Re: Chain Tensioning Method?
It takes some precise machining but you could use an idler sprocket or friction resistant plastic rod in a verticle slot being pushed up by a spring on either side.
We ordered some large diameter nylon rod from McM, the drive team is pondering some ways to use it, probably cut in half lengthwise, and with a groove turned in it to guide the chain.
Last year's experience showed us that it's worthwhile to spend some time on tensioner design.... |
That device they tightened was something similar to what ive attached below, its the piece i made to tension our conveyor belt last year.
There are commercial tensioners as well.
One is an idler sprocket on a bearing, you slide it along perpendicular to the chain somewhere to add tension to the chain Another is an arrangement just like on the big CIM motor - an idler with bearing, mounted to an arm with a spring (often adjustable tension). Third are various plastic slides and such, as mentioned already. McMaster sells all of these. Don |
Our take on an adjustable chain tensioner. It was easy to make, simple, not really expensive (cheaper than floaters anyway) and it is possible to spring load them, although we did not. I made a more detailed post about them here.
A thick nylon washer on a bolt. Its fool proof to put on, just tension it, and bolt it on. However, you don't want to use them too much.
#7
I really liked the chain tensioners that 1625 used on their robot last year. They're great because adjusting the tension is really simple, all you have to do is pivot the little arm that holds the idler sprocket. This worked with their one-chain-per-side configuration.
Here's a picture, and you can see the tensioner right next to the transmission: |
#8
Here is a great thread on the 254/968 drive train
http://www.chiefdelphi.com/forums/sh...threadid=50318 Here is an alternative design that I came up with that does the same job without the fancy parts. A great render is most of the way down the page. http://www.chiefdelphi.com/forums/sh...ad.php?t=50768 |
#9
I just did the tensioning system on our robot today, and a simple solution that we are using is basically a small piece of delrin (low friction plastic) pushing down on the chain with two screws tapped into the delrin (yes it actually works..). Then the screws are attached through a part of the frame directly above the chain. Seems to work well so far, going to play with it tomorrow more.
#10
That's what we had in mind, making it adjustable through a long range of travel is the fun part! Being able to quickly release the chain tension, and unhook the chain without removing the master link so one can rapidly change a wheel between rounds, is the goal.
#11
You could use something like this.
The grey cylinder is a sprocket, and the side plates (blue) bolt on to the KOP pneumatics mounting brackets (green). In our case, we were going to attach a spring of the right tension to the open axle (bottom-left) and to a bolt which would be driven into the top of the mounting block (red) between the Mounting brackets; but you could as easily attach a pneumatic piston, or anything else. Scale reference: the red mounting block is meant to fit around 1" square tubing. ![]() |
#12
#14
thanks for the link, we hadn't thought of that!
#15
| Chain Drive chain | Damelvin | 3D Animation and Competition | 2 | 15-02-2005 00:19 |
| Autonomous Method | Astronouth7303 | Programming | 3 | 25-02-2004 17:14 |
| Axle mounts- Chain tensioning | Jeff Sharpe | Technical Discussion | 12 | 20-01-2003 22:50 |
| CRYSTAL METHOD CONCERT | drksdofthemoon | Chit-Chat | 7 | 30-04-2002 16:58 |
| Chain and chain breaker source? | kmcclary | Off-Season Events | 4 | 22-10-2001 22:51 |
