Go to Post I say we all stop flaming and pointing out what went wrong or what bad calls were made and start pointing out how much fun we all have at the regionals and what FIRST actually has done for us. - burkechrs1 [more]
Unread 19-01-2007, 20:37
kmcclary's Avatar
kmcclary kmcclary is offline
Founder 830/1015;Mentor 66/470/1502
FRC #0470 (Alpha Omega Robotics)
Rookie Year: 1994
kmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond repute
Re: Vacuums!
Originally Posted by drewjones13 View Post
Is there an image/scematic for the most basic vacuum system using solenoids and the air storage tanks?? can you please post a url to it or maybe email it to me?
Wait a sec... That won't work. There's simply no way to run the kit Vacuum Generator (VG) an entire round solely from tanked air.
Unless you are generating vacuum with a kit motor and a pump assembly, you'll need the compressor, just to operate the VG. The kit VG is a Venturi device. Think of a soda straw that you blow across, to raise the liquid in a drink cup. It works like that. So, the VG is going to require constant airflow running through it just to operate, whether or not you're holding ANYTHING. Without a compressor, you'd run out of tanked air in only a few seconds after the very first time you activated your vacuum generator!
The basic schematic for a compressor based system is shown in the 2007 Pneumatics Manual. (See the sticky link for it at the top of the Pneumatics Forum.)
That said... *IF* you can come up with a vacuum pump assembly that you can hack to be run by a kit motor, NOW you have something! Your simplest move would be to design a "reversable air pump", and directly connect it to your suction cup. Run it one way to stick, and reverse the motor to blow-off the ringer.
If that's not possible, you'll need to either vent the line between your motor based homebrew VG & suction cup with a valve of some kind (the kit valves won't work for this app - they require pilot air pressure to work at all), or else inject compressed air with a separate valve into the line. (The latter IS possible with kit valves, but the system is more complex than a venting solution, since you're right back to requiring stored air or a compressor, JUST to run the kit valves!)
Does this answer your question?
- Keith
Keith McClary - Organizer/Mentor/Sponsor - Ann Arbor MI area FIRST teams
ACTI - Automation Computer Technologies, Inc. (Sponsoring FIRST teams since 2001!)
MI Robot Club (Trainer) / GO-Tech Maker's Club / RepRap-Michigan) / SEMI CNC Club
"Certifiably Insane": Started FIVE FRC teams & many robot clubs (so far)!
2002: 830 "Rat Pack" | 2003-5;14: 1015;1076 "Pi Hi Samurai" | 2005-6: 1549 "Washtenuts"/"Fire Traxx"
2005-(on): 1502 "Technical Difficulties" | 2006-(on): FIRST Volunteer!
2009-(on): 470 "Alpha Omega" | WAFL | Sponsor & "Floating Engineer" for MI Dist 13 (Washtenaw Cnty)
2011: 3638 "Tigertrons" | 2013-(on): 4395 "ViBots" | 2014-(on) 66 "Grizzlies"
"Home" Teams: 66, 470, 1076, 1502, 4395
Local FIRST alumni at or coming to Ann Arbor (UM/EMU/WCC/Cleary)?
...We Want YOU as a Mentor! Please email me for info!
Support CDF Reputation - If a posting helped, thank 'em with rep points!
"It must be FRC build season when your spouse and children become 'Action Items 8 & 9'..."
