Go to Post Bomb squad, that grabber was the coolest way to grab a tetrahedral object in the history of grabbing tetrahedral objects. - IronVulture [more]
Unread 19-01-2007, 22:19
David Sherman David Sherman is offline
FIRST College Student Mentor
FRC #0973 (GRR)
David Sherman is on a distinguished road
Send a message via AIM to David Sherman
Chain Tensioning Method?
I'm designing the drivetrain for this year's bot and we need a way to tension chains. Last year we used floating idlers from mc master and those were a mess. I'm looking at an automatic tensioning system, such as something spring loaded. Any suggestions, tips, or advice?
FRC 973
2008-Present:College Student Mentor
FRC 599 2003-2007
Unread 19-01-2007, 22:23
cgredalertcc cgredalertcc is offline
AKA: Charlie Baxter
FRC #1747 (Harrison Boiler Robotics)
cgredalertcc is a name known to allcgredalertcc is a name known to allcgredalertcc is a name known to allcgredalertcc is a name known to allcgredalertcc is a name known to allcgredalertcc is a name known to all
Send a message via AIM to cgredalertcc
Re: Chain Tensioning Method?
I would think you could fabricate something like the tensioners that come stock on the large cims. Obviously you would want probably a tighter spring but I'm pretty sure fabricating that would be easy.
Unread 19-01-2007, 22:42
Richard Wallace's Avatar
Richard Wallace Richard Wallace is online now
I live for the details.
FRC #3620 (Average Joes)
What problems did you have with the floating idlers from McMaster? Did you use #25 chain or #35 chain?
Richard Wallace
since 2003
Unread 19-01-2007, 22:58
FRC #0973 (GRR)
I used 35 chain and just getting the strips, that hold the two blocks together, in to the drivetrain was very difficult and adjusting them was very time consuming.
FRC 973
FRC 599 2003-2007
Unread 19-01-2007, 23:15
Simon Strauss's Avatar
Simon Strauss Simon Strauss is offline
None #1155 (Sciborgs)
Simon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant future
Send a message via AIM to Simon Strauss
It takes some precise machining but you could use an idler sprocket or friction resistant plastic rod in a verticle slot being pushed up by a spring on either side.
NYC Chairmen's Award Winners 2007 Thank you team 2265, you were our project and we couldnt have done it without you all
New Jersey Regional Finalists thanks to teams 359 and 486 Aloha
"Beware of the Ska Robot Army!" -The Aquabats
Unread 19-01-2007, 23:18
Dan Petrovic's Avatar
Dan Petrovic Dan Petrovic is offline
Got my degree and ready for more!
FRC #0166 (Chop Shop)
Dan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond repute
Don't use chain?
That seems to be a pretty good tensioning method to me. We aren't going to have a single link of chain on our robot this year.
You could also look at what 254/968 did last year for chain tensioning. I can't exactly describe it, but it tensioned the chain when someone tighted some device. Maybe someone from either one of those teams can clear that up for us.
The sign applause was definately one of the best moments I had ever witnessed at a FIRST event.
Who knew silence could be so loud?
Mayhem in Merrimack hosts: 2005-2016 - Week Zero hosts in partnership with FIRST HQ: 2014-2016
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
We ordered some large diameter nylon rod from McM, the drive team is pondering some ways to use it, probably cut in half lengthwise, and with a groove turned in it to guide the chain.
Last year's experience showed us that it's worthwhile to spend some time on tensioner design....
Unread 19-01-2007, 23:25
That device they tightened was something similar to what ive attached below, its the piece i made to tension our conveyor belt last year.
Unread 19-01-2007, 23:26
DonRotolo's Avatar
Back to humble
FRC #0832
There are commercial tensioners as well.
One is an idler sprocket on a bearing, you slide it along perpendicular to the chain somewhere to add tension to the chain
Another is an arrangement just like on the big CIM motor - an idler with bearing, mounted to an arm with a spring (often adjustable tension).
Third are various plastic slides and such, as mentioned already.
McMaster sells all of these.
Don
Unread 19-01-2007, 23:48
in between teams
AKA: Luke Van Oort
Our take on an adjustable chain tensioner. It was easy to make, simple, not really expensive (cheaper than floaters anyway) and it is possible to spring load them, although we did not. I made a more detailed post about them here.
Team 1219: 2009 - Mentor
Unread 19-01-2007, 23:51
Kyle Love's Avatar
Kyle Love Kyle Love is offline
Support STEM Education
FRC #3301 (Jay County Robotics)
Kyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond repute
A thick nylon washer on a bolt. Its fool proof to put on, just tension it, and bolt it on. However, you don't want to use them too much.
Kyle Love
Teams I've been on:
Team 45 - The TechnoKats - Student/Leader/Driver 2004-2007
Team 1646 - Boiler Precision Guessworks - Mentor 2007-2011
Team 3301 - Jay County Robotics - Teacher 2011-Present
Unread 20-01-2007, 00:16
BBnum3's Avatar
BBnum3 BBnum3 is offline
Ridiculously proud of MN First
AKA: Nat Thompson
FRC #1816 (The Green Machine)
BBnum3 is a splendid one to beholdBBnum3 is a splendid one to beholdBBnum3 is a splendid one to beholdBBnum3 is a splendid one to beholdBBnum3 is a splendid one to beholdBBnum3 is a splendid one to beholdBBnum3 is a splendid one to beholdBBnum3 is a splendid one to behold
Send a message via AIM to BBnum3
I really liked the chain tensioners that 1625 used on their robot last year. They're great because adjusting the tension is really simple, all you have to do is pivot the little arm that holds the idler sprocket. This worked with their one-chain-per-side configuration.
Here's a picture, and you can see the tensioner right next to the transmission:
Founding member of Team 1816.
Unread 20-01-2007, 00:21
Here is a great thread on the 254/968 drive train
http://www.chiefdelphi.com/forums/sh...threadid=50318
Here is an alternative design that I came up with that does the same job without the fancy parts. A great render is most of the way down the page.
http://www.chiefdelphi.com/forums/sh...ad.php?t=50768
Unread 20-01-2007, 00:29
Jonathan Norris Jonathan Norris is offline
Jno
FRC #0610 (Crescent Robotics)
Jonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond repute
I just did the tensioning system on our robot today, and a simple solution that we are using is basically a small piece of delrin (low friction plastic) pushing down on the chain with two screws tapped into the delrin (yes it actually works..). Then the screws are attached through a part of the frame directly above the chain. Seems to work well so far, going to play with it tomorrow more.
Co-Founder of Taplytics.com
2013 World Champions (1241, 1477, 610)
Crescent Robotics Team 610 Mentor
K-Botics Team 2809 Founding Mentor ('09-'11)
Queen's University Mechanical Engineering, Applied Science '11
Crescent Robotics Team 610 Alumni
Unread 20-01-2007, 00:40
MrForbes's Avatar
AKA: Jim
That's what we had in mind, making it adjustable through a long range of travel is the fun part! Being able to quickly release the chain tension, and unhook the chain without removing the master link so one can rapidly change a wheel between rounds, is the goal.
Chain Drive chain Damelvin 3D Animation and Competition 2 15-02-2005 00:19
Autonomous Method Astronouth7303 Programming 3 25-02-2004 17:14
Axle mounts- Chain tensioning Jeff Sharpe Technical Discussion 12 20-01-2003 22:50
CRYSTAL METHOD CONCERT drksdofthemoon Chit-Chat 7 30-04-2002 16:58
Chain and chain breaker source? kmcclary Off-Season Events 4 22-10-2001 22:51
