Go to Post I sincerely hope no one on CD is going to neg rep you for thinking - Richard Wallace [more]
Unread 17-01-2007, 23:57
kmcclary's Avatar
kmcclary kmcclary is offline
Founder 830/1015;Mentor 66/470/1502
FRC #0470 (Alpha Omega Robotics)
Rookie Year: 1994
kmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond repute
Mounting the PIAB Suction Cup
According to the specs, the PIAB suction cup has a 3/8-18NPSF (National Pipe Straight Dryseal) outer thread. That's not a standard tap in MY set! ...And FIRST didn't supply a mating nut for it (that I've noticed at least).
What are you guys doing for mounting this thing?
So far, I've tried:
- Sticking the end into the closest sized pipe coupler. Only a few threads go in before it jams. (Hmmm...) That's not secure enough for me.
- All of my local hardware stores only carry NPT taps in that size. (FYI, NPT = National Pipe Thread - That's tapered, not straight, to form conical jam seals in pipe connections. No joy...)
- I haven't found a mating nut for it. (IS there a mating nut somewhere?) A "3/8 pipe thread" does not take a 3/8" nut. It's slightly larger than a a 5/8" nut. (Darn...) Nothing fits in metric, either (worth the try though). I couldn't find one at McMaster. Googling "3/8-18NPSF nut" didn't work, either.
- I HAVE found a 3/8-18NPSF tap at McMaster.com (#2526A44), but that costs $28. IMO that seems kinda steep for just ONE lousy use!
So... Has anyone found a sneaky, cheaper way yet to mount the suction cup? I really don't want to fork out the bucks for the special tap! (Let alone store and then try to find the darn thing again in my tap collection a few years from now whenever we need to use a suction cup again...)
Personally, I'm currently leaning toward drilling an oversized hole in my mount, then filling the gap with some structural epoxy. (That should form a nice, strong, "threaded socket"!) But that's soooo tacky, heavy, and prone to other failure modes.
Suggestions appreciated. Thanks!
- Keith
Keith McClary - Organizer/Mentor/Sponsor - Ann Arbor MI area FIRST teams
ACTI - Automation Computer Technologies, Inc. (Sponsoring FIRST teams since 2001!)
MI Robot Club (Trainer) / GO-Tech Maker's Club / RepRap-Michigan) / SEMI CNC Club
"Certifiably Insane": Started FIVE FRC teams & many robot clubs (so far)!
2002: 830 "Rat Pack" | 2003-5;14: 1015;1076 "Pi Hi Samurai" | 2005-6: 1549 "Washtenuts"/"Fire Traxx"
2005-(on): 1502 "Technical Difficulties" | 2006-(on): FIRST Volunteer!
2009-(on): 470 "Alpha Omega" | WAFL | Sponsor & "Floating Engineer" for MI Dist 13 (Washtenaw Cnty)
2011: 3638 "Tigertrons" | 2013-(on): 4395 "ViBots" | 2014-(on) 66 "Grizzlies"
"Home" Teams: 66, 470, 1076, 1502, 4395
Local FIRST alumni at or coming to Ann Arbor (UM/EMU/WCC/Cleary)?
...We Want YOU as a Mentor! Please email me for info!
Support CDF Reputation - If a posting helped, thank 'em with rep points!
"It must be FRC build season when your spouse and children become 'Action Items 8 & 9'..."
Unread 18-01-2007, 00:03
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Mounting the PIAB Suction Cup
I have a lathe, I don't see what the problem is. Cut some threads in a piece of metal to fit the part. I guess if you don't have a lathe, then you see the problem differently than I do.
If the 3/8 NPT tap happens to have the same thread pitch, and the conical tap happens to have the same diameter as the suction cup at some point along it's length, you might consider making a thin nut from 1/4" aluminum stock. The threads will not be a perfect fit, but they could be close enough.
Unread 18-01-2007, 00:30
Gabe's Avatar
Gabe Gabe is offline
Pocket Full of Tools
FRC #0604 (Quixilver)
Gabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond repute
Well, until you know for certain where it will be placed you can just use a hot glue gun to make a nice seal. Once the suction cup is in place and you are certain of its placement you can use more permanent epoxy like JB weld.
Team site: Q U I X I L V E R
My favorite tool is my imagination; I’m always finding new ways to use it.
Unread 18-01-2007, 00:41
kmcclary's Avatar
Rookie Year: 1994
No luck. That's our problem: There are no lathes here. (A excellent suggestion though, for whenever we do get one!)
...and I hate to ask a sponsor to spend big bucks to have one of their machinsts go out and make one lousy nut. That's one expensive nut!
Is that what your team is doing?
Other tricks, anyone?
(And before anyone says it, considering the thought time spent on this already I probably could have just gone out and bought the darn tap... But this is one of those "generic" problems that nag at you. I'd really like to find a better, simple solution for one-of problems like this than "go and throw money", just for the next time something similar comes up. Thanks!)
