions about rules ahecht Rules/Strategy 9 07-01-2002 22:45
