Go to Post Oh, you mean the refs. The only hand signal I've seen the judges use is the hi-five. - RoboMom [more]
Unread 19-01-2007, 16:56
VerticalReality VerticalReality is offline
AKA: Melissa Wong
FRC #0912 (Iron Lyons)
VerticalReality is an unknown quantity at this point
Fisher Price Motors
Hello, does anyone know if it is possible to make a lockable transmission for the Fisher Price Motor? If so, how would you do it?
You can reply here or send me an email at melissawong321@hotmail.com.
Thanks and good luck to everyone,
Melissa W.
[Team 912]
Unread 19-01-2007, 17:02
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Re: Fisher Price Motors
Could you describe what you mean by 'lockable transmission' with a bit more clarity?
It's possible to do nearly anything with enough resources and ingenuity.
--Madison--
...down at the Ozdust!
Unread 19-01-2007, 17:06
Joel J's Avatar
Joel J Joel J is offline
do you..
Not backdrivable, probably.. Like the winches of 2004.
Joel Johnson
RAGE (173) Alumni, 1999-2003
AKA: Melissa Wong
I sure can. Our arm on our robot is going to be lifted up and down using a motor. The only suitable motor would be the Fisher Price motor so inorder to make it possible, we need to make the motor lock when the arm has reached a certain height because the weight of the arm will just bring it back down -quite fast.
Does that clear it up a bit?
Melissa W.
[Team 912]
Unread 19-01-2007, 17:12
AdamHeard's Avatar
Lead Mentor
If you use a PID loop to control the arm, it will be able to dynamically control the motor to hold the arm steady.
Look up PID in the whitepapers section or google it.
Unread 19-01-2007, 17:20
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Additionally, you can set the "brake" jumper on the victor speed control, which will slow the rate of descent of your arm a little bit. However, if true non-backdrivability is what you want, a traditional way of achieving that is with a worm gear, like this. The Fisher Price motor (by itself) is a very high RPM motor though, and you'd probably want an additional stage of gearing in there somewhere. Also check out the FIRST mechanism library
Unread 19-01-2007, 19:33
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
Melissa W.
[Team 912]
The higher the gear ratio between the arm and the motor the easier it will be be hold the arm's position. Of course the arm will also move much slower too. But that is the nature of engineering, pick your druther and go with it.
With a high gear ratio, you could add a brake to the arm mechanism somewhere. The closer to the motor the less force you need. I seem to remember WildStang using a servo to make a brake for their FPs one year, but as an Inspector I see so many robots I might be somewhat confused.
ChrisH
Christopher H Husmann, PE
"Who is John Galt?"
Unread 19-01-2007, 19:57
Eric Yahrmatter's Avatar
Eric Yahrmatter Eric Yahrmatter is offline
FRC #0033 (Killer Bees)
Eric Yahrmatter has a spectacular aura aboutEric Yahrmatter has a spectacular aura about
Fisher Price motors are not well suited for dead-load (static load) applications, so a PID loop is not the best way to hold an arm steady. It could put you at risk of burning out your motor(s). Therefore, I recommend that you try using a Dewalt transmission with the non-backdrive pins in place. Here's an example:
http://www.jmen.biz/Bees/2004-2005_P...edium/0043.jpg
Directions for interfacing an FP to a Dewalt Transmission:
http://www.chiefdelphi.com/media/papers/1592
Henry_Mareck's Avatar
Henry_Mareck Henry_Mareck is offline
FRC #0418 (Purple Haze / LASA Robotics)
Team Role: Student
Henry_Mareck is a jewel in the roughHenry_Mareck is a jewel in the roughHenry_Mareck is a jewel in the rough
Send a message via AIM to Henry_Mareck
Assuming you are going to be gearing the motor down, DeWalt drill transmissions can have anti-backdrive pins in them which do the job nicely. They also provide a 47:1 reduction in first gear, which helps to bring that massive rpm down to a manageable level. A whitepaper on how to adapt a DeWalt to a Fisher Price can be found here.
Edit: Hows that for a coincidence?
Unread 19-01-2007, 20:15
groves groves is offline
Steve Liggett
None #1213 (Groves)
groves is just really nicegroves is just really nicegroves is just really nicegroves is just really nicegroves is just really nice
you could use a craftsman ratchet
Unread 19-01-2007, 21:45
Dominicano0519's Avatar
Dominicano0519 Dominicano0519 is offline
My team is not competing this year
AKA: Demolition Man
FRC #0381 (Tornadoes)
Dominicano0519 will become famous soon enough
Send a message via MSN to Dominicano0519 Send a message via Yahoo to Dominicano0519
just get a monster gear ratio and thats it!
althought that might weight a little too much
Favorite Phrases:
1. I like your robot, no-homo
2. "It depends how you define alone" ( Bill Clinton when being questioned about Monica Lewinsky)
Unread 20-01-2007, 00:25
Biff Biff is offline
AKA: Tom Cooper
#1227 (Techno Gremlins)
Biff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the rough
Worm gear.
Pluses, a single lead stays where you park it. Power off
Down sides, very high friction loss and gear ratio. things may move way slower than you want. I would stay away from FP's on highly loaded arms, they smell real bad when stalled. Consider moving FP's to drive along with a pair of Cims if you are doing tank drive. Andymark http://andymark.biz/am-0002.html Makes a gear box to match Fp's to Cims. you only lose about 5 to 7%. Almost used one last year As a shooter motor.
Biff
Unread 20-01-2007, 00:29
CraigHickman
Posts: n/a
I highly suggest using the disc brakes from preformance off road bikes. With one of those, you can stop solid a 4 CIM drivetrain to the point of stalling. It's more than light and simple enough for your job.
Unread 20-01-2007, 01:46
Dan Petrovic's Avatar
Dan Petrovic Dan Petrovic is offline
Got my degree and ready for more!
FRC #0166 (Chop Shop)
Dan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond repute
I'm surprised no one has mentioned worm gears.
We're going to have worm gears at every moving joint on our robot this year.
The sign applause was definately one of the best moments I had ever witnessed at a FIRST event.
Who knew silence could be so loud?
Mayhem in Merrimack hosts: 2005-2016 - Week Zero hosts in partnership with FIRST HQ: 2014-2016
Unread 20-01-2007, 03:31
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
Like they've said.. Worm Gear. Here's our's from 2004 used as a winch to lift ourselves up. A little video of it is here here
Fisher Price Motors Uchia_Itachi Motors 11 15-01-2007 11:43
Fisher Price Motors for Drill Motors archiver 2001 0 24-06-2002 00:22
Fisher Price Motors... archiver 2001 2 23-06-2002 22:36
4 fisher price motors? Jordan A. General Forum 2 12-01-2002 11:52
