Go to Post FIRST truly isnt about building robots, but allowing yourself to reach higher and farther than you ever could. - Brandon Holley [more]
Unread 19-01-2007, 22:03
GMAdan's Avatar
GMAdan GMAdan is offline
Team member turned mentor
AKA: Daniel A. Cobar
FRC #1881 (GAMMA Elite)
GMAdan has a spectacular aura aboutGMAdan has a spectacular aura about
Send a message via AIM to GMAdan
Re: pic: 1881 tube interface idea
Originally Posted by InfernoX14 View Post
This was one of my early ideas, but after seeing the round peice of diamond plate at the end of the posts, I quickly discarded it. There is about 1" of clearance between the ring and the plate on the post. And seeing as the "fingers" that touch the ring have to be over 1" or something (I don't know the specific rule) that wouldn't really work.
How you do intend on getting spoilers off of the posts, too? That would be a bit more difficult than necessary.
There is rule of thickness of the tube contactor? I must have over looked it when reading
Well if i do remember the center plate on the post is 10'' the inside of the tube is 13''. This leaves us with 3'' to play with. the fingers are not in excess of an inch in that regard. meaning with fingers in place we have little bit more than an inch left over. Also a side note the image is upside down.
pic: Team #8's Tube Interface dfukuba Extra Discussion 5 13-01-2007 02:04
pic: Height on top of a tube Jeff Rodriguez Extra Discussion 21 13-01-2007 01:46
pic: Team #8's Tube Interface dfukuba Extra Discussion 13 13-01-2007 01:16
pic: 1881 new gearbox design GMAdan Extra Discussion 7 21-12-2006 01:59
I²C Interface on PIC CBM3 Programming 2 01-11-2003 22:28
