Go to Post This just goes to prove there was life before FIRST (but it wasn't as much fun!) - Ken Loyd [more]
  #31   Spotlight this post!
Unread 20-01-2007, 00:42
Biff Biff is offline
AKA: Tom Cooper
#1227 (Techno Gremlins)
Biff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the rough
Re: Vacuums!
Kit motors and scrounged shop vac parts or serch for two stage vacume motors from surplus places. Remove motor guts, attach pulley, belt and kit motor, gear for between 15k and 28k (hope to keep current under 46 amps). Built two models last year. Never used them in competion.
Biff
  #32   Spotlight this post!
Unread 24-01-2007, 17:31
drewjones13's Avatar
drewjones13 drewjones13 is offline
drewjones13 is an unknown quantity at this point
Re: Vacuums!
We have a compressor taht refills the tanks whenever one empties so in theory we should be able to run the VG with tanked air.
  #33   Spotlight this post!
Unread 24-01-2007, 17:56
JustinMilne's Avatar
JustinMilne JustinMilne is offline
FRC #1901 (Ram Rod)
JustinMilne is an unknown quantity at this point
Exclamation Re: Vacuums!
compressors are heavy and fittings are heavy
are you shure you are making the most wheight efficent decision?
wheight of part vs eficenty
a griper can be just as efficent
  #34   Spotlight this post!
Unread 24-01-2007, 20:25
DARKAGE's Avatar
DARKAGE DARKAGE is offline
AKA: Vic
FRC #0441 (Devil Dogs)
DARKAGE is an unknown quantity at this point
Send a message via Yahoo to DARKAGE
Re: Vacuums!
How do you connect the vacumm to the pnuematic parts and pump.????
  #35   Spotlight this post!
Unread 02-02-2007, 23:34
Rick-906's Avatar
Rick-906 Rick-906 is offline
inventor of the hoverbot-2006
AKA: Richard
FRC #0296 (Loyola Northern Knights)
Team Role: Communications
Rick-906 is a splendid one to beholdRick-906 is a splendid one to beholdRick-906 is a splendid one to beholdRick-906 is a splendid one to beholdRick-906 is a splendid one to beholdRick-906 is a splendid one to beholdRick-906 is a splendid one to behold
Re: Vacuums!
Has anyone else found that the suction cups really suck?
all puns aside... our team experimented alot with them and found that they were far from perfect, not only do they add a lot of weight, they take time to connect to the tubes [for the suction to build up] and are fairly easily knocked off the robot.
im thinking of trying the piston method as suggested above, since thats weight efficient and would probably be fairly powerful.
but i think custom suction cups are the way to go
The knack of flying is learning how to throw yourself at the ground and miss.
--Hitchhikers Guide to the Galaxy
2006 Archimedes Divisional Champions
2006 Championship Winner
  #36   Spotlight this post!
Unread 18-02-2007, 20:37
robogeek753's Avatar
robogeek753 robogeek753 is offline
Droid Master
AKA: Bradley
FRC #0753 (The High Desert Droids)
robogeek753 is an unknown quantity at this point
Re: Vacuums!
Note:
The rules state that you absolutely never can and/or should reverse polarity on the compressor. If you do that the FIRST Safety Nazis will make you change it. Just use the vacuum pumps in the Kit (you can order more w/ cups for about 30$ from PIAB.com)
Don't reverse polarity on commpresors!!!
GO 753
  #37   Spotlight this post!
Unread 19-02-2007, 01:29
kmcclary's Avatar
kmcclary kmcclary is offline
Founder 830/1015;Mentor 66/470/1502
FRC #0470 (Alpha Omega Robotics)
Rookie Year: 1994
kmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond repute
Re: Vacuums!
Originally Posted by robogeek753 View Post
Note:
GO 753
To add to that, OTHERS have already stated (I'm not trying it to verify!): IF you try reversing the compressor, due to the valving inside it is still a compressor! The thing you lose is COOLING. The fan is not blowing air properly across the fins anymore. The compressor overheats, and given enough time it potentially become damaged, or destroyed.
So again, do NOT try reversing the compressor!
(I'm not sure about that one team's claim of being able to use the compressor as a vacuum pump. I'm curious how they actually did that.)
- Keith McClary
Chief Engineer, Team 1502, "Technical Difficulties"
Keith McClary - Organizer/Mentor/Sponsor - Ann Arbor MI area FIRST teams
ACTI - Automation Computer Technologies, Inc. (Sponsoring FIRST teams since 2001!)
MI Robot Club (Trainer) / GO-Tech Maker's Club / RepRap-Michigan) / SEMI CNC Club
"Certifiably Insane": Started FIVE FRC teams & many robot clubs (so far)!
2002: 830 "Rat Pack" | 2003-5;14: 1015;1076 "Pi Hi Samurai" | 2005-6: 1549 "Washtenuts"/"Fire Traxx"
2005-(on): 1502 "Technical Difficulties" | 2006-(on): FIRST Volunteer!
2009-(on): 470 "Alpha Omega" | WAFL | Sponsor & "Floating Engineer" for MI Dist 13 (Washtenaw Cnty)
2011: 3638 "Tigertrons" | 2013-(on): 4395 "ViBots" | 2014-(on) 66 "Grizzlies"
"Home" Teams: 66, 470, 1076, 1502, 4395
Local FIRST alumni at or coming to Ann Arbor (UM/EMU/WCC/Cleary)?
...We Want YOU as a Mentor! Please email me for info!
Support CDF Reputation - If a posting helped, thank 'em with rep points!
"It must be FRC build season when your spouse and children become 'Action Items 8 & 9'..."
