Go to Post If you are stupid about this and violate the rules, and thereby cause your alliance to lose a match, then your alliance partners will gang up on you and violate your robot. - dlavery [more]
Unread 17-01-2007, 13:12
DylanRoss DylanRoss is offline
FRC #1987
DylanRoss is an unknown quantity at this point
Axes in Default Code?
Hi, I've been looking over the 2007 default code and making adjustments where necessary; however, I've encountered something that doesn't seem right to me. Under the one-joystick drive section, I see this code:
p1_x = 255 - p1_y;
p1_y = 255 - pwm05;
pwm13 = pwm14 = Limit_Mix(2000 + p1_y + p1_x - 127);
pwm15 = pwm16 = Limit_Mix(2000 + p1_y - p1_x + 127);
I haven't actually downloaded the code to the robot, but it seems like the first two lines would switch the X and Y axes. I made a simple program that allowed me to input joystick values and it gave me the right/left drive values, and it gave me the backwards output I expected. It seems to me like removing those first two lines should solve the problem. Is this normal? Are the axes switched? Should I go ahead and remove those two lines?
Thanks,
Dylan
Unread 17-01-2007, 15:32
Bomberofdoom's Avatar
Bomberofdoom Bomberofdoom is offline
Biggest FIRST addict in Israel
AKA: Nir Levanon
FRC #2230 (Zcharia's Angels)
Bomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond repute
Send a message via MSN to Bomberofdoom
Re: Axes in Default Code?
Haven't seen those first 2 lines you wrote, but if you connect the PWM13 to the right motor(victor) and PWM15 to the left, it will all work.
Unread 19-01-2007, 23:31
slloyd slloyd is offline
AKA: Sonny
FRC #1221 (Nerbotics)
slloyd is an unknown quantity at this point
hey, that code is assuming that the shaft of the two motors are facing each other...
if you mount your motors with the shafts pointing away from each other then your motors will run backwards (up on joystick means drive backwards, left on joystick causes robot to turn right).
you need to invert the signal in the code to support the motors aligned with shafts facing away.
try this modification:
p1_x = p1_y- 255 ;
p1_y = pwm05 - 255;
slloyd
Unread 19-01-2007, 23:37
AKA: Sonny
now here's a question for you...
what does pwm05 have to do with the joystick? on our robot nothing is even plugged into pwm05... why is this part of the single joystick X/Y mixing operation code?
i have no idea..
slloyd
Unread 20-01-2007, 19:06
FRC #1987
Before that bit of code, the program sets p1_y to pwm06 and p1_x to pwm05.
Unread 21-01-2007, 14:21
AKA: Sonny
thx for the clarification
i wonder if that is safe? i mean, what if i connected something to PWM05?
maybe the single joystick control code should default to:
p1_x_unmodified = p1_x;
p1_x = 255 - p1_y;
p1_y = 255 - p1_x_unmodified;
eh?
Modified default code gives "code violation" scottmso Programming 8 10-02-2006 23:17
problems using gyro/adc code with camera default code tanstaafl Programming 7 22-01-2006 23:09
user code to default code phoenixomega001 Programming 5 09-01-2005 00:09
default code archiver 2001 2 23-06-2002 22:53
