I lessthanthree you.
Unread 20-01-2007, 01:30
Electrical Engineer
Rookie Year: 1995
Re: I hate "C"
Originally Posted by maniac_2040 View Post
...Why does it throw off the stack variables by two bytes each?(Not that I know much about the "stack" anyways ) and how did you know this?
I've been working with embedded processors for over 25 years (and vacuum tubes, et cetera for 10 years before that). I think that I first learned about C and stack variables in college (circa 1978).
dcbrown's explanation is correct. When viewed from a pure "software" perspective, the fact that this processor passes parameters on the stack is, perhaps, confusing. C allows a variable argument list and it is up to the called function (in this case, printf) to parse the format string (the first parameter of the function is actually a pointer to a string) and determine how many variables there are and how large each one is. Your first %d in your format string indicated a 2 byte variable was the second parameter on the stack. When you put a long variable in the calling statement, 4 bytes were pushed onto the stack. That meant that all of your subsequent parameters were 2 bytes off...
I would refer you to K&R for more details. It was the bible back in the 70's and, in my opinion, it is still the bible.
For specifics on C as implemented for this processor, I'd look here.
Regards,
Mike
Mike Betts
As easy as 355/113...
New NEMO White Papers! "Creating a Killer Packet" and "25 Ways to Sponsor" Jessica Boucher Team Organization 0 10-08-2005 10:55
"Thunderbirds" Vs. "Team America" Which one will rule the box office? Elgin Clock Chit-Chat 3 07-09-2004 19:53
Conflict between "Initialize_Tracker()" and "pwm13 & pwm15"? Kevin? gnormhurst Programming 3 22-02-2004 02:55
how tall is the ramp when in "up" and "balanced" position??? archiver 2001 1 24-06-2002 00:54
I "hate" the new first site Dima General Forum 11 06-01-2002 19:40
