Go to Post FIRST is not a destination, its not the reward, its the slingshot that will launch you from where you are, to where you can be. - KenWittlief [more]
Unread 19-01-2007, 17:18
DonRotolo's Avatar
Back to humble
FRC #0832
Re: question about rules
No, there are no minimums specified (although there is a practical minimum), but there is one rule relevant:
<G29> ROBOT orientation - ROBOTS must start the match with their long (maximum) dimension in a vertical orientation. After the start of the match, ROBOTS may change their orientation such that the long dimension is either vertical or horizontal. Refer to Rule <R37> in Section 8 to determine how this affects the use of bumpers.
To me that means that a robot must have its longest dimension in the vertical plane. This may affect low rolling "bricks", but can be easily cured with a tall, thin and flexible 'antenna' (maybe a flag holder?) that is taller than any other robot dimension.
Don
About the new rules-about the updated Rule <G09> aten Rules/Strategy 1 13-01-2007 13:20
Max Control Board Size Question Dermot_135 Control System 5 07-02-2006 22:12
Question about rules: Does ball damage count as field damage? Jevin H Rules/Strategy 11 17-01-2006 14:21
Questions about rules ahecht Rules/Strategy 9 07-01-2002 22:45
