Go to Post It's good to learn from experience. It's better to learn from somebody else's experience. - Jay TenBrink [more]
Unread 19-01-2007, 18:38
bayesianlogic bayesianlogic is offline
ekzept
AKA: Jan Theodore Galkowski
bayesianlogic is an unknown quantity at this point
Cool Dashboard .ini file, configuration
Is there a specification for the .ini file that is associated with the Dashboard program? In particular, the Dashboard shows a number of User Bytes available for display, as well as LEDs. While the specification document on the Dashboard details the protocol between OI and RC allowing peoplee to write their own Dashboard, is there a specification or description of how the existing one might be used? Is the Labview code available and might that help with this?
Thanks.
-- Mentor, Team 2053, TigerTronics, Endicott, NY.
Unread 20-01-2007, 17:44
kwilliam's Avatar
kwilliam kwilliam is offline
FRC #1038
kwilliam has a spectacular aura aboutkwilliam has a spectacular aura about
Re: Dashboard .ini file, configuration
The User Bytes and LEDs are set in the Default_Routine in user_routines.c, if I recall correctly. The LED's correspond to those on the Operator Interface.
Labview Dashboard and updated IFI dashboard spec Joe Ross LabView and Data Acquisition 1 04-04-2006 02:04
Help! making an inventor file into an autodesk file kjhobin Inventor 5 19-03-2006 23:04
Configuration File? FFnut Programming 2 03-02-2006 17:38
How do we convert a modified user routines file into a valid .HEX file HuskieRobotics Programming 13 28-02-2004 12:12
Dashboard OCX file Ameya Programming 2 31-12-2002 14:50