- Keith
Unread 18-01-2007, 12:38
pauluffel's Avatar
pauluffel pauluffel is offline
AKA: Paul Luffel
FRC #1127 (Lotus Robotics)
pauluffel is a jewel in the roughpauluffel is a jewel in the roughpauluffel is a jewel in the rough
Send a message via AIM to pauluffel
PIAB sells T-slot adapters for their suction cups (you are using a standard automotive industry end-of-arm tooling system, right?) which seems like it would be easy enough to modify into a standard mount bracket.
http://www.piab.com/Templates/WebBas....aspx?id=10183
Part number 01.04.111 (the G3/8") should be compatible with the FC75P.4E.07UF Suction Cup in the KOP. (Use email 'j.endira@ltcind.com' to access datasheets and CAD files.)
For quick reference:
PIAB part 01.04.111
Base: 1.25" square
Unread 18-01-2007, 13:03
GeoffP GeoffP is offline
Engineer
FRC #1222 (Falcons)
GeoffP is an unknown quantity at this point
you should be able to get a mating component at a local pneumatics supplier or distributer -- festo, smc, bimbo, numatics, motion industries,...
find the right fit -- do not use epoxy. you will suck something up and need to replace or clean the unit half way through the tourney. I recommend a spare in your pit kit.
Unread 19-01-2007, 12:25
Gary Bonner Gary Bonner is offline
FRC #3974
Gary Bonner has a spectacular aura aboutGary Bonner has a spectacular aura about
The Kit of Parts checklist identifies the suction cup as PN FC75P.4E.07UF. According to the PIAB website, the male threads are G3/8, and not compatible with NP threads.
Unread 19-01-2007, 12:48
MrForbes's Avatar
AKA: Jim
Hmmmm.....interesting.....
"Suction cup FC75P Polyurethane 60, G3/8" male - 1/8" NPSF female"
So that could be the problem, we need a G3/8" nut, not a NPSF nut. Good catch!
Unread 19-01-2007, 13:09
scott@maine.rr. scott@maine.rr. is offline
FRC #0058 (Riot Crew)
Rookie Year: 1995
scott@maine.rr. is an unknown quantity at this point
The G3/8 thread is a British straight pipe thread. It is 19 TPI, 16.62 mm major diameter.
See http://www.marylandmetrics.com/tech/thddat7.htm
Scott
Unread 19-01-2007, 21:01
kmcclary's Avatar
Rookie Year: 1994
Did you actually find a NPSF nut? if so, that would work as well. (As I said a the top, NPSF stands for "National Pipe STRAIGHT etc..." )
We haven't been able to find a 3/8-18 NPSF nut anywhere locally. (You probably tried a 3/8-18 NPT [National Pipe Thread] connector. That is the TAPERED one - I mentioned above that we already know it won't work. )
But that still isn't my original question... What off-the-shelf solutions have YOU guys already FOUND, to mount this puppy? (Part sources, please) We'd considering the link (mentioned above) for the T-nuts, but that just converts the problem into one requiring a T-Slot holder. And, giving us the specs for the thread doesn't help (we have that already), as we have no lathe here.
I guess I'd still like to hear other actual off-the-shelf solutions people have tried (which WORK, and hold it SECURELY), for those of us that do NOT have access to a lathe.
Thanks!
- Keith
Unread 19-01-2007, 21:59
MrForbes's Avatar
AKA: Jim
Off the shelf solution: get a very short 1/8" npt nipple, and an 1/8" npt coupler, and put the mounting bracket between them, and screw it together. You'll have to mess around to get the spacing correct so the pipe threads tighten about the same time the bodys of the cup and coupler contact the bracket.
I can draw a sketch if you don't understand, let me know
Unread 19-01-2007, 22:00
Andrew Blair's Avatar
FRC #0306 (CRT)
Buy a 3/8" shaft collar?
-Sir Francis Bacon
-Albert Einstein
Unread 19-01-2007, 22:03
MrForbes's Avatar
AKA: Jim
the G3/8" pipe thread is much larger than 3/8", but a 5/8" shaft collar might work.
With pipe sizes, the size is the nominal inside diameter...not like bolts, where the size is the actual outside diameter.
Unread 19-01-2007, 22:24
FRC #0306 (CRT)
Oh, you're right! I didn't even think about the actual size of the vacuum cup. But that seem like the easiest option, should a tap not be available. You'd probably need to weld onto the collar, but it should hold the cup more securely.
-Sir Francis Bacon
-Albert Einstein
Unread 20-01-2007, 00:04
DonRotolo's Avatar
Back to humble
FRC #0832
Ummm, I may be making a fool of myself here, but I'm pretty sure our cup came with a nut, we used it to mount it to a metal plate for testing...
Don
pic: how not to use a suction cup Sterno Chit-Chat 28 11-02-2007 17:00
Suction Cup Nut IfIwasarichman Technical Discussion 5 31-01-2007 08:21
Suction Cup CAD/Schematic?? brennerator Inventor 3 14-01-2007 23:00
More clarification on the suction rules Natsume Rules/Strategy 7 15-01-2003 01:04
Who do you think will the Stanley Cup in the NHL?? Matt Attallah Chit-Chat 24 11-04-2002 10:01
